Question about Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer
My Whirlpool Duet dryer keeps shutting off and it takes forever before it is cool enough again to restart the drying.
  • schwarzie Aug 23, 2010
    Thank you--I will let you know after the service repair person checks it out.
  • Whirlpool Master
  • 19,396 Answers
Hi.
Repair is done testing element, thermostat and timer board.
A problem cusing this is often a plugged element. That means that the element stays always on because of a contact.
If that is not the problem, then thermostat may be shorted (it reads zero Ohms when limit temperature is reached, not opening and causing overheating).
Check also the status of the thermal fuse.
If all the above is Ok, then test the control board.
The timer board rarely causes this kind of problems, the problem is likely in the heating system.
Posted on Aug 23, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Also, often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 22, 2010
  • Rylee Smith
    Rylee Smith Aug 23, 2010
    Thanks
    Rylee
The clothes take forever to dry. Even with the more Dry cycle the clothes are wet after 40+ minutes The timing changes from 40 minutes then to one hour+.....
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Nov 23, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My dryer panel is turning on by itself. when I shut it off, it turns back on after a while. A load of clothes is drying, and the dryer keeps making a beeping sound every now and again. It seems to be...
Many of your better dryers have an anti-wrinkle function. When a load is complete if you don't take care of it, every little while the dryer will turn on for a few minutes to fluff the clothes and beep to remind you.
May 31, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
It dries but it takes forever. It is like it is not getting very hot. Can you help
CHECK YOUR EXHAUST VENT, MAKE SURE YOU HAVE A GOOD STRONG AIR FLOW WHEN THE MACHINE IS RUNNING. IF IT''S GOOD, THEN CHECK YOUR COILS AND RADIANT SENSOR
Jan 24, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Frigidaire Model FSE446RHS shuts off mid cycle
Hi, If the motor is shutting down mid cycle and can not be restarted untill cooled, the motor will need changed. It is shutting off on a safety overload. These motors cost about $145.00
Please let me know if I can assirt you further.
Vic
Jun 01, 2009 | Dryers
My whirlpool duet gas dryer (model ggw9200lw1) is taking too long
There is a rare chance that the gas supply is clogged. Dealing with gas pipes is dangerous business, don't fool with it unless you are experienced with plumbing. After checking a gas pipe, do a bubble check for leaks with dish soap from a sponge or sprayer. There are small filters and traps placed here and there in the plumbing of some units. They are similar to the ones on a washing machine hose, but smaller.
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Dryer not drying
look at the vent outside and see if it closing or even has a cover this allows cold air inside the dryer and cause it to take longer to dry
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
NOT GETTING HOT ENOUGH TO DRY TOWELS IN AN HOUR
It takes the dryer forever to dry a load of clothing, no matter how many pieces or thickness. Yes, I have already checked the vents out of the dryer, there not clogged. Any other suggestions?
Jul 09, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer Logo
481 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
