Question about Whirlpool Microwave Ovens
Whirlpool microwave oven model; MH7130XEZ-1 (built Jan 1998). My microwave is totally blank. Verified that I have power to the unit, but no display or no fuctions operate. Is there a power fuse internally that might have blown? or is it likely that the circuit board has fried?
SOURCE: Whirlpool microwave/oven model RM286PXV3
I have a 13yr old above-range oven which quit when my wife cooked food in an aluminized foil wrapper (a small fire ensued!). This oven has 3 thermal protection units, on the magnetron, the chassis and on top of the food cavity. This last one had failed open, and since it's in series with the magnetron thermal protection unit and the main relay, nothing would work. MAT electronics sell the units for less than $4, but my problem now is to pick one with the appropriate temperature cut-off. They range from 200 to 300F.
Posted on Nov 18, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: Whirlpool Microwave Model MH7130XEZ-2
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Oct 22, 2007
hiltonjug
  • 612 Answers
SOURCE: GE model JE2160BF03 no power. Blown fuse.
They are put out when something metal is put inside and cooked for a few min. They are also put out with power surge. It protects your mag tube. Plus they just go bad sometimes. Could be a number of reasons but these are the most common.
Posted on Nov 17, 2009
SOURCE: Model JE2160WF Microwave Power up for second
I have the same problem, plug is fine...Did you get yours to work??
Posted on Nov 26, 2009
  • 119 Answers
SOURCE: No power to Panasonic NN-S252 microwave oven
follow the incoming mains lead into the microwave their is a small pcb with a fuse their check this first
Posted on Feb 20, 2010
Where is the reset button on a whirlpool microwave #MH7130XEZ-2
Hello Art. If you want to reset your Microwave, we would recommend resetting it by shutting it off from the circuit breaker for at least a minute.
May 08, 2017 | Whirlpool Microwave Ovens
Model MH7130xez won't heat. everything else works. the clock, timer and lights. does this model have a fuse?
if unit won't heat, then there is a problem with either the magnetron or the diode. if its the magnetron, the microwave will sound almost normal. if its the diode, it will make a humming sound
Mar 26, 2011 | Whirlpool MH7135XE Microwave Oven
F7 code on Whirlpool Microwave model GH9185XLT - 1
Power to magnetron
interrupted
12. Replace inverter.
13. Replace all parts and panels before operating.
14. Plug in microwave oven or reconnect power.
15. If problem persists, unplug microwave oven or disconnect power.
16. Replace electronic control.
17. Replace all parts and panels before operating.
18. Plug in microwave oven or reconnect power.
19. If problem persists, unplug microwave oven or disconnect power.
20. Check for reversed plug connection on controls or loose wiring.
21. Replace all parts and panels before operating.
22. Plug in microwave oven or reconnect power.
May 23, 2017 | Whirlpool GH9185XL Microwave Oven
Whirlpool MH7140XFQ-1 microwave no longer heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
kggk
Apr 24, 2009 | Whirlpool MH7140XF Microwave Oven
Service to Whirlppol MH7130xez-1, circuit breaker popped then unit went dead
water may have leaked inside unit causing a short.the transformer output is about 1400 volts that feeds a large capacitor. a direct short can blow the transformer instantly or any support parts without time to burn something. creating little or no smell. I never sujest that a person
to try to repair a microwave oven because
the capacitor can still be charged and very lethal.
Feb 25, 2008 | Whirlpool MH7135XE Microwave Oven
Door
The door part# is 4359542 if you need the part number. If you need to know how to replace the door check up by the upper hinge on the inside of the door should be a plastic piece that you can remove so if you lift the door off of its hinges. You may or may not need to remove the grill above the door to raise the door high enough
Oct 31, 2007 | Whirlpool MH7135XE Microwave Oven
Whirlpool mh7130xez-1
When you open the microwave door, on the inside of the door there is a plastic trim around the glass called a choke that is clipped in that needs to be removed to get to the screws for your handle
Oct 29, 2007 | Whirlpool MH7135XE Microwave Oven
Oct 14, 2007 | Whirlpool MH7135XE Microwave Oven
Microwave Ovens Logo
69 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
