Question about Briggs & Stratton Garden
I have a briggs 11 hpvertical shaft engine and had it overhauled by local mech. it runs grate but sounds like marbels in it. Could the mechanic have improperly installed the balancsing rd or other improperly. compression is good..
  • 472 Answers
S OUNDS LIKE THE CONECTEN ROD IS LOOSE
Posted on Aug 22, 2010
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
Will engine valve make 'marbels in a can noise'in
Interesting. There are several things which can make that sound. Oddly enough, some Automakers use pellets in the Catalytic converter and when they lose the partitions inside the converter they tend to rattle like that. Another related area is the shields on the Catalytic converters. Sometimes the welds break and the shields flap against the pipes. Third, if you travel gravel roads the stones kick up get inside the shields and rattle.
Moving forward you have the A/C clutch bearings which can make that sound before they altogether cut loose.
Transmission Torque converters on automatics make that sound very close to failing. As long as the engine is running it does not have to be i gear.
But an individual valve in an engine will not make that sound. A broken sparkplug tip could make a noise but you would have a missfire.
There are roller bearing pulleys on the pulley system for the Serpetine belt. Any of these devices could make noise. Besides the A/C compressor, your Alternator and even your Power steering pump can
make noise.
Please rate my info.
Jan 16, 2013 | Cars & Trucks
I have a 25 hp ohv briggs and stratton, it will not run without having to choke it some
Try increasing the idol by turning the idle screw up.If that doesn't work the carburetor may need to be reset properly or it might need an overhaul.
Mar 09, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Van Guard 16 hp D.C. Chipper with Gravity Flow. With fuel switch on and starting engine four minutes, white smoke apprears and increases gradually, then heavier and chokes itself...
Sounds like your carb is flooding. Inside the carb, there is a simple valve that shuts off the fuel flow when the fuel bowl is full. If this valve fails, or if the float sinks, then too much fuel is forced into the cylinder and will wash past the rings and into the crankcase. This causes the engine to run very rich. You need to remove, clean and overhaul the carb, and change the oil and sparkplug and probably the air filter too. Find the model, type, and code numbers on the engine and go to www.partstree.com , www.ordertree.com , or your local repair shop to get the needed carb overhaul kit. Some B&S engines have an option of carbs, so look for a name on the carb itself...probably Nikki or Walbro. The carb kit is not very difficult to install, but make sure to get everything very clean before reassembly.
Good luck.
Sep 24, 2010 | Briggs & Stratton Chipper Shredder Patriot...
I have a sears craftsman tractor,18 hp electric start. No. 917.254860. engine no. 422707,type no. 1522.01. briggs and stratton. engine won,t turn over. Replaced plugs,coil,carborator rebuilt to specs. New...
From your description it seems that the starter is not engaging to turn over the engine. First ensure all the connections of the thicker cables to the battery, starter and tractor frame are clean and tight. If starter motor is turning but still not engaging it will mean that the pinion on the starter motor is binding on the shaft. You can buy a new starter pinion gear from your local B & S agent.
To replace pinion, remove starter motor from engine, remove old pinion and put on new one and reattach starter to engine. If fuel & spark are right you should be up amd running.
Sep 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs stratton,16 H>P> runs smooth 'til mower is engaged.
Is the choke staying on perhaps? check spark and plug check airflow, get compression test maybe the oil/compression rings giving way... sounds like its getting hot and increasing fuel flow for some reason??? perhaps clean carb with some cleaner while running (remove air cleaner) spray directly into carby while running run at full throttle as you spray it will try and die ... relax on the spraying and see how it goes.. check air cleaner for blockages as the same time :) hope you get it working!
May 04, 2017 | Briggs & Stratton Briggs Stratton Vanguard...
I have a Murray snowthrower Pro series 27'' 10.0 HP. After 1 hr of grating noise (like bearing) it stopped throwing.
So many things,
You need to have someone with eyes on for this one.
As it could also be a catastrophic problem.
This engine also has a history of bending push rods.
Hope this tips helps.
r/
David
Dec 26, 2009 | Briggs & Stratton Briggs Stratton Intek V...
18hp B&S wont slow down no matter where
It's one of two things. Most likely, the screw(s) have come out of the butterfly valve on the throttle shaft and letting it run wide open. The second thing is that the governor gear inside the engine broke. Unless you a pretty good mechanic, I'd recommend taking it to a shop. If it is just the butterfly in the carb, you still have to deal with...where did the screws go? They may have passed through the intake and exhaust valves or they may be stuck in one of the valve seats or embedded in the piston. Like I said, better take it to a trusted shop, if there is such a thing, unless you live close to me. lol.
Jun 25, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
21 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
