Question about Hauck I'coo Pacific Stroller Timber Strollers
Where can i buy a replacement wheel for i'coo pacific?
I changed batteries on my coo koo clock and now the clock works but coo koo does not
Check the milli amps of the batteries. Not all batteries are born equal. See if you can get a 2700 mAh battery. the problem is probibly that there is enough power out of the battery to work the clock but not enough to work both clock & coo-koo.
Jan 15, 2017 | Home
Owner manual pacific sk4500
Look on Pacific's web page, under the customer support tab
Sep 26, 2014 | Pacific Cycle Pacific Exploit Mens...
How do I remove the rear right wheel for replacement?
you should jest take dust cover off then the nut and wheel will slip off you might also loosen fender if its to low and hit tire trying to come off raise the fender so tire will slip off and if it is stuck hit will a punch and hammer at the base of the hub should pop off shouldnt be stuck anyway thats how it will come off buy new will it cost 30 dollars from pacific cycle there will be a sticker with there phone number on near the crank hub cheaper to buy new one instead of fixing old one
Aug 22, 2014 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Hi just bought a I coo pram from a friend and the rear wheel is missing the brake component . So the wheel cannot be locked or slowed down by the hand brake. I don't know what model it is and was wondering...
go to a shop that sells prams and other baby gear and ask they about your item. If it is a popular brand they will have the answers you require.
Jun 01, 2014 | Cars & Trucks
Hello. I have a Pacific PP102W radio/cassette/cd player and the aerial has broken. Any idea where I can buy a replacment? Thank you H Rosen
Go to an electronical components shop, especialized.
Ask for an telescopic aerial antenna, the same that has Pacific PP102W ( took the device to shop).
JMG
Jul 18, 2011 | Audio Players & Recorders
Why did my tire warp when i took off to start ridingPacific Exploit Men's Mountain Bike (26-Inch Wheels)
Tire warped or the wheel? You're too powerful, I guess. Check for uneven spoke tension. Get the tools and learn how to fix it yourself or take it to the shop. DON'T RIDE IT LIKE THAT.
http://www.parktool.com/blog/repair-help/wheel-and-rim-truing
Jun 21, 2011 | Pacific International Cycling
Hi, I can't recline the I coo Pacific stroller, the push button is too hard. I bought the stroller three months ago, so it's still new!! Thank you!
I also had trouble with this but I found if I pulled it up a little before pushing the button it would work and then after doing it several times it gave a little and it didn't need to it anymore x
Jan 08, 2011 | i'coo Pacific Stroller Stone Strollers
Hey stroller i'coo Pacific problem.... The front two wheels don't pivot(?) what's the fix?
You have to unlock the front wheels. Pull out and up on the front wheel lock. Watch the demo video on www.gtbaby.com website.
Aug 14, 2010 | Hauck I'coo Pacific Stroller Timber...
Need a wheel to a Pacific Explorer Bike Trailer
Did you Ever get resolution for this? Wuld you happen to have a manual, I just got this from a garage sale and the told me the manual was online (of course it isn't.). I would love it if you could scan and email to me...
Nov 05, 2009 | InSTEP SC760 Twin Seat Stroller
Hauck I'coo Pacific Stroller  Timber Strollers Logo
240 people viewed this question
Top Hauck Baby Gear Experts
Kelley Hopper
ray gallant
Dorel UK
Dorel UK
Are you a Hauck Baby Gear Expert? Answer questions, earn points and help others
