Question about SanDisk Sansa e260 MP3 Player
Sansa e280 recovery mode
When i start my e280 it says that the main image has failed to open and 2 switch 2 recovery mode, i hav done that and open the file from the sansa website http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
the firmware file
then when i open the file and go 2 the page where it reads the version and 2 continue with the upgrade it says that it cant read the version details
plz help
  • 8,596 Answers
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 23, 2008
When i start appear "load main image failed switch to recovery mode"
The error means that the program of your SanDisk is corrupted. Do you see an option to switch it to "recovery mode"? If not, the best thing that you could do is to send the device to the authorized service center for repair.
Thank you!
Sep 12, 2010 | SanDisk Sansa E280 MP3 Player
My mp3 player won?t start
Download and use the Sansa Recovery Tool from Sandisk's website.
-Tha Mp3 Doctor
Jan 10, 2009 | SanDisk Sansa E280 MP3 Player
My mp3 won't start
Sansa e280 Main Image Wont Load Problem, Plus firmware updater doesn't work
Do not worry! I had the same problem as you before and got it fixed perfectly! Go to this thread and read the instructions carefully.
http://www.anythingbutipod.com/forum/showthread.php?t=11233
Note that doing this will delete all files in your player, so I recommend you to save your files somewhere before doing this.
Dec 28, 2008 | SanDisk Sansa e250 MP3 Player
Load main image failed switch to recovery mode
follow the above steps but turn on the power button if nothing is happening. It's the only way I got my e280 to recovery mode
Sep 23, 2008 | SanDisk Sansa E280 MP3 Player
Switch to recovery mode...
go here
good luck
please mark the post with a fixya!
Feb 12, 2008 | SanDisk Sansa E280 MP3 Player
My Sansa e280 forze
Try plugging the player into the computer and formatting it. This will erase the music from the player, but you have a copy of the music on your computer as well. I think this will solve your problem.
Good luck.
Nov 08, 2007 | SanDisk Sansa E280 MP3 Player
My sansa e280 rhapsody says switch to recovery mode
Recovery mode is used to recover from a fatal error.
Follow these steps and youll be back in business.
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Oct 22, 2007 | SanDisk Sansa e260 MP3 Player
Recovery mode
Recovery mode won't help you unless you have the recovery files to go with it. Most likely you will need to re-install the firmware on to the device. Download this "recovery tool" from the SanDisk website and run it with your device connected in recovery mode. Make sure you select "format" when prompted. Tool is here; http://sandisk.com/assets/file/downloads/firmware/e200fw01.00.12.exe Recovery mode - power off device. Slide "hold" switch into hold position. Press and hold "record" button and then connect to PC.(keep record button pressed until after connected to pc) Hope this helps.
Sep 04, 2007 | SanDisk Sansa E280 MP3 Player
go to sandisk and go to support there you can find support the recovery software. hope it helps
Jun 16, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
418 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
