Sony VAIO F340  PC Notebook
Problem for Sony VAIO F340 (PCG-F340) PC Notebook
Sony PCG-F340 keeps shutting down
By kioner - usenet poster
I have the above model that keeps shutting down within 15 seconds of it
loading the windows desktop (win98).
It also keeps flashing the LED nearest the number 1 on the battery
indicator.  This notebook doesn't appear to want to run of the battery at
all (it doesn't seem to hold a charge).
The shutting down problem is still happening when plugged into the mains.
It doesn't do it if it's booted in safe mode though.
Any ideas would be greatly appreciated.
Thomas.
Same Problem
Nov 06, 2008
-   my laptop just shuts down and seems to be hot on bottom-   Guest
Best Solution
posted on Aug 10, 2005
Very Helpful)
Ranny
Rank: Apprentice
Rating: 0%, 0 votes
 "ThomasNews" <thomasn @iprimus.com.au> wrote in
I once installed a trojan which caused this to happen - it would run a
script at bootup which caused a shutdown. It was quite easy to remove in
safe mode (can't remember how exactly, but read about it on the web).
Perhaps you might have something similar? Worth a check..
If this is not the case then try formatting and reinstalling the OS.
Was this helpful?
Yes
No
Solution #2
Not Helpful)
Luisa_K
Rank: Apprentice
Rating: 0%, 0 votes
Thanks for your reply shaun.  I have checked the power management stuff.  To
no avail.
Was this helpful?
Yes
No
Solution #3
Not Rated)
Lizzy
Rank: Apprentice
Rating: 0%, 0 votes
If you can't get the system to boot normally under A/C power with the
battery installed, try pulling the battery out of the notebook. I suspect
the power management is reading a bad battery and trying to either suspend
or shut down the notebook. In safe mode, the power management device is
inactive.
Also, if you consider another notebook, stay away from Sony. They really
aren't good value in my opinion.
Marty from Fabulous Sunny South Florida
Was this helpful?
Yes
No
Solution #4
Not Rated)
Bouncy
Rank: Apprentice
Rating: 0%, 0 votes
Check the power management configuration in Windows to start. You can do
this in Safe Mode so it shouldn't be too hard. It's possible your
battery is going bad but have it checked, if the battery is good your
power control module in the laptop may be the problem. I hope the laptop
is still under warranty if the worst is happening.
--Shaun
Was this helpful?
Yes
No
Popular Solutions for Sony VAIO F340 PC Notebook
Questions and Unsolved Problems for Sony VAIO F340 PC Notebook
Do you recommend Sony VAIO F340 (PCG-F340) PC Notebook?
Answer
Answer
D drive will not work. laptop will not recognize that a dvd or cd is in the drive
Answer
i can not get it to boot of the windows xp installation disk.(this is a bootabl disk) i have change... (More)
Answer
Registeration of new product
Answer
i need 2 find the code for penguins
Answer
I've got a NV52, running windows 7. The card reader installed drivers after I inserted it, but I... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony VAIO F340 PC Notebook:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
