Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
The heating element on my DGB500 BK automatic Grind & Brew coffee maker stoped heating this morning. Can I get it repaired. The unit is 5 or 6 years old.
  • 10,515 Answers
If you have a meter you can check to see if you are getting power to the heating element in the coffee pot. If the element does not heat the water will not go through.
It could be repaired.If you wish you could contact them at :-
http://www.cuisinart.com/support/us.html
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 22, 2010
Filter lid spins properly, brew lights are on; but it won't brew coffee.....please help
How to Repair a Cuisinart Coffee Maker - Java Jenius
www.javajenius.com > How-To
How can I flush it if it won't brew at all? ..... The filter basket is in the proper position for the coffee to enter the filter but the ... I have a regular cuisinart coffee maker for12 cups (no grinder). ... I have the Cuisinart automatic grind and brew, model DCC490SA. .... The pot brewed a good cup of coffee but as of now it is useless.
Jan 21, 2016 | Cuisinart DCC-790PC 12-cup Grind & Brew...
My cuisinart automatic grind and brewthermal shuts off every minute or so it douse not brew strate through.
HI,
• Remove the hopper from the unit
• Lift coffee channel cover
• Clean out coffee chute
• Replace channel cover and hopper
• Your coffeemaker is now ready to brew again
Oct 06, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
Krups grind & brew. It grinds but water
Check to see if your heating plate gets hot when it is on, if it doesn't your water heater/heating pklate has failed.
Nov 20, 2009 | Krups Coffee Makers & Espresso Machines
Coffee maker with grinder--sometimes, when percolating, it overflows
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
Jun 28, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Cusinart 12 cup grind and brew overflows with grinds and water
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Note: Some coffee makers define as little as 5 oz as a cup.
Apr 02, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
I Have a Cuisinart Automatic Grind & Brew Thermal that when you start brews a small amount of coffee and then shuts off. I shut off grind and start. After I do that it brews a full pot. We have cleaned...
I have a cuisinart model dgb-600bc coffee grind & brew, didn't have a manual with it when purchased, plugged in it & hit the on button, lights up when pushing in on it, but let it go & it stops, but doesn't brew nothing. HELP -
Aug 26, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a dgb600bc grind and brew. It will initially grind and brew the coffee hot, but as soon as the brewing is done the heating element shuts off causing the coffe to slowly get cold.
When the cycle is finished, the coffeemaker will beep 5 times, indicating that the coffee is ready. The unit will turn off automatically.
The insulated carafe keeps the coffee warm for four hours. The aroma of the coffee is preserved thanks to the hermatic cover. It is not necessary to remove the cover to pour coffee.
Hope this will help you.
/Mirran
Jul 24, 2008 | Cuisinart DGB-600 Coffee Maker
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
73 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
