My SPL 616X Staples Shredder will not work. The red light Overheat is ON. Any suggestions? Thanks Carter Hoppe
SOURCE: staples spl-710sh paper shredder stopped shredding
This exact thing has happened to my unit as well. Ive disassembled it to discover that 5-7 teeth on the gear that the motor drives have been stripped off. Unless the gear can be replaced (which is probably not worth the expense), then the unit is toast. Sorry. Good luck.
Posted on Nov 01, 2009
SOURCE: staples SPL-770M shredder with overheat light even when cool
Just a FYI: I had the same problem. Nothing appeared jammed. But I took the housing cover off and low and behold the rubber roller that turns the shredders had MELTED to the inside. That's why it wouldn't work. This happened while shredding a single DVD - something I had done effortlessly on numerous occasions. You may want to check to see if the roller melted or if some debris has jammed up inside the unit, like mine did often.
Posted on Jan 08, 2010
SOURCE: Drive gear for staples shredder Model# SPL-770M is worn
is it the drive gear or is it that the shreader is dull that makes the shreader sluggish?
Posted on Jun 23, 2010
  • 10865 Answers
SOURCE: Each time I use my staples SPL-616X shredder all
Yes you do need to oil the blades, but it is important to get the right oil. Most stores that sell shredders, like Staples Office Supply, also sell shredder oil. J.
Posted on Aug 01, 2010
SOURCE: I need to replace the plastic guides in a Staples
did you ever figure out where to get these guides? i need them too. jeff
Posted on Nov 16, 2010
I have a Staples Shredder model SPL-TXC6A (serial 0809026807), which I have been using a lot lately. The auto and reverse buttons will not function, & neither will the forward button.
If you have used it a lot, it may have tripped the thermal fuse. Normally, these reset themselves. One thing to make sure of,, is that the safety switch under the machine is firmly on the pin in the basket under it.
This is a light duty shredder, you can only use it for two minutes!
6-sheet, light-duty, up to 25 uses/day
Runs 2 min on / 4 min off
http://www.snoopdeal.com/bargain/43085/Staples-SPL-TXC6A
Nov 21, 2016 | Office Equipment & Supplies
Gears not working. paper stuck in blades. how do I remove the casing for a Staples 616X shredder?
There are 6 holes on the underside of the shredder, corresponding to 6 screws that have to be unscrewed. One of the 6 has a gray round QC seal over it which you must break in order to access that last screw (in the center of the unit). The idea is that if you have broken this seal, then you've voided your warranty.
Feb 25, 2011 | Staples SPL616X Cross-Cut Shredder
HI,I NEED PARTS FOR MY SHREDDER SPL-616X. GEAR WHEEL WERE TO GET PARTS
i have the gears - my shredder has broken plastic guides but the gears look fine. i'll mail them to you if you like. Jeff
Aug 22, 2010 | Staples SPL616X Cross-Cut Shredder
Each time I use my staples SPL-616X shredder all the paper gets stuck around the blades what can I do? Do I need to put some oil on the blades?
Aug 01, 2010 | Staples SPL616X Cross-Cut Shredder
Jul 22, 2010 | Staples SPL616X Cross-Cut Shredder
Staples SPL-770M shredder with overheat light even when cool
Sep 10, 2009 | Office Equipment & Supplies
SPL 1506X Shredder
Have you looked for hidden staples in the machine. Sometimes they can be hard to spot.
Aug 01, 2008 | Office Depot Ativa DQ60M Shredder
485 people viewed this question
k24674
jasbo
jasbo
