How do I lock my router so others cant run off my wireless router?
    Brigadier General:
  • 10,406 Answers
Connect to the web-server "inside" the router, and run the "Wireless Network Setup Wizard". Create an SSID, enable 'WPA' encryption, and set a password/pass-phrase. Give the password/pass-phrase _ONLY_ to your family members.
Posted on Aug 22, 2010
How do i get a security code so others cant use my internert
type 192.168.1.1 into your browser and hit enter. This will take you to your router page.
If you have never been to this page before this is a list of defualt passwords to enter your page.
Linksys BEFW11S4, WRT54G: admin
Linksys EtherFast Cable/DSL Ethernet routers: Administrator
Linksys Comcast routers: comcast
All other Linksys routers: [none]
Default passwords: Linksys BEFW11S4: [none]
Linksys Comcast routers: 1234
All other Linksys routers: admin
From here you can set your own wireless security mode and generate a passphrase or key to lock out intruders.
Hope this helps...Good luck
If I have helped you resolve your problem, please
consider giving me a good rating and a quick
thanks or good job.It will help me as well Thank
you.
Oct 23, 2010 | Linksys Wireless-G WRT54G Router
Cant lock my wireless router forgot password
reset you router on factory set with reset button and need to reconfigure again.
Apr 11, 2010 | NetGear WGT624 Wireless Router
D-LINK WAS LOCKED NOW i CANT GET INTO MY OTHER
If you are locked out of your router, you can either connect to it with a RJ-45 LAN cable.
Once connected you can access the security to reconnect to it.
Otherwise, you can reset the router and reconfigure your wireless connection.
You can reset by sticking a pin in the small hole on the back of the router near the power source.
Thanks,
Pat
Mar 22, 2010 | D-Link WBR-1310/RE 54Mbps 802.11g Wireless...
Cant put a lcok on my smc router
Manual for WBR14-G2 router [6.2 MB] in pdf format:
http://www.smc.com/files/AG/MN_SMCWBR14-G2.pdf
Keeping others from connecting to your router:
1. Have an "wired only" router login access or for this router "change and disable your SSID". This way you avoid that others can login to
to the router changing your settings: See page 48 of the manual.
1.1 Wireless Network Name (SSID): change the default name SMC
to "any private name" ( and remember for later login )
1.2 Broadcast Wireless Network Name: change from default ENABLE
to DISABLE .
2. Make a secure wireless encryption key for your connection:
see page 87.
2.1 For most secure key select WPA / WPA2 only and SAVE SETTINGS .
2.2 See page 91 for entering and saving your secure key: the password
that must be entered to get access to the router.
Sep 18, 2009 | SMC (SMCWBR14-G2) Router
How do I lock my RCA DCW615R router?
You Router supports either WEP or WPA Security. First thing to do is enable the security, it will become difficult to enter from other users.
IF your using a default gateway (192.168.x.x) which is your Router Address. You can enter by Internet Explorer to go inside the Firmware of your Router (http://192.168.0.1) then enter.
This is an example of firmware worksheet:
Please rate me.
Thank you.
Sep 04, 2009 | RCA DCW615R Wireless/Cable Modem
How to lock my router so neghbours cant connect
Follow the instructions on this D-Link page (it shows DI-614, but it is the same procedure for your model):
http://support.dlink.com/faq/view.asp?prod_id=1055
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 26, 2009 | D-Link DI 514 Wireless Router (DI-514)
Netgear range max cant be found by ps3 please help
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. Click the Wireless Settings under Advanced tab.
5. Check the box under Enable Wireless Router Radio and Enable Wireless SSID Broadcast.
6. Click the Wireless Settings under Setup.
7. Change Channel (recommended are 1, 6 and 11).
8. Change the SSID to uniquely identify your network. You might have a similar SSID with your neighbor.
Note: Do not change the SSID if there are already other wireless computers that can connect to the network.
Other factors that you may consider when you are not able to view any available wireless network:
a. Switch for the wireless adapter is turned off
b. Distance between the wireless router and computer
c. Possible wireless interferences
Dec 24, 2008 | NetGear WGR614 Wireless Router
How do I lock my modem?
Go to a computer wired to your router
Open an internet explorer browser
Click on the address bar and type in 192.168.0.1
Type your password for the router.
Normally be default its username admin and blank for password.
Go to wireless on the left side.
Under security type in WPA-PSK
Type in a password 8 charachters or more
ON your wireless computer
Connect to your network name and put in that 8 char password.
If there is anything else just message
Sep 03, 2008 | D-Link AirPlus DI-524 Wireless Router
Ethernet
my router is autometical lock
Jun 21, 2008 | 2wire 2700HG-B Router (2700HGB)
Internet wireless connectivity
This is a common and annoying problem. Your router is running and connected, but they are either not using the same encryption keys or else you have some other setting incorrect (encryption type is a common one).
Turn off the laptop's wireless connection and enable its cable (wired) connection. Connect the laptop to the back of the router physically with a network cable. In a browser type 192.168.1.1 (or other similar number - check your router's quick start guide). Log into the router and go to the WIRELESS SETTINGS. Write down everything you see (channel, station ID, encryption type and key, and whether MAC ADDRESS LOCKING is on (if it is turn it off for now)). Take these settings, reverse the process on your laptop and try to connect wirelessly with the new settings. They have to be exactly the same
If it all works, you need to go back into the router and enable MAC ADDRESS LOCKING after giving it your laptop's MAC ADDRESS, enable the highest standard encryption both the router and the laptop support, and turn off station ID broadcasting if possible.
If you still cannot connect wirelessly, connect again through the wire connection, and turn off encryption, turn off MAC ADDRESS LOCKING, and try again.
Good luck...
Nov 16, 2007 | Belkin (F5D6230-3) Wireless Router
Computers & Internet Logo
141 people viewed this question
David Payne
David Payne
