Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Agitator is very weak. Also, how to you remove back to inspect unit? thanks
    Champion:
  • 245 Answers
This sounds like your dogs are bad. These 4 plastic gear teeth are located right on top inside the agitator. All you need is a 7/16 wrench and aflathead screwdriver. I cannot remember if this washer has a motor coupling. Either way checkthe dogs first.
Posted on Aug 23, 2010
Removing kenmore agitator 417.94862302
You do not have agitator dogs in your machine, yours is made by Frigidaire the agitator can be removed by removing the top of the agitator and remove the bolt. It is screwed directly into the transmission shaft, You want to check the belt to see if it is stretch out , just normal from use.
Feb 06, 2014 | Kenmore 24032\24036 Top Load Washer
Top agitator sort of floats around instead of jerking back and forth.
HI. the internal components that make up the agitator should be inspected for damage.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction. Another issue that might cause this disruption is the Motor coupler.
Washers with a direct drive motor have a motor coupler instead of a belt. The motor coupler consists of three plastic disks (or tri-stars) with interlocking tabs. Those tabs can wear and break which results in slippage. The slippage causes little or no power to be transferred to the transmission. A worn motor coupling can result in weak or no movement of the agitator and spin basket. Inspecting the motor couplers requires removing the motor, which is fairly easy to do.
Remove the cabinet. Locate the motor. The pump is mounted to one side of the motor. You do not have to remove the hoses from the pump unless they prevent you from moving the pump out of your way. If you must remove the hoses, label where they connect first. To disconnect the hoses, pinch the wire clamps with pliers (or loosen the screw) and slide the clamp farther up the hose. Slide the hose off of the pump port.
There are two clips that secure the pump housing to the motor. Use a screwdriver to pry up the clips and remove the cover. Next, slide off the pump to reveal the motor. Disconnect the wiring harness from the motor, do not pull on the wires themselves. The motor typically is secured with retaining clips and bolts. Remove the bolts and use a screwdriver to pry up the clips (if present). Remove the motor.
Mounted on the shaft of the back of the motor you will find the motor coupler. Separate the three disks and inspect them for damage. If you find cracks or excessive wear, replace the coupler.
**(((If the motor couple is in good condition, replace the agitator components and clutch assembly as well.)))
Dec 29, 2009 | Whirlpool Washing Machines
Agitater is weak and stops 3 minutes into wash
Dec 23, 2009 | GE Washing Machines
Washer keeps spinning. doesn't move to next cycle
It sounds like the agitator , air bell or transmission is failing. Since the unit spins the belt & motor is ok. I recommend removing & inspecting the agitator & air bell. If they are not stripped out then you have a transmission failure.
Or, start the washer at the beginning of a cycle set to the lowest water level. After the unit fills it should be agitating stop the washer. Open the lid & try moving the agitator, if the agitator will not move it is good & no need to remove for inspection. You have a bad transmission. If the agitator moves easily then we know that the agitator or air bell is stripped out & will need to be inspected for confirmation before replacing.
Hope this helps.
Thanks for using Fixya.
Dec 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Center not turning
Nov 23, 2009 | Kenmore Washing Machines
Agitator single direction only, instead of back and forward.
Oct 27, 2009 | Kenmore Washing Machines
AGITATOR WORKING SLOWER THAN NORMAL. PLEASE HELP. THANK-YOU
Oct 15, 2009 | Kenmore 23822 Top Load Washer
Agitation makes noise ge model wbb4500gww when agitating
Oct 13, 2009 | GE WBSR3140DW Top Load Washer
Performa Washer model PAVT454EWW does not agitate, loud noise comes from near shaft under drum. Spins fine, belt moves fine. Is there a motor (''agitator motor'') other than the main motor that is at front...
Oct 08, 2009 | Maytag Washing Machines
I am unable to remove the agitator from my Kelvinator K605 washin
 Before removing the agitator, unplug the washer to avoid an electrical shock hazard.
The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
read more about the agitator removal in the next comment.
Jan 30, 2009 | Washing Machines
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
22 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
