Question about Whirlpool Washing Machines
Error alarm F 35 is displayed on our Whirlpool Duet washing machine model number WFW9600TW00
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F 35 means Analog Pressure Sensor Failure- which means that there is a malfunction of the component detected by the Steamer Electronic Board.
1. Check that the pressure hose is fixed correctly.
2. Check that the air trap is not blocked.
3. Check that the hose is not blocked
If still the issue is not resolved then it is an issue with the water level pressure switch operation and there is a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome are clear of any blockages, then there is an issue with the water level pressure switch. Please do rate the solution if the issue is resolved or else post a comment for further assistance.
Thanks
Rylee
Posted on Aug 23, 2010
What does 5ud mean 10 minutes from finishing 5 Ud displayed can't open door?
The SUD (not 5UD) code is displayed when excess foam is detected (possibly because excessive detergent is being used). If your machine does not cure itself, you may have to run an "Eco drum clean" cycle (if your machine has it) or a 90 degree cotton cycle with no detergent and no load.
Aug 29, 2016 | Samsung Washing Machines
My whirlpool duet is displaying the error code 888. It works ine through all cycles but the time displays 888. All the lights are illuminated and there is a high pitch alarm sound that remains on until...
Please state brand and model of your washing machine for accurate and specific solution...
There is no 888 error code on my list of whirlpool..I think the 888 flashes is the time remaining..
If the lid opens while the unit is in running mode, time remaining will flash in the display.
Close the lid and press START to continue with the cycle.
Hope it helps..
Dec 03, 2011 | Washing Machines
Whirlpool duet steam WFW9600TW00 code F35
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Oct 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Model # Wfw9600tw00 on final spin sounds like there is a loose bolt in drum.
one of two things there is either something in the pump or pump busted not so bad common problem.
or the bearings are gone and thats big dollars.
Jan 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load washer displays error f did what the manual says but still same problem
it shows f11,also DL,
I did change the door lock,
same alarms.
it's fine for few wash but when it happens again it just stop and show
F11.
Mar 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Finished Clean Washer cycle and my bleach dispenser full
It's normal for all washers with a sanitize or tub clean cycle to leave diluted bleach in the dispenser
Feb 11, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
I have an ''F 35'' error code on a Whirlpool Duet Washer Model # WFW9600TW01
An F 35 error in fact means any number of things, from the drain hose being pushed too deeply into the standpipe to using the wrong soap or too much soap and the computer triggering an over-suds condition. Your best bet is to contact Whirlpool.
Dec 14, 2009 | Washing Machines
Whirlpool Duet washer Displays F 35 code and stops
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet won't drain, the lower plug is clean, displays
usually whirpool duet models come up with the error codes with "F" followed my a number..... can u clarify if its just "F" or has a number next to it... it wud help us provide us better solutions to u.....
Jul 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
139 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
