Mitsubishi DLP overheating
I have a MItsubishe DLP model WD-62927 and during the last 2 weeks a massage comes on the screen that TV will shut down soon to check ventilation. There is no blockage to ventilation and TV does turn off, LED turns amber and remains that way for approximately 15 minutes, after that TV will turn on again
  • Msimons12 Jun 03, 2008
    I have a 61 inch Mitsubishi diamond series DLP and I have the same problem. I had one lamp that burnt out, and after just a few months I am getting the overheating messages again and expect the new lamp to burn out soon.
  • kyrish Sep 04, 2008
    same problem - same model... is there a do-it-yourself guide to changing the filtration?
I have a 65" mitsubishi and have been battleing the same problem for about 6 months I did the canned air thing and I eventually found a useful sollution on you tube if you take the back of the tv off clean the two fans with a qtip then take the intake fan housing out there is a third fan behind it now when I say housing I mean the whole black shraud out there's a little fan that points at the bulb two screws and its out use canned air and qtips to clean it and also clean the port leading to the bulb it has worked so far and I'm sure I will have to clean it more often now that I know its there good luck
Posted on Aug 03, 2012
    Novelist:
    Champion:
  • 236 Answers
Check your air intake filters, it's a removeable filter in the air inlets.
Posted on May 04, 2008
Hi, I have a Mitsubishi wd-57733 dlp tv that shuts down
Ballast is possible if repeated lamp failure but I have a solution I posted several times for this type of problem that works and is simple to try:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
Apr 30, 2012 | Mitsubishi WD-57733 57" HDTV
When you turn the TV on it stops at the blue Mitsubishi screen and the power button just blinks. You have to then unplug the TV to power down. Pushing the power button on the TV or remote will not power...
There is a software update that is available for some Mitsubishi dlp models. The wd-65c9 is one of them. When I experienced your problem, I went to the website, downloaded the update, and installed it on my tv and boom, its fixed. It's super easy, free, and takes a few minutes.
Jan 31, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
I have a mitsubishi the model number is wd-82837 it keep shut down after blue screen show
Ur tv"LAMP"LED light indication flashes or stay on?Ur tv projection lamp been inside this tv like a 1 1/2 or 2 years and tv been on an in used like 4 or 5 hours every day.Yes to all of this,than the tv projection lamp is the causes and it life are ending.The tv projection lamp require replacing.
Dec 09, 2010 | Mitsubishi WD-82837 82 in. HDTV DLP TV
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi has problems with the thermal sensor going bad. They extended the warranty for several sets. The sensor is right by the lamp. Call mitsubishi and insist they do something for you. If you keep playing your set, the bulb could also be at risk. I would think your set is covered being a 62" set. Good-luck and be sure to act ASAP.
Dec 07, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Status light stays on
I have a 52inch mitsubishi dlp model ws-52725,I turn on the tv and the green light is plinking I have this befor and had to replace the module at a coat of 600.00 that was 2 years ago .I have done all the necessary steps,light still plinking.what do I have to do now ?My last mitsubishi I had for 15 years with no problem.Its mitsubishi going down hill. Thank you PS there any help any where ?
l#wd52725
Nov 22, 2008 | Mitsubishi WD-52725 52". Rear Projection...
DLP Projection tv, Models WD-52631,57731,65731. The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv...
DLP Projection tv, Models WD-57731, The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv system shuts down. I reset it a few times but that doesn't change the problem
Jul 26, 2008 | Televison & Video
2yr old DLP TV flashes for few mins then has red tinge
Push the menu button when the problem shows up again. Please tell me if the flashes show up in the displays as well on the menus. I can take it from there.
Apr 15, 2008 | Mitsubishi WD-62927 62" HDTV
Televison & Video Logo
660 people viewed this question
Top Televison & Video Experts
