Question about Dirt Devil Featherlite Bagless Vacuum M085845Vacuum
I cleaned the belt area and removed all of the strings and fuzz. However, I am still smelling rubber burning from the vacuum.
  • 694 Answers
This can be caused by a loose or worn belt that is continually slipping on the brush. It simply needs replaced with the correct belt.
It can also be caused by the belt being caught on something by the shaft. In this case, the power head needs to be taken apart to check for improper placement of belt.
The vacuum motor could also be overheating, which would more than likely be caused by a plugged hose. Disconnect hose from power head and vacuum, then try to roll a marble or small ball through it. Also, check the vacuum's hose port for a plug. Another area to check is the tube in the power head. Clear if needed before continueing operation.
Posted on Aug 22, 2010
GREEN LIGHT AND MOTOR
The green light is an indicator that your brush is rolling smoothly. If it starts to flicker and you smell something that smells like rubber burning you need to do a couple things; one is remove the roller and clean off all of the hair, string, etc. Next you want to replace your belt. Just because the roller isn't turning doesn't mean the motor and the belt aren't either. If your roller gets jammed your belt will continue to spin and it will eventually wear down in one spot and break. Replace the belt, clean the roller and your should be fine.
Apr 26, 2013 | Kirby Ultimate G Bagged Upright Vacuum
I have the G series Kirby silver vacuum, I was vacuuming and started to smell some burning. Looked down and my green light was off also. What could it be? PLS HELP
Your belt is burning and will eventually wear down and break. The green light comes from copper brushes on your roller creating an electrical current that lights the little green light. As long as the roller is turning, the light will stay on. There may be something jamming the roller (hair, string, paper, etc). Clean the roller off and replace your belt. If you don't replace the belt it will break soon enough. Once you start smelling the "rubber burning" smell it's and indication that your belt has deteriorated at some point and has a weak spot in it. Clean the roller and replace the belt and it should be fine.
Apr 20, 2013 | Kirby Ultimate G Bagged Upright Vacuum
Brush not spinning
1. Make sure the belt is in contact with the shaft. 2. Remove the roller and clean the brushes AND the area that seats into the vacuum. If there is too much hair, string, etc. the brush may not roll. chances are the belt is probably not making contact. If it was you would smell rubber burning if the brush wasn't turning.
Mar 03, 2013 | Kirby Vacuums
What is causing a slight burning rubber smell when running the vacuum?
If this is a sweeper model with a rotating brush, remove the brush assembly. Clean and oil (3-1oil or similar) the bearings on the ends of the brush. They are usually full of string, hair, and thread which binds the brush. Check the belt for burn spots or other damage. Hope this helps!
Oct 04, 2010 | Vacuums
Every so often I get a smell of burning from my g4 Kirby vacuum. I noticed it's when I'm vacuuming a fairly new rug on this house I clean. Should I be concerned?
If it is a smell of burning rubber - most likely your vacuum belt is overdue for replacement.
At this point - remove the brush roller, remove the old belt, clean off your brush roller and remove any string or hair that may be bound up around it (usually around where the belt goes or on the sides), and put on a new belt. Your Kirby should act good as new if your bag is replaced at the same time.
If the brush roller has too much string and hair wrapped around it, many times the brush roller will not spin as fast as the belt is driving it and you will get that burning smell.
Dec 23, 2009 | Vacuums
DC07 Low Reach Vacuum smells like a belt is burning and is making
The roller is likely jammed, or there is debris around the belt area
Jul 05, 2009 | Dyson DC07 Low Reach Bagless Upright...
Rainbow Vacuum smells like something is burning.
Your belt is worn and that is why there is a burnt rubber smell. You need to change your belt. You can find a replacement belt and instructions here:
Rainbow Replacement Belts
Apr 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Burning rubber smell when the vacuum is on.
it sounds like the belt may be burning like the roller bar is stuck maybe or the belt is stretched and is burning itself off
Jan 11, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Odor of burt rubber
check the bush roller, remove it from the case and clean the ends and middle from hair,dust and string.
Jan 16, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Bissell Cleanwell II Bagless uprighht vacuum
Hi Pmob20,
Remove the brush and clean all the string or whatever may be trapped at the end edges of the brush.  This is usually the case with Bissel vacs, that string or fiber gets trapped at the ends of the brush assembly.
Oct 10, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Dirt Devil Featherlite Bagless Vacuum M085845Vacuum Logo
248 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
