Question about Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher
The dishes are not coming out clean, how do i fix the dishwasher so that it works at full efficiency?
  • Fisher and P... Master
  • 3,247 Answers
Check the rinse aid setting is according to the user manual. Also use longer cycles for better wash results. Make sure the proper salts are used if you are in hard water area.
If problem is not resolved then buy Finish dishwasher cleaning kits from super market and run each drawer on long cycle with kit located in it according to instructions.
Hope this helps. Please rate this solution to help fixya help you better in future.
Posted on Sep 26, 2010
Machine working fine last week then began to not clean efficiently then water did not all drain away so plunged, soaked up excess, cleaned filter, replenished dishwasher salt and rinse aid and put new...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Apr 17, 2011 | Haier Dishwashers
Tip
Dishs not coming out clean
It is a known fact that if you rince your dishs off before you place them in the dishwasher your dishs will come out alot cleaner. Stuck on foods can be baked on the dish causing the dish not to come out clean also by doing this it will exstend the life of your product because the passage ways for the sprayer will not get cloged giving a full pressure washing
on Dec 10, 2009 | Dishwashers
We have a Bosch SHU3307UC dishwasher. Two friends swear by theirs, saying they put everything in dirty and the load always comes out clean. That does not at all work for us. My wife has to just about wash...
Put dirty stuff in will eventually keep a tech like me very busy. We love to come and charge you alot for cleaning your dishwasher. Remember the Maytag commercials where they put a cake in it? Still got the dishes clean but before long it will cost you big time. Just run everything under the tap. Pot and pans should be lightly washed also. Watch how you place the dishes. Most dishwashers spray up from the bottom. Block it, and the spray will not reach the top.
Nov 28, 2010 | Bosch 23 in. SHU3307UC Built-in Dishwasher
The top does not wash and the bottom some what works. no water pressure
First thing to check is your in coming water pressure and temp.The internal water temp has to be at least 120 degrees to properly clean the dishes.
Second after the machine has stopped filling with water open the door and look at the water level in side you should have 1/2" to 1" of water and it should be hot.
Third if there is not that much water add a few cup fulls off water unit the whole bottom of dishwasher is covered in water. Then start your machine and let it go through a cycle.
If your unit cleans the dishes then you may need to replace the water fill valve,if it does not clean the dishes and the results are the same you need to replace your main wash motor.Remember water temp has to be 120 degrees.
I hope this helps with your dishwasher and you get it fixed fast.
Feb 06, 2010 | Dishwashers
We have a GE dishwasher with upper and lower sprayers. The upper sprayer (one located right under top rack) won't spray or turn which leaves the dishes in upper rack dirty, any suggestions on how to fix...
try c.l.r. to clean dishwasher check and clean lower and upper spray arms out, run no detergent you can also run vinegar in it as well about a cup full,let the machine start to run then stop dish washer for a few hours then restart see if this works for you use a short cycle.
Dec 01, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Not Cleaning Dishes
Hello there:
first you will need to check if the water supply line filter is clogged if not make sure that all of the strainers are not clogged i know that you said the spray arms are clean but if you get a real close look the nozzels expecially the end ones get clogged really easly if you use a tooth pick you can get these cleaned out if all of this does not work than i would suggest replacing the water pump this is what delovers the water under pressure to the spray arms ok
best regards mike
Sep 24, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishes have filmy finish
hello. this will help a great deal.
First of all empty out your dishwasher, toss in two cups of plain white or cider vinegar and run it on the highest and longest cycle.
Always run the hot water in the sink first and start the dishwasher only when the water is as hot as it will get.
This wash will clean out your dishwasher thoroughly.
Then always do your dishes after you have rinsed any residue off of them before placing them in the dishwasher and I always recommend the pot scrubber cycle if you have one.
Jul 07, 2009 | Dishwashers
Model # dwu7702aae has heat delay light coming on during cycle. Why?
Heater is used to both heat water during clean cycle and dry dishes after wash cycle. Most washers have either a separate switch for Heat or Dry for optional use, or some have the water heat and dish dry options built into cycle set options.
You can save money by turning off the Dish Dry option since it is a very in-efficient way to dry dishes. Instead, open the wishwasher door after washing cycle completes, just enough so fresh air can get into, and humid air can escape, dishwasher.
Water Heat option is only needed for dried food on dishes, and is never needed if dishes are either rised off before putting them in the dishwasher, or rinsed off inside the dishwaser with a Rinse cycle, if they are to stand for a time waiting for a full dishwasher for wash.
Feb 22, 2009 | Maytag Dishwashers
Top Dishes not coming clean
Clean ot replace circulation pump.
Clean or replce hoses
Jan 05, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher Logo
65 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
