Question about Whirlpool MH8150XJ Microwave Oven
Display lights are not on, microwave will not turn on. it does have power to everything.
  • Whirlpool Master
  • 9,047 Answers
Maybe you can address your question (and include your full model number) here or repost here to FixYa with a new message that includes the model.
Posted on Aug 22, 2010
  • William Miller
    William Miller Aug 22, 2010
    Especially if your cooktop lights recently failed see this.
How do I determine if the fuse is bad on a Frigidare #FMT118EPB Microwave? Thanks.
Michael, if the fuse is bad, it will take out everything on the microwave. You will not have any lights inside or on your display. You can find the fuse inside of the cover by following where your power cord goes into the unit and following usually the black wire to the fuse. Hope this helps!
Dec 04, 2014 | Frigidaire FMT118EPB Microwave Oven
Hi I have a Samsung SMH9187 micowave that is dead (no display, light, fan, mirowave).
Sounds like the main fuse blew. It's either near where the power cord enters the cabinet, or behind the control panel (if an over the range unit).
You may also have some type of failure in the high voltage circuit; based on your description of the symptoms.
Aug 16, 2014 | Samsung SMH9187ST Microwave Oven
AEG MCD2664E-m - plate not turning
There is no separate fuse only for turntable motor. Usually there is two fuse, one in High Voltage section (instead fuse could be HV protect diode) and another one for 220 V (light, turntable motor, fun motor, display....). If light work normally then is turtable motor faulty.
Dado
Mar 21, 2014 | AEG MCD2664EM 60cm Built In Microwave &...
Power quite one day it lost power like curcuit broke there is power to the outlet
If there was a power outage, and then your microwave oven never came back on. Then it could be a possible fuse problem. If the circuit breaker had tripped, then after you turned off the cir. brkr. and turned it back on, then everything should've worked fine. Again, I would lean towards a blown fuse in your microwave. Now you're saying there's power to the outlet, and it still won't go on? Then my easy solution would be to plug it into another outlet, and try it again. Your problem could be that plug. After doing everything I just suggested, at any time did you get a digital readout on your time display in the upper right hand corner of the oven. Basically, is there any lights on at all when you're plugged into the wall. If not, then the problem is in the microwave itself! It could be just as simple as a blown fuse, but I would like you to try these other alternatives first. Feel free to contact me again if these don't work. Good Luck, and I hope I've helped you some. Let me know, Jim
Apr 06, 2010 | General Electric Microwave Oven
Power is on, lights and front panel work, just no heat
There are a few definite causes but if you would like to rectify problem without messing around, i wold replace magnatron: capacitor and HV diode.That will certainly sort the problem out.
Sep 25, 2009 | Goldstar MV-1501 Microwave Oven
All the lights and features work, but no heat. Will not cook.
9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section. Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay..... Q - The microwave display counts down and the inside light is on, but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
Jul 11, 2009 | Maytag MMV4205 Microwave Oven
Only display on, no cooking power
faulty components i would repolace it if it were mine
Jun 21, 2009 | Kenmore 62462 / 62464 / 62469 1200 Watts...
Sanyo Super Showerwave out!
Sounds like a bad connection inside. unplug the power, take off the cover, look over all the connectors closely.
Dec 31, 2007 | Hotpoint RVM1435 Microwave Oven
Whirlpool MH8150XJ Microwave Oven Logo
64 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
