Question about GE DBSR453EBWW Electric Dryer
Dryer screeches under a load but quiet running empty
  • GE Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.Also remove the screws holding the lint filter in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me,
Posted on Aug 22, 2010
Dryer screeches than stops cycle. Now doesnt work
I would bug them until they fixed it. You got sold a bill of goods. In other words avpiececof junk. Your bearings are burned up. You should ask for your money back if that is in the clause. Hold on to your paperwork and get copies made. I hope you didn't pay but 50-75 dollars.
Feb 28, 2013 | Frigidaire Dryers
My washing machine inner stainless steel tub appears to be unattached. It will run an empty load and makes knocking noises and screech type humming. It will not run with any load size in it. Is this a...
Something seized up.
Probably fixable.
If under warranty call them up.
If not under warranty, take it apart yourself!
If these are like dryers, you may have just lost a plastic guide or the belt (if these one in these) may be stretched.
Depending on the age of the machine and your budget, sometimes good to buy a replacement and then doodle at fixing them.
Hang around here and someone will probably know.
I don't buy front loaders because of the electronics, but they do save water.
Feb 12, 2013 | Washing Machines
Extremely screeching noise when running?
Screeching is the metal-on-metal contact of the drum touching the rear of the unit while
turning - there's a (usually) felt cover gasket over the circular depression at the back of the dryer.
When this wears through (after a number of years/loads), you get the screeching of
metal-to-metal contact.
Problem: friction can heat up the metal so much that the remaining felt gasket material (and/or
accumulated lint or clothing) catches fire.
Fix: replace felt drum gasket.
The Maytag Atlantis MDE6400AY electric dryer has a DuraCushion(tm) dryer drum, so I'm
suspecting the "DuraCushion" has worn out at least at one point in its 360-degree arc.
Jul 07, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
I have a GE dryer that make a very loud screeching noise when turned on. The heavier the load, the louder the noise. The noise gets quieter as the load drys and the dryer barely makes it when turned on...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 16, 2011 | Dryers
Thumping/Screeching sound, MD:LDE8616ACE. Rollers? Idler Pulley?
Your description sounds like one or both of the rear drum supports (rollers) is bad. A quiet thumping is almost always present as the weld in the drum comes in contact with the drum supports. A binding support will squeal, and the thumping could be worse at that time. After running the dryer until the noises are present, once disassembled, you can tell if a support is bunding or rolling normally by spinning it by hand. The same goes for the idler pulley. Make sure power is disconnected from the unit befor attempting any repairs.
While the unit is disassembled for repair, make sure your your old cat is not inside.
Sep 11, 2009 | Maytag PYE2300AY Electric Dryer
Screeching Kenmore front loading dryer
There is a hub and bearing that needs to be replaced you will need to have this serviced by a qualified tech. The whole front of the dryer has to come off and the basket needs to be removed.
Jan 05, 2009 | Kenmore 94872 Front Load Stacked Washer /...
Dryer makes screeching noise runs for awhile then shuts off.
The 1,5 year new dryer makes a terrible screaching noise when it has a load of clothes in it. It still dries fine, no problem with the heating element. No noise without clothes, only when it has a load.
Nov 23, 2008 | Dryers
The Dryer is not Squealing- It is SCREECHING FOR THE ENTIRE CYCLE...
could be rollor wheels that support rear of drum need grease or replaceing also have a slide bearing in frount may need lub or replaced
Nov 03, 2007 | Whirlpool LEB6300 Electric Dryer
GE DBSR453EBWW Electric Dryer Logo
87 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
