Go to address on IE type 192.168.1.1, 192.168.0.1 or 192.168.0.50. change sitting on wireless wep security
You will have to login to the router's web utility, go to wireless security settings, and choose either WEP, or WPA. After selecting one of the two you will need to select a passphrase which you will need the next time you connect. I suggest WPA personal, because it offers a stronger encryption method than wep, making it more secure.
SOURCE: How do I make my
there should be a wizard built into your operating system that will let you do that or if you have the little wireless icon on the bar with the start menu double click that and click on the option on the upper left part of the screen that says "setup a wireless network for a home or small office" you should have the option of securing it with a password.
SOURCE: neighbour is using my wireless
my neighbour has set a password on my router how do i reset the router in order to block them , i tried reset from the back of the router but no luck , i also tried to reset from the system but no luck
any advise
