Question about Peg Perego John Deere Gator HPX
Gator wont start. acts like not in nuetral. Battery charged but won't turn over. dont have diagram to check fuses
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Wrong forum
Posted on Jun 08, 2012
5 Suggested Answers
  • 161 Answers
SOURCE: We just bought a new battery three weeks ago for
this is a very common problem with these types of ride on toys, you have to make sure theres not to much weight in it or it will drain the battery almost right away, also the charger itself maynot be charging it fully . Try charging it fully, put the amount of weight you normally have in it and when it starts to slow down take out the child or children and reach in and push the gas pedal to see if it made a difference.
Posted on Mar 20, 2009
  • 156 Answers
SOURCE: I'am Looking for a diagram for a Plunger Fuse onthe gator 4x2
The wire sequence is red, white, blue.
The red is the farthest from the other two.
If it is a peg perego switch plunger style then this will work.
Hope this helps
Posted on Jun 23, 2009
  • 8 Answers
SOURCE: Gator battery issue
If the charger is green, it should be working. You may need a new battery, but it could also be a switch issue.
http://www.rungreen.com/john_deere_peg_perego.html
Posted on Aug 04, 2009
  • 850 Answers
SOURCE: 2 year old JD Gator wont keep a charge in the battery when using
there is no alternator on these toy gators!
the battery is in the front lower panel 7 should not be charged for more than 14 hours at any one charge!
Mabe the battery needs replacing!
If you ned any further assistance re parts etc. id be glad to help!
Cheers Rob
Posted on Aug 15, 2009
Audi a4 quattro
don't think fuse diagram will help , is the battery in good condition , may not hold enough charge to turn over engine , try jump start if engine starts then get a new battery then check alternator charge rate as may be reason battery went
Jul 15, 2014 | 1999 Audi A4
My 1992 dodge ram power 250 cummins turbo diesel wont charge replaced alt and battery and still wont charge what can be my problem?
My 1992 Cummins W250 auto trans turned out to be the Computer/ECM mounted on front fender by battery tray. Mine only acted up in cold wheather. It started out with the ASD (auto shut down relay) clicking rapidly. In addition the water in fuel, wait to start and check engine light also blinked fast. In this state, the battery would not charge.
Sep 30, 2012 | 1992 Dodge Ram 250
Our john deere gator won't run
how do you know that the battery is charged? it could be that the charger isn't working. I would check the charger with a multimeter and verify that its putting out enough volts to charge the battery, it should be putting out between 13.8 and 14.6 volts
Apr 29, 2012 | Peg Perego John Deere Gator HPX
Gator lacks power when running in our front yard grass.
sounds to me like you have a bad motor, yes both wheels should turn
Dec 30, 2011 | Peg Perego John Deere Gator HPX Ride on...
Wiring diagram mazda premacy car wont startput key in turn over engine wont kickin
Autozone.com has free digrams in the repair section.
What won't "kickin"? The starter does not turn? If that is the case,
Go to the starter, there will be a large battery cable and a smaller wire on a seperate terminal. Put a test light to the small terminal/wire and have a helper turn the key as if to start the car. If the test light comes on then the starter/solenoid is bad. No light, may be ignition, nuetral safety switch, fuses, etc..
Oct 10, 2011 | Cars & Trucks
2001 Montero won't start, replaced starter, battery and alternator. what else could it possibly be?
posibility your nuetral sw is shorted or starter relay is bad. you already spent a lot of time and money may as well buy a diagram otherwise you will spent more. research in the library or go to dealer parts store and ask or beg to see a diagram why the car wont start. what do you hear just click, just crank, it wont turn over, nothing. check fuses
Aug 16, 2010 | 2001 Mitsubishi Montero
Have No ignition light when in Nuetral.plus wont start
russel just because you have new batt does not it is not faulty or not fully charged have it tested should read 12.7 volts if fully charged. it should not be a fuse or green light would not be on when the bic is running . check batt cables at battery and also at stater solenoid. hope this will help
Mar 24, 2009 | 2003 Yamaha YZ 250
Battery died then wont start after charging
i think you are on the right track. my guess would be fusable link
May 19, 2008 | 2004 Nissan Sentra
Peg Perego John Deere Gator HPX Logo
174 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
