Question about Harley Davidson 426290 AM/FM Radio
I have a anoying crackel that comes from speakers. This problem use to be abel to be fixed by tigtening the 4 bolts on the side of the radio but now they can't be tightend; they just spin. I have ran a new ground from radio to frame, did not fix problem. I have alo put in a inline noise supressor;did not fix. this noise only occurs at certain rpms. The bike is a 02 ultra. thanks.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Harley Davidson Expert
  • 281 Answers
Internal amp is breaking down. Will eventually result in no audio. Radio Sound made the radio and can repair it
Posted on Aug 23, 2010
Where is the factory amplifier on gmc envoy 2003
For the XL - The AMP is located on the drivers side, behind the left rear trim panel.
1. Remove the cargo shelf. 2. Tumble the third row seats to the cargo position. 3. Remove the left body side window rear garnish molding.4. 4. Remove the left body side window forward garnish molding. 5. Remove the liftgate sill plate. 6. Remove the left rear door sill panel. 7. Remove the lower seat belt anchor bolt. 8. Remove the auxiliary power outlet from the trim panel. Release the five screws that retain the rear quarter trim panel to the body. 9. Remove the rear quarter trim panel from the vehicle.
If you don't have the XL then the AMP is located on the passenger side.
1. Remove the screw that retains the trim panel to the body. 2. Remove the cargo net retaining knobs. 3. Remove the bolt that retains the seat belt upper guide to the body. 4. Remove the rear upper quarter trim panel from the vehicle. 5. Remove the cargo shade/cover. 6. Remove the inflator access panel. 7. Remove the right rear quarter upper trim panel. 8. Remove the liftgate sill plate. 9. Remove the right rear door sill panel. 10. Remove the lower seat belt anchor bolt. 11. Release the retaining clips that retain the trim panel to the body. 12. Partially remove the trim panel in order to remove the inflator switch from the inflator bezel. 13. Remove the auxiliary air outlet washer and retaining nut. 14. Feed the auxiliary air outlet through the inflator bezel. 15. Remove the inflator bezel from the trim panel. 16. Disconnect the the 12-volt power supply electrical connector. 17. Remove the 12-volt power supply. . 18. Remove the trim panel from the vehicle. 19. Disconnect the electrical connectors from the radio speaker amplifier. 20. Remove the 4 bolts that retain the radio speaker amplifier to the body. 21. Remove the radio speaker amplifier from the body.
Mar 16, 2011 | 2003 GMC Envoy
I get a crackeling sound out of speakers. Dell speakers. Tried to use contact fluid I bought at Radio Shack. How do I squirt it in?
. your issue is possible due to a bad volume control or a separated conductor wire at the connector to the sound card.
You may have to buy a new speaker assembly or if you are adept at soldering or can disassemble the speaker assembly you can replace the resistor potentiometer/ volume control with a new suitable resistor from Radio shack or your favorite electronics store that supplies these parts.
Usually a new speaker assembly is warranted.
Oct 04, 2010 | Dell A215 Computer Speakers
My car scream when first started. How to fix it?
Sounds like a loose alternator belt. Look under the hood with the engine off , find the alternator, see the belt and make sure it is tight.
Mar 11, 2010 | 1993 Toyota Corolla
Protection light comes on. what is it and how do i fix it
Wire connection is not right or the power source is not enough. Make sure the radio wires connected to the car are correct and that the usually blue and white REM wire from the radio is connected to the REM position in amp. Power source must be straight from battery not from anywhere else. Ground wire should be connected any metal bolt in trunk or to a new hole drilled into frame. Also make sure that the wires for speakers are running on 1 side of the car and the power is on the other side, never together on same side of car. Hope this helps.
Oct 02, 2009 | Kicker KX400.1 Car Audio Amplifier
I have a 2000 Honda Accord. The radio works but there is no sound coming out of the speakers. One day the the speakers all crackeled and I didn't here sound again. What do I do? Is there an amp?
I had an issues where the my radio was working but no sound was coming out of the speakers. My problem was that the passenger speaker was disconected, and the wires were shorting out the radio. So I took it in to a pro installer and we put in a new speaker to the passenger door and hooked it up properly. The deck then started playing music fine.
Make sure your speakers are all connected properly, and that your wires have no cuts in the plastic that would expose the copper, causing them to short out. Also check your fuses to see if you blew any.
Hope this helps.
Jun 25, 2009 | 2000 Honda Accord
Behringer ep 2500
if after the pop it smells like a firecracker just went of than you fried the circit for that speaker or if it has fuses on it or ferther down the wire check them but it could be just the radio and nothin to worry about:)  a friends car does it, and it is very anoying
Jun 01, 2009 | Behringer EUROPOWER EP2500 Amplifier
MT HT-TX52 WORKED FOR A COUPLE OF MONTHS, THEN THE SUB WOOFER WOULD MAKE A VERY LOUD CRACKELING NOISE ALL OF A SUDDEN, BUT ONLY ONCE IN A WHILE, SO I UNPLUGGED IT AND JUST RAN THE OTHER 4 SPEAKERS. WORKED...
Maybe a capacitor in the amp section is making this problem.The only way to find out is to check receiver in service and find which capacitor is bad...but this is not so easy
Apr 18, 2009 | Samson Audio Players & Recorders
Large crackling noise with my Acer Laptops base?
it is ur laptop's cooling fan's noise it is not a big problem.but if it is too much loud then contact on service center.
Apr 11, 2009 | Acer 90.00012.30B Computer Speakers
Crackeling speakers
check the connections , replace it.
Jan 19, 2009 | Hitachi 57G500 57" TV
Removing front and back speakers in 1991 Grand Am....
There is a lot involved in replacing these speakers. You should also know that the original factory speakers are 10 ohm speakers. This means that if you replace them with new speakers (most of which are 4 ohm) you run the risk of damaging the stereo, the speakers, or both. This can also cause a potential fire hazard in your car. If you want new speakers, you really should look at installing a new stereo as well.
To get to the back speakers, you will need to remove 2 bolts located under the front edge of the rear seat (bottom). After you remove the bottom, you will need to remove the rear seat (back). This involves removing the bolts that hold down the rear seat belts, which is a large sized torx bit (T-45, T-47, or T-50... Don't remember which). After removing these, lift straight up on the seat back to remove. Now remove the deck brake light housing, and the bracket that holds it. Now the deck cover can be removed. Be careful not to bend it too much getting it out from under the side trim on both sides.
For the front speakers, you must disassemble a good portion of the dash. Remove the screw holding the light switch and the wiper switch housings. This screw is underneath each housing. Once removed, there are dash mounting screws behind them. These screws (and many of the other dash screws) are a smaller torx-bit (T-10 or T-15, don't remember which). Sometimes they use a 7mm bolt. There is a cover panel just above the glove box. This panel is held on with 2 screws located in the glove box. After removing this panel, you will find 2 or 3 bolts holding on the dash. Last but not least, you will find 2 bolts inside each of the defroster vent grilles. These grilles just snap out for easier access to the bolts.
1991 Pontiac Grand Am Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4" Round
Car Audio Front Speakers Location: In Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6" x 9" Oval
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Nov 30, 2008 | 1991 Pontiac Grand Am
Harley Davidson 426290 AM/FM Radio Logo
136 people viewed this question
Top Harley Davidson Audio Players & Recorders Experts
Jim Goldsmith
Jim Goldsmith
Stephen Burdy
Level 1 Expert
xxxxxx xxx
Are you a Harley Davidson Audio Player and Recorder Expert? Answer questions, earn points and help others
