Question about Frigidaire PLHS267ZA Side by Side Refrigerator
I just got this fridge a few days ago (it is just a year old) when I plugged it in, it was running for a few min, I noticed a buring smell coming from the fridge side.. after inspecting it I noticed that where the top light is in the fridge the plastic above (the top inside of the fridge) is burnt. I took the light bulb out and the smell went away within a few min. I have checked to make sure it is the right bulb and wattage (it is) any idea's in why and how to fix this problem?? many thanks
  • 725 Answers
Did you leave the door open? check the light socket for shorts ..check the door switch the light will go off when to door is closed..
Posted on Sep 07, 2008
FRS26R4CB0-Freezer not freezing and Fridge not getting Cool
Hi Candi,
I don't know this model but most friges are the same,
Check on the bottom back, there should be a radiator with a small fan
installed.
If the fan is not working this maybe your problem,
It is not colling the gas.
You also may have a gas leak or the gas compressor is not working
or starting to work because of a faulty capcacitor.
Jan 11, 2014 | Frigidaire FRS26R4C Side by Side...
PLHS267ZA is leaking water from the bottom (freezer side)
I would look under the fridge for a drip pan that might be full, so when it defrost it overflows the pan and runs on the floor. If not that you must have a blockage somewhere in the drain line that runs to the drip pan. Take out the shelves and take off the plastic panels to access the drain and drain line, pour some warm water down the drain to unplug it.
Jan 03, 2014 | Frigidaire PLHS267ZA Side by Side...
The fresh food compartment on my PLHS267za fridge is freezing. Have tried turning the temp all the way down and it is still freezing. What could the problem be?
damper stuck open by the fresh food thermostat. the unit doesnt know that it is cold enough so the damper stays open letting cold air from the freezer to continue to travle over.
Oct 19, 2010 | Frigidaire PLHS267ZA Side by Side...
I have water running to the fridge and contact at dispencer by I cannot get water to ice maker or dispencer
Look on the backside of the fridge for a small shutoff valve which may be turned off. Also, if your fridge has provisions for a filter, check for a clogged or missing filter. In either case, you will have to replace the filter.
Jun 11, 2010 | Frigidaire PLHS267ZA Side by Side...
Frigidaire Gallery refrigerator, evaporator fan not running
As insignificant as it may seem, that evap fan motor is as important as petrol in a car. That fan controls the fridge cooling on many fridges and circulation in tha freezer compartment. Replace it with the correct one and you should see a functional fridge/ freezer again. Note, i wouldnt run unit without it for long, as condensig temperatures run high and compressors dont last long.
May 23, 2010 | Frigidaire PLHS267ZA Side by Side...
PLHS267ZA
The guide that funnels the water into the ice maker needs to be replaced. The cause of your problem is that water is leaking into the back, freezing there, and blocking the air flow. Mine sounded like an idling semi truck with engine problems.
Jan 06, 2009 | Frigidaire PLHS267ZA Side by Side...
Refrigidare model # plhs267za
sounds like the air damper control for refrig is freezing in the open positon. not a really consumer freindly repair,(dropping side control panel checking damper door for ice build up, removing ice and applying a silicone lubricant(vasiline) to prevent further freezing of air damper motor. sounds easy enoug but that panel is real tricky to drop and mount back in.
Mar 04, 2008 | Frigidaire PLHS267ZA Side by Side...
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Frigidaire PLHS267ZA Side by Side Refrigerator Logo
166 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
