Question about Motorola Talkabout T6210 (14 Channels) 2-Way Radio
Are motorola talkabout t6210 and talkabout 200 compatable. I have the eavesdrop reducer turned off on the t6210 but the transmissions are garbled when recieved by the talkabout 200.
  • Motorola Master
  • 1,654 Answers
Yes, they should be compatible. You are correct in shutting off your eaves drop reducer. You might also check to see you have your interference eliminator code set to zero (off). We have been unable to find a good online source for a user guide for the T200, but if memory serves, they do not have "code". Here is a link to the very similar T280 guide: http://www.giantintl.com/ContentManage/manuals/Moto/T280_User_Manual.pdf
And here is a link to the T6210 user guide http://www.giantintl.com/ContentManage/manuals/Moto/T6200_User_Manual_E.pdf
Between the two radios there should be 14 frequencies in common. If you continue to have difficulties you might check to see if your batteries are good and/or fully charged. This also can interfere with good communications.
Best regards.
Posted on Aug 23, 2010
Two sets of Motorola Walki Talki radios will not communicate.
In addition to the channel and privacy codes, some Motorola two-way radios have a feature called Eavesdrop Reducer where you have 3 scramble settings available; perhaps you have this set on one of sets of radios but not the other. It should be something like that because otherwise there is no reason that by setting the radios to the same channel and privacy code they wouldn't be able to send/receive to each other.
Nov 24, 2013 | Motorola Walkie Talkie 2-Way Radio
Motorola talkabout MR350 headset only sends audio and can not recieve
Likely not compatible. One thing to try is to make certain the transmitting unit is turned OFF when you initially plug in the headset. Sometimes if a headset is plugged into a radio when it is already ON, the headset will appear to be in VOX (voice activated) mode and will not allow the user to receive. Also, if this headset has an inline PTT, it may not be compatible with the radio and you would need to use the PTT on the radio.
If this doesn't work, you would need to use the TalkAbout headset designed for the MR350.
Best regards.
Mar 03, 2012 | Motorola MR350R Two Way Radio
I have the motorola talkabout 2 way radios.= #MH370CR tpr . Problem - This is the 2nd set within the last 4 months The radios will shut off by themselves and sometimes will shut off just after the 1st...
I had a similar problem - my Talkabouts would not transmit - after checking the interference codes, qt, etc, it turns out the rechargeable batteries weren't able to handle the 1-watt mode. I switched to another FRS channel that only transmitted at .5 watts, and that seems to have cured the problem, but the range is probably reduced. With another set, I chucked (recycled) the rechargeables and placed 3 new AAA's in and it worked like a champ for a long time. Hope this helps
Jul 07, 2011 | Motorola Walkie Talkies 2-Way Radio
I lost one on my t6500 talkabout, what can I do with the one remaning? can I use it whit a new pair?
Yes, other TalkAbout radios are compatible with the T6500. Most of this series of radios have the 14 FRS frequencies installed.
Bestr regards.
Jan 05, 2011 | Motorola Talkabout T6500 (7 Channels)...
How to get a Talkabout T5720 to communicate with a
The frequency range and operatngmode of the two radios are compatible. To get the Radius operating on a GMRS channel you'll need a Motorola programming cable and software, OR a trip to a Motorola dealer for frequency programming. Considering the cost involved, the 2-watt output of the Radius, and the 1-watt output of the Talkabout, you would be better off performance and cost wise buying a pair of 5-watt GMRS portables.
BillB
Jan 11, 2010 | Motorola Talkabout T5720 (7 Channels)...
How do you turn off the talk confirmation tone (bleepity - bleep) on a motorola talkabout fr60.
On most TalkAbout radios you hold in the plus (+) button while turning on the radio.
Nov 25, 2009 | Motorola Talkabout FR60 (14 Channels)...
SX700 2-way radio garbled
ok sounds like there is a lose connection in the airal or the speaker so it would probably need to be repaired
your best option is to take it to a electronics repair centre near you that specialise in motorola equipment
Mar 18, 2008 | Motorola Talkabout SX700 2-Way Radio
Communications
Yes, but depends on the configuration/setup and programming/frequency assignation of the MTS2000.
To my knowledge, the UHF version of the Motorola MTS2000 are designed to operate either in the 403~470Mhz or the 450~512 or 520MHz band.
On the other hand, Motorola TalkAbout Radio are design limited to operate in the FRS band which is 462.5625~462.7250MHZ and/or the GMRS band which is 462.550~467.725.
So technically, both the MTS2000 and the FRS/GMRS share some frequencies. What needs to be done is to re-program the frequency allocation of the MTS2000 into its channels to match the TalkAbouts frequencies. The other way around is not possible. TalkAbouts frequency assignments can not be reprogrammed/changed. Below are typical TalkAbout Channels/Frequencies.de11c4e.jpg
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 04, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola Talkabout T6210 (14 Channels) 2-Way Radio Logo
198 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
