Question about Kenmore Drop-In Bobbin 505S-21BH Mechanical Sewing Machine
Hi why does the machine skip stitch ,or Cather at the bottom ,the problem occur while am sewing.
  • Kenmore Master
  • 7,365 Answers
Check to see if your needle is bent-roll on flat surface to see if it roll good
if the needle make a popping sound when going thru fabric it is blunt
the needle is incorrectly inserted in needle clamp holder
needle & thread not compatable with project
check for warped bobbin
rethread machine
check bobbin area for lint or loose threads
check to make sure thread is not caught on any thing-such as spool pin-notch in spool of thread
Posted on Aug 23, 2010
My machine is skipping stiches it seems its not picking up from the bobbin
Install a brand new needle and confirm it is inserted with the flat side facing the proper direction.. A bent, damaged needle will sometimes cause skipped stitches or even needle strikes inside the machine. A new needle is the least expensive cure for a lot of sewing machine problems. The needle should be changed about every 8 hours of sewing or at least when starting a new project.
Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Sometimes, skipped stitches will occur if the needle, thread, and fabric are incompatible. Be sure to use the correct needle for your project. Use a good quality thread--AVOID old or bargain bin thread!
If the machine continues to skip stitches, then it may be out of time. Search for sewing machine timing or take it for service.
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
Don Ignore Your Sewing Machine Skipping Stitches Simple Solutions
May 24, 2017 | Sewing Machines
Janome 11000 skipped stitches if any are even made at all
Skipped stitches sometimes occur if the machine is incorrectly threaded. Remove the thread and re-thread from the beginning (first RAISE the presser foot so the thread will seat in the tension disk).
Confirm that the thread follows the correct pathway (consult manual).
Try installing a brand-new needle.
Make sure the needle, thread, and fabric are compatible.
All About Needles
If it continues to not pull up the bobbin thread, the needle/hook could be out of time. May require service.
Sewing machine won pick up bobbin thread hook timing fix
Mar 05, 2016 | Janome 11000 Memory Craft Special Edition...
Skipping stitches, already change the needle what else could be?
www.craftsy.com > Blog Home > Quilting Blog
Jan 22, 2014 - Skipped stitches when you'e in the midst of sewing are really aggravating, especially when they occur on highly visible topstitching. But don't ...
Four Tips for Solving Skipped Stitches - YouTube
? 1:49
https://www.youtube.com/watch?v=djJXwsUM8YY
Sep 30, 2013 - Uploaded by How To Sew
Visit www.howtosew.com for more sewing basics and easy p. ...Sewing Machine Repair Interview- Common Problems w/Stitches, Threading, ...
Jan 27, 2016 | Sewing Machines
How do I get it to sew?
was the presser foot lowered? check if the loop-taker is properly installed or seated.
Oct 03, 2015 | Brother XL2600I Sew Advance Sew Affordable...
Sewing machine skipping stitches
If you are using knit fabric and a regular needle, then your machine will skip stitches. Can you give me more details on what you are sewing or trying to sew>
Feb 12, 2015 | Singer 3116 Simple
I think the timing is out on my janome 2039 sewing machine
It is very possible that the timing is off, which often occurs with broken needles. A common symptom is that the needle will not pick up the bobbin thread. Missed stitches aren't necessarily timing related--be sure to install brand needles often and use the correct needle for the fabric & thread you are using. Using the wrong needle will often cause skipped stitches.
10 reasons for skipped stitches
Here What to Do if Your Sewing Machine is Skipping Stitches
You can search for sewing machine timing or take it for service.
Apr 12, 2017 | Janome Harmony 2039 Mechanical Sewing...
Sewing maching making randon loops bottom stitching
Sounds like you are getting some skipped stitches. Have you tried changing your needle? You may want to make sure you are using a ball point, those help alot with skipped stitches.
Dec 15, 2008 | Kenmore 15516 Mechanical Sewing Machine
Kenmore Drop-In Bobbin 505S-21BH Mechanical Sewing Machine Logo
63 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
