Question about V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series
Wires were pulled off ignition switch, donot remember wire locations
Factory alarm wont turn off on a 2001 Chevrolet monte Carlo. Making honk go off till it drains battery.
Try shutting it off with the door key . Lock and unlock the drivers door with it.
Nov 06, 2014 | 2001 Chevrolet Monte Carlo
Driver window donot go up or down
Check all fuses first then pull switch and test for power at window switch. If power getting to switch, test wires going to window motor. 2 wires to motor, and depending on what way switch is pushed determines which wire will have power. Switch just reverses polarity to raise and lower, so one or the other wire should show 12 volt DC power when switch pushed. If power going to motor, double check you have good ground as well, and if so, motor is shot. You can also double check motor by connecting wires from motor to a 12-14volt cordless drill battery.
Dec 27, 2013 | 1996 Plymouth Voyager
Jvc kd bt11
hi vicki, firstly check out the power wiring to your unit. yellow wire to the battery +12v(direct live) and the red one to the ignition switch(vehicle start switched live). also try resetting your unit. if all these donot work then check out your local installer before handing the unit in for repairs. good luck. cheers.
Sep 06, 2013 | Car Audio & Video
I replaced the ignition switch in my 1995 ford ranger now the alarm won't stop
95 Ford Ranger Auto Alarm Wiring Diagram.
You need to re-check your ignition wiring. Here is the wiring for the alarm.
Battery Constant 12v+ Positive Wire (+): Yellow
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Red/Light Blue
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Light Green/Purple
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Black/Light Green
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Gray/Yellow
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): White/Black Or Brown
Parking Light Positive Wire Location: At Headlight Switch Or Low In Drivers Kick Panel
Power Door Lock Negative Wire (-): Pink/Yellow (Type B)
Power Door Lock Negative Wire Location: In Either Kick Panel
Power Door Unlock Negative Wire (-): Pink/Light Green (Type B)
Power Door Unlock Negative Wire Location: In Either Kick Panel
Door Trigger Positive Wire (+): Black/Light Blue
Door Trigger Positive Wire Location: In Drivers Kick Panel
Domelight Supervision Wire: Use Door Trigger (Requires Relay)
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Yellow/Light Green
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Any Wire With A Tan Stripe Or A Yellow Stripe
Tachometer Wire Negative Wire Location: At Ignition Coil
Brake Light Positive Wire (+): Light Green
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): Dark Green/Purple
Factory Alarm Disarm Wire Location: Low In Drivers Kick Panel
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Nov 16, 2011 | 1995 Ford Ranger Supercab
I need to disable my alarm on a 1997 bmw 528i.
Now im not sure since the manual says your model has the same alarm system as the 328i and on the 328i you can remove the module to disable by doing the following. you can unplug the control module. It is located under the glove box. Climb under the dash on the passenger side and remove a few screws on the trim panel under the glove box. Theres a black control module with a green connector. There should be a lock tab on the connector. press the lock tab and pull out the connector. The alarm should now be disabled. But if it has the special transponder key this may not work.
But if the only reason you want to disable it is because of the motion sensor setting of the alarm for no reason there is a solution for this. To disable the motion sensor, hit the lock button to arm, then hit lock button again within four seconds to disable motion sensor. Red light on rearview mirror should flash four times, then pause, then start flashing on regular intervals. this is most likely the reason if your having the issue where the alarm goes off every 20 minutes.
If you want to completely remove it below is a wiring diagram taken from the manual for you alarm system.
this is from the manual its the alarm wiring diagram.
Battery Constant 12v Positive Wire ( ): Red/White or RedBattery Constant 12v Positive Wire Location: Ignition Switch Harness
Starter Positive Wire ( ): Black/Yellow or Black
Ignition Positive Wire ( ): Green
Second Ignition Positive Wire ( ): Purple/White or Purple
Parking Light Positive Wire ( ): Gray/Purple and Gray/Yellow. Use Both Wires. This vehicle has a dual parking light system that will require 2 extra relays.
Power Door Lock Positive Wire ( ): White/Red
Power Door Lock Positive Wire Location: At Factory Alarm Plug. The alarm plug is a black 12 pin plug located just behind the glove box.
Power Door Unlock Positive Wire ( ): Blue/Red
Power Door Unlock Positive Wire Location: At Factory Alarm Plug. The alarm plug is a black 12 pin plug located just behind the glove box.
Door Trigger Negative Wire (-): Brown/Gray
Door Trigger Negative Wire Location: At Factory Alarm Plug. The alarm plug is a black 12 pin plug located just behind the glove box.
Domelight Supervision Wire: Turns On With Unlock
Horn Negative Wire (-): Brown/Red or Brown/Yellow
Tachometer Wire Negative Wire (-): Black
Tachometer Wire Negative Wire Location: At Instrument Cluster
Brake Light Positive Wire ( ): Blue/Red or Green/Red
Factory Alarm Disarm Wire (-): Disarms With Factory Remote Only. Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: Transponder Anti-Theft System, Requires Bypass And Extra Ignition Key. The 1997 model year vehicle may require a bypass module and an extra ignition key, if vehicle is equipped with a special key from BMW.
Factory Anti-Theft System Location: Transponder At Ignition Switch Tumbler
if you require further assistance please let me know and i will help assist you from there. Thanks, Midwest-Tek
Aug 27, 2010 | 1997 BMW 328
How do i wire in a alarm on my 97 suburban K1500 i need a wiring diagram to find wire colors for windows lights and etc........
1997 Chevrolet Suburban Car Alarm Wiring Instructions
Battery Constant 12v+ Positive Wire (+): Red
Starter Positive Wire (+): Purple or Yellow
Ignition Positive Wire (+): Pink
Second Ignition Positive Wire (+): Pink/White Or White (This wire must be connected as ignition #2 for remote starting.)
Accessory Positive Wire (+): Orange
Parking Light Positive Wire (+): Brown
Parking Light Positive Wire Location: At Headlight Switch Or In Drivers Kick Panel
Power Door Lock Negative Wire (-): Light Blue (Type A)
Power Door Lock Negative Wire Location: In Either Door Harness
Power Door Unlock Negative Wire (-): White (Type A)
Power Door Unlock Negative Wire Location: In Either Door Harness
Door Trigger Negative Wire (-): Purple
Door Trigger Negative Wire Location: At Headlight Switch
Domelight Supervision Wire: White (-), Requires Relay
Domelight Supervision Wire Location: At Headlight Switch
Trunk Release Negative Wire (-): Black (+) Or Black/White (Requires Relay)
Trunk Release Negative Wire Location: At Hatch Release Switch Or Low In Drivers Kick Panel
Horn Negative Wire (-): Black
Tachometer Wire Negative Wire (-): White
Tachometer Wire Negative Wire Location: At ECM. The ECM (electronic control module) is located on the driver side inner fender.
Wait To Start Wire: When hooking up a remote starter on a diesel, you will need to program in the 5, 10 or 15 second wait to start timer in the installation manual. On some vehicles the wait to start light on the dash is not a true (+) positive or (-) negative and the wire from the remote starter will not work.
Wait To Start Location:
Brake Light Positive Wire (+): White
Factory Alarm Disarm Wire (-): N/A
Mar 31, 2010 | Brand Remote Start/keyless/car Alarm Very...
Need to know how to hot wire ignition.what color wires do i use?
1991 Ford F150
Vehicle Battery Positive Wire (+): Yellow
Vehicle Battery Positive Wire Location: Ignition Switch Harness
Vehicle Ignition Wire (+): Red/Light Green
Vehicle Ignition Wire Location: Ignition Switch Harness
Vehicle Second Ignition Wire (+): N/A
Vehicle Second Ignition Wire Location: N/A
Vehicle Accessory Wire (+): Gray/Yellow
Vehicle Accessory Wire Location: Ignition Switch Harness
Vehicle Second Accessory Wire (+): N/A
Vehicle Second Accessory Wire Location: N/A
Automobile Engine Starter Wire (+): Red/Light Blue
Automobile Engine Starter Wire Location: Ignition Switch Harness
Automobile Second Engine Starter Wire (-): N/A
Automobile Second Engine Starter Wire Location: N/A
Factory Anti-Theft System: None
Factory Anti-Theft System Type: None
Car Key Sense Wire (-): Black/Pink
Car Key Sense Wire Location: At Steering Column Harness
Car Neutral Safety Wire (+): N/A
Car Neutral Safety Wire Location: N/A
Car Tachometer Wire (-): Tan/Yellow
Car Tachometer Wire Location: At Ignition Switch Control Module in Driver Fender Well
Car Speed Sense Wire: Gray/Black
Car Speed Sense Wire Location: Pin #3 at PCM Mounted on the Firewall
Car Parking Lights Wire (+): Brown
Car Parking Lights Wire Location: At Headlight Switch or Driver Side Kick Panel
Car Brake Lights Wire (+): Green
Car Brake Lights Wire Location: At Brake Switch Above the Pedal
Car Reverse Lights Wire (+): Black/Pink
Car Reverse Lights Wire Location: At Switch on Transmission
Car Horn Wire (-): Blue
Car Horn Wire Location: At Steering Column Harness
Sorry friend, this is as far as i can go to tel you how to hot wire the ignition. But with the color codes you should be able to figure it out, Good luck and keep me posted.
Jan 23, 2010 | 1991 Ford F150
What color is the power wire in 1994 toyota pick up
this might help
1994 Toyota Pickup Car Security Wiring Diagram
Battery Constant 12v+ Positive Wire (+): White And White/Red
Starter Positive Wire (+): Black
Ignition Positive Wire (+): Black/Yellow
Second Ignition Positive Wire (+): Black/Yellow Or Black/Red
Accessory Positive Wire (+): Blue/Red
Parking Light Negative Wire (-): Red/Black
Parking Light Negative Wire Location: At Steering Column Harness
Parking Light Positive Wire (+): Green
Parking Light Positive Wire Location: In Drivers Kick Panel
Power Door Lock Negative Wire (-): Blue/White
Power Door Lock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Power Door Unlock Negative Wire (-): Blue/Yellow
Power Door Unlock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Door Trigger Negative Wire (-): Black/White Or Black
Door Trigger Negative Wire Location: At 2-Pin Plug, Top Of Fusebox
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Horn Negative Wire (-): Green/Red
Tachometer Wire Negative Wire Location: At Diagnostic Connector. The diagnostic connector, is located on the passenger inner fender near the fuse/relay box.
Brake Light Positive Wire (+): Green/White
Nov 29, 2009 | 1994 Toyota Pickup
HORN DIAGRAM FOR A DODGE RAM 1500 (CONNECTIONS)
Battery Constant 12v+ Positive Wire (+): Black/Orange And Red/White
Starter Positive Wire (+): Yellow
Ignition Positive Wire (+): Blue (16 Gauge)
Second Ignition Positive Wire (+): Yellow/Red
Accessory Positive Wire (+): Blue (10 Gauge)
Second Accessory Positive Wire (+): Orange
Second Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Black/Yellow
Power Door Lock Positive Wire (+): Orange/Violet
Power Door Lock Positive Wire Location: In Drivers Kick Panel, White 6-Pin
Power Door Unlock Positive Wire (+): Pink/Violet
Power Door Unlock Positive Wire Location: In Drivers Kick Panel, White 12-Pin
Door Trigger Negative Wire (-): Yellow
Horn Negative Wire (-): Black/Red
Tachometer Wire Negative Wire (-): Gray
Tachometer Wire Negative Wire Location: At PCM, Connector 1, Pin A7. The PCM (powertrain control module) is located on the firewall next to the wiper motor.
Brake Light Positive Wire (+): White/Tan
Factory Alarm Disarm Wire (-): Black/Orange (To disarm requires a (-) negative through a 1565 ohm resistor and an extra relay to connect.)
Factory Alarm Disarm Wire Location: In Drivers Kick Panel, White 12 Pin Plug
Aug 22, 2009 | 1998 Dodge Ram 3500 2WD
Need brake circuit diagram for 1991 chrysler new yorker
1991 Chrysler New Yorker Auto Security Wiring Diagram
Battery Constant 12v+ Positive Wire (+): Red and Pink
Ignition Positive Wire (+): Dark Blue
Accessory Positive Wire (+): Black/Orange
Power Door Lock Positive Wire (+): Orange/White Or Orange/Violet
Door Trigger Negative Wire Location: In Drivers Kick Panel
Dome light Supervision Wire: Use Door Trigger (Requires Relay)
Dome light Supervision Wire Location: N/A
Trunk Release Positive Wire (+): Black/White (Requires Relay)
Trunk Release Positive Wire Location: At Trunk Release Switch
Horn Negative Wire Location: At Relay In Fuse box
Tachometer Wire Negative Wire (-): Black/Gray
Brake Light Positive Wire Location: At Switch above Brake Pedal
Factory Alarm Disarm Wire (-): Light Green/Orange
Thank You for contacting Fixya.com
Aug 03, 2009 | 1991 Chrysler New Yorker
V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series Logo
Top Honda Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Spud Howell
Mike Carew
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
