Question about Dell E173FP 17" LCD Monitor
Dell monitor (Model: 2005FPW) flickers for 10 min when first turned on.
  • 11,361 Answers
Check for bad caps, cold solder joints as shown in my albums here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Replacement board:
http://www.lcdrepair.us
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Aug 22, 2010
Dell 2005FPW screen turns black after a second ,can not get it back on
this is a fairly common problem. The backlight circuit is probably shot. Not much to do but replace the monitor.
Oct 05, 2014 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell UltraSharp 2005FPW shut down wont power up.
You can have the board repaired for $50 or you can inspect it first for bad connectionc, bad caps, etc.
http://www.lcdrepair.us/2005fpw-power.html
Apr 22, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
How and where i can find aschematic for dell 2005fpw.
You can start from here if this helps.
http://support.dell.com/support/edocs/monitors/2005FPW/En/about.htm#Specifioications
Dec 14, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell 2005FPW Monitor Flicker problem
The flickering is most likely the florescent backlight having a hard time starting, Just like in a light fixture, as it gets old, it takes longer to warm up to get full functionality.
If under warranty, contact Dell for a replacement, if not, then when it becomes untenable, replace the monitor. Prices are dropping drastically, an new 20 or 22 In can be bought for about $150 or less
Aug 08, 2009 | Computers & Internet
I was given a dell 2005fpw screen by a friend and im not sure if i've damaged it. When you plug it in to the mains and turn it on it comes up with the dell screen but after that the screen flickers and im...
if the screen is flickering it could be a bad monitor. Try hooking up another known good working one if you can. If the known good working monitor works then you know the dell monitor you were given is bad. If you get the same flickering result then make sure you wait until your laptop boots up into windows then try to change the output to the monitor. If you can get a picture then try the other monitor to see if you can get a picture as well.
If you can get pictures with both monitors then you know it was a matter of changing the output on the laptop if you get a picture on one but not the other then you know one of the monitors is bad. Depending on the laptop you have will depend on what key combination is used to change the video output to the monitor.
Aug 03, 2009 | Dell Computers & Internet
Dell 2005fpw flash problem
Often this is a capacitor problem, there have been many problems with them as of late. http://www.badcaps.net/forum post here and they will be able to help you out.
Jun 12, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell monitor 2005FPW keeps on flashing
I was having the same problem.
I solved it by replacing the two 47µF capacitors on the power supply/inverter board.
I actually removed all the capacitors (around 13) and all checked out fine except for the two 47µF.
I forgot to take pictures or even write down the capacitor label on the board.
They are located close to the logic board connector
Feb 05, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Flashing on and off
I would suggest trying another monitor to rule out your PC or monitor card. I would also check the video settings on the PC. Then assuming your cable/connector and video card are okay, it sounds like a lamp or lamp driver (a.k.a. ballast or inverter) issue. In other words, an internal issue that probably needs component-level troubleshooting.
Jan 08, 2007 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
462 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
