Question about Nikon N75 35mm SLR Camera
Rewind stuck on reverse - Nikon N75 35mm SLR Camera
    Champion:
  • Nikon Expert
  • 225 Answers
Hi Luce n Steve, To quote JC at Photo.Net: "sometimes the rewind function "gets stuck" if the camera thinks a previous rewind did not complete successfully. The solution is to reset it by forcing a rewind operation. Just press the two rewind buttons simultaneously: on the left side of the lens and just behind the shutter release. (They are marked and the manual explains how to force a rewind.) I did exactly this, and my next roll of film loaded without problems." Hope that help you folks.
Posted on Aug 23, 2010
How to rewind film on minolta maxxum 5000?
Open door in the dark room.
See if it's already rewinded, but could be a stuck counter
May 12, 2014 | Minolta Maxxum 5000 35mm SLR Camera
How to rewind/fast forward trough currently listening segment?
Touch the screen, and 'reverse', 'pause', and 'forward' icons will momentarily appear on the lower portion of the screen. Before the icons vanish, touch either the forward or reverse icon and continue to hold your finger on the icon without lifting it off of the screen. Fast forward or rewind will then begin, at a rate of 5 seconds per second held. I am told after holding for 15 seconds or longer the speed of the fast forward may increase (true for other Coby models I have owned), but so far I have had no luck getting this to occur with my MP828.
Jun 23, 2012 | Coby MP828 layer
The rewind button on my diana camera is stuck OUT - as well as that I can't rewind my film as the rewind lever is stuck - can you please help?
Take your camera to photo developer who has the dark room. They will open your camera in dark room and remove the film without any damage to it. Once film is out you can see whats actually the problem, it can be gear tooth misaligned or something.
May 08, 2011 | Lomo Diana Mini 586 Film Camera
Plug/wire is stuck partially out (4-5 inches)pressing on rewind button nothing happens....just stuck!
This usually means the cord got twisted over itself. Pull it completely out and give slight resistance on cord and rewind it again.
Sep 17, 2010 | Hoover Elite Rewind Bagless Upright...
The pull cord will not engage the flywheel. it pulls our with no resistance.
The rewind ratchet drum has steel balls that engage, they could be stuck with old grease, take it off (reverse threads) and clean it and oil it.
May 25, 2010 | Garden
How to load ribbon and rewind ribbon.
The ribbon should reverse itself if it working properly. Just to the indide of each ribbon is a reversing that the ribbon should go thru, Move that arm away from the empty spool and type a few letters it should reverse. DickyO
May 31, 2009 | Royal Office Equipment & Supplies
Rewind button is stuck
It can definitely be fixed but let's try one thing before forking over few bucks to technician. Assuming it is a SLR camera, When you rewind, hold the rewind knob pushed in and try it. If you have a point and shoot, let me know which model. I'll be ready to assist when you respond either way.-James
Apr 04, 2009 | Olympus Photography
I want to know how to rewind a film reel or reverse an Elmo FP-A movie projector. I have an old Elmo FP-A movie projector that works fine. I do not have the instruction manual that would explain how to...
There are 3 round knobs and 1 Autostart switch on the control panel. The key to rewinding this machine is by pushing the gray button down, while turning the Motor Knob to the "Run" position. Of course you'll need to start the original film back on its reel, directly. (Do not thread the film as you would normally.) BTW, you can show your films in reverse by using the Reverse button on the motor switch while its running. Hope this helps. Now, if I can find someone who can guide me in re-assembling my Elmo projector's lens, which I dis-assembled in order to clean the crud off the multi-lenses in the main lens unit itiself.
Mar 10, 2009 | Fuji Photography
Rewind on my camera wont turn
Has the rewind knob become unscrewed or just won't turn? It does have to be turned clock-wise to rewind the film. If you would happen to turn it counter-clockwise, it would either jam or the knob itself would become undone from the rewind shaft.
Dec 25, 2007 | Photography
VCR tape stuck
Yes, it is a mechanical problem. While the tape is in fast forward the gears are engaged and locked to provide drive to the spindel on the right, however when you press the rewind button without hitting stop, the gears try to engage the spindel on the left without stoping and reversing (changing rotational positioning), this causes the motor to stop (this emulates a tape jam)the tope is left in and the unload mechanism never spools the tape back in because the motor has stopped. To free the tape, what I do is open up the unit and find the main motor check to see if the belt has slipped, if it has not try to manually spin the motor to engage the unload mechanism and eject the tape.
Dec 18, 2006 | Zenith VCS442 VHS VCR
Nikon N75 35mm SLR Camera Logo
232 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
