Question about Kenmore Elite 900 sq. in. Cooking Area Gas Grill 16690\17690
The first two burners on the left light and have good gas flow. When I light the middle and the left two burners the flames flicker and go out, like there is not enough gas. I cleaned the burners, tried two different tanks and it still is not lighting. This just recently started happening.
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on Sep 05, 2010
OSAKA 43-530 , Error 55 and middle green light flases in left pannel
If the gas lights & doesn't stay on, then there is a flame sensing issue. Remote sensor may have flame impingement (dirty). Clean flame rod sensor with light sandpaper or cloth.
Jan 06, 2014 | Weather King 12AJA4801AH Air Conditioner
Gas flow burner
try adjusting the gas/ air ratio shield. that is the tin collar over the opening where the gas jet is . moving it back or forward varies the amount of air available for the mixture and alters the flame height. and colour.
May 27, 2013 | Weber Genesis Silver B Grill
No flame touching thermocouple
There must be a blockage on the inner flame ring as the gas is not getting to the thermocouple .
Apr 21, 2017 | Gaggenau 11 in. VG 232 Gas Cooktop
I have a rinnai LPG 6 burner gas heater, it starts fine but wont ignite the middle left burner. It has a blue flame over the top that occasionally radiates down the burner. All the other 5 burners work...
sounds like the injector hole is too largefor that burner have you had it converted reciently
lpg injectors are only half the size hole of natural gas injector, could have a blockage in the injector diverting the gas flow
Jun 09, 2011 | Rinnai Heating & Cooling
Lighting pilot light
Pilot assembly is located inside the bottom compartment, between the the two middle burners while the gas valve is located under the burner manifold. Make sure that the gas line where the unit is connected is open. You need to turn the gas valve knob to "Pilot" position and depress it (to allow the gas to flow on pilot) then light the pilot assembly using a lighter with extended nozzle ( burner igniter). Once the flame is present at the pilot assembly, wait for about 15 seconds (allowing thermopile to heat up) the gradually release the gas valve knob. If the pilot flame is stable, turn the gas valve knob to "ON" position and set the thermostat to desired temperature setting. This will ignite the burners and heat up the oil to set temperature. Just remember, do not do this if there is no oil on fry tank.
Feb 18, 2011 | Pitco Frialator 35CS Deep Fryer
Frigidaire professional series gas stove does not light. When handle is turned the "clicking" sound happens, with the smell of gas but no flame. what could be problem? 3 other burners work...
A few months ago I lost one igniter on the left front burner. It clicks and gas flows but wont ignite.Now when I turn on the left back burner, the gas still flows but I hear clicking on the right side, not from that burner. It wont light either.
Dec 17, 2010 | Frigidaire FEF336BC Electric Kitchen Range
When I turn the on the first burner will light and flame are OK, but lighting the next burner the flame goes down to a point that you can barely see the flame. It appears that the gas get reduce to have a...
sounds to me like your other burner isn't getting the same amount of gas flow. what you need to do is give your grille a good cleaning and check the lines for any leaks. you will always smell gas so it will be hard to tell by smell alone. Test your lines by wrapping them tight with foil or something removable and turn your grille on to see if the flame gets bigger.
Oct 04, 2010 | Grilling
Burner won't turn on
The first question I have is the flame size good on the 2 burners that did light? If the flames are smaller, then you might just need to turn off the tank and disconnect it, then reconnect it and very slowly turn the tank valve on again. You might have turned the tank valve on too fast causing the excess flow valve to close and only give a trickle of gas through. On the other hand, if the flame size was good on both burners, then your igniter may not be lighting the rear burner, but typically if the other 2 burners light, the 3rd burners lights off the others. Did you try lighting the 3rd burner manually with a lighter to see if it was getting gas? If it lights manually, then the spark igniter may be your problem. It's also possible the rear burner has clogged holes from rust or drippings and is difficult to light. Without seeing it, it's just the process of elimination til it works. Try all those things and see if that gets it going for you. Check out my tips & tricks on gas grill lighting for more detailed info. Click on my user name and scroll down til you find it listed on my profile. Good luck. Douglas
May 15, 2010 | Weber Genesis Silver A Grill
I have a Kenmore 4 burner grill that I purchased about 3-4 weeks ago. 3 of the 4 burners have nice blue flames and work very well but the left middle burner gets a huge yellow flame no matter what temp it...
does the same burner flame turn blue if other burners decreast in flow-with that burner on high and others low-is it still yellow? if so Gas Valve needs to be replaced.
Oct 05, 2009 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Glas flow will almost shut down once i turn on the second burner
hi my name is mark, let me see if i understand your problem. you light the 1st burner and get a good flame. you light the 2nd burner with the 1st burner lite and it starves both burners of gas. if this grill is a lp grill and you have propane in the tank. the regulater is the problem.
Feb 22, 2009 | Kenmore 16228 Grill
Kenmore Elite 900 sq. in. Cooking Area Gas Grill 16690\17690 Logo
132 people viewed this question
Top Kenmore Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
