Question about Lakewood (r) Industrial Drum Fan (MC-24)
II have an Industrial fan made by Lakewood I believe the blade is 41" and the motor is a 1hp motor. I mistakenly turned it while it was running and the blade hit the shaft on the motor. Now in order to get it running I have to replace the motor and blade. Does anyone know where I can find replacement parts? I have been looking online for lakewood replacements and don't find what I need. Thank you for the help. signed OUT "$600.00.lol
4 Suggested Answers
  • 38 Answers
SOURCE: lakewood box fan 3 speed switch wiring schmatic
What I did was (but be VERY VERY carefull) is have the fan plugged in, and check which wires give which speed when you touch the main wire. VERY carefull. I'm not liable for any harm done to you or your fan.
Posted on May 09, 2009
  • 91 Answers
SOURCE: does the lakewood fan have a fuse that can be
No, it is either the speed control, capacitor or motor. You can get parts, if it worth your time, try nelsonappliance.com and part # LW007JRMOTOR
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Posted on Aug 26, 2009
mcdevito75
  • 1970 Answers
SOURCE: are replacement motors available for these fans?
mcdevito75 here, If the fan is not too old I would figure yes, but a replacement motor will cost as a new fan, if not more, then you have to install and the blades are a presss fit to the motor.
Posted on Jul 28, 2010
Troubleshooting lakewood fan model hv 18
This one the best brands on the market that I have ever owned.
If the fan motor will not turn on or hums and/or turns slowly more than likely its a lubrication problem.
1. Unplug the fan from the wall remove the 516 screws to the cage
2. Try turning the fan blade by hand if it is tough to turn more than likely it's a lubrication problem
3. You will have two oil holes one in the front one in the back spray WD-40 into these holes, turn the fan blade if it starts to free it up apply more WD-40 and keep turning the blade add more WD-40 until the blade turns freely. Especially in the rear oil hole because this is an oiled bushing that you are adding oil to. Once the fan is turning freely replace the front cage with all the screws plug the fan and I hope this solves your problem. You may add 3 in 1 oil or some other very light lubricating oil periodically.
I hope this solves your problem Mike
Mar 03, 2012 | Lakewood HV 18-c Floor / Box Fan
Are replacement motors available for these fans? Lakewood HV 18 Lakewood HV 21 Lakewood HV 21T
Jul 27, 2010 | Lakewood HV-18 Floor / Box Fan
I need a replacement motor, 60 HZ 2.7 amp, for a Lakewood fan Model HV-217SPC
GRAINGER.COM ... .GOOD LUCK AND I'FN I WAS ANY HELP PRAISE IS APPRECIATED .. SO VOTE JAY MOTORWIZJ
May 28, 2010 | Lakewood MC-42 Fan
Does the lakewood fan have a fuse that can be replaced?
Aug 26, 2009 | Lakewood HV 18-c Floor / Box Fan
How to lubricate my Lakewood window fan?
It's probably not a good idea to lubricate your fan, as a wet lubricant will cause dirt to bind to moving parts in the motor which will in turn act as an abrasive causing the motor to prematurly fail.
The fan it's self should be sealed at the factory and provide years of mantenance free use.
Jul 29, 2009 | Lakewood Dryers
Light works, fan does not. Fan motor has low hum but blades don't turn
How old is this? The motor has failed windings and carries a pretty long warranty I believe 25 years was the norm? eric
Jul 02, 2009 | Hampton Bay 52 In.Carriage House II in...
Can here motor running but blades do not turn
go and take it apart and clean it afterwards. dont forget to put oil. you might want to check the carbon inside the motor, they may need replacement.
Mar 18, 2008 | Lakewood HV 18-c Floor / Box Fan
Lakewood floor fan
most likley the set screw that secures the blade to the motor is loose.
Jun 09, 2007 | Lakewood HV9 Floor / Box Fan
Lakewood 200I Floor / Box Fan
Probably requires cleaning- take the grille off, pull the blade free (most pull straight out- some have a pin/socket deal right behind the blades that need to be removed first) and clean out any gunk you may find inside. Be sure to unplug it first. before replacing the blade, turn the shaft with your hands to see how it moves; you might want to grease it with an electricity friendly lube of your choice. If it's still hard to turn, it may just be this fans time; box fans are cheap, and made cheap, and the wear-and-tear adds up.
May 23, 2007 | Lakewood 200I Floor / Box Fan
Fan Blade Wobble or Part of the Design?
The problem you are getting is due to a warped fan blade, assembly of motor, or unbalanced spin radius. Your best bet on this is to seek a replacement from your manufacturer, as this is likely a fault of the assembly process, or even of manufacturing the fan blade set anyway. While the problem is not a major one, and you will be just fine using said fan for some time, it will shorten the life of the motor, which will eventually run dead due to extra stress. To prevent excess wear and tear, run the fan at a slightly lower speed, i.e. on 2, maybe even 1. At higher speeds, the centripetal force will cause the blades to warp further, and pull the motor back and forth, and thus, cause the unit further damage.
Jan 11, 2007 | Lakewood R12-DSK Table Fan
Dryers Logo
69 people viewed this question
Top Lakewood Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
