Question about Teac MP-111 MP3 Player
Doesn't come up with PMP351 device in media player 11 running vista
My WMP 11 on Vista will not recognise my philips
Could be driver problem. You can try reinstalling the driver for the device. If it's a vista system, you might want to run the executable file in administrator mode, or even change the compatibility to XP.
Uninstall the current installation of the device software.
  • Insert CD in CD-ROM
  • Right click on the setup file
  • Choose properties / Compatibility Tab
  • Set it to XP
  • and tick the box at the bottom run as administrator.
I hope that help.
Aug 16, 2009 | Philips HDD1630 MP3 Player
Player not reconized
What operating system are you using? The Zen uses the MTP driver so if you have Vista or are running windows media player 10 or 11 the driver should be present and the device ought to be recognized. If not, check device manager for your zen device. If it's there, right-click and uninstall, disconnect your player and after a few seconds plug it back in. Windows should then reinstall your driver.
Jul 31, 2009 | Creative Labs Zen MicroPhoto MP3 Player
I do not have the Vista setup disk for my inovix IMP 5750. Where can I download it from?
HI,
Unfortunately there is no vista software available for your mp3 player.
If you are looking a way to transfer music to your player then you can use the Windows media player 11 which is available in vista operating PC.
You can open windows media player 11 and click on SYNC>click on search devices and make sure your player is connected to the pc.It will search for your player and then you will be able to transfer music by just doing a simple drag and drop.I mean dragging the music from the wmp11 library list to the right side of the SYNC.
Jul 07, 2009 | Audio Players & Recorders
Error when trying to download MS strrets and trips 2006 w/ GPS lo
I have used every version of streets & Trips since 05, and have never had any issue with Win Media Player, currently using streets 2009 on one machine with Windows 7 RC1, which has WMP 11, and on another PC streets 2008 and Vista with WMP 11. You may need to change your default program settings for media back to WMP if you ever had another media player installed.
Jun 13, 2009 | Microsoft Streets & Trips GPS 2006 x GPS...
After down loading music player went off won,t recharge
This player is effectively destroyed by using it on a computer that runs either Windows Media Player 11 or Vista. You can try doing a repair in Philips Device Manager, but this is very nearly an obsolete mp3 player.
Nov 27, 2008 | Philips GoGear HDD1830 MP3 Player
I HAVE WINDOWS VISTA
If you are using Windows Vista with Windows Media Player 11, you will need to follow these instructions.
Note: You will be able to download purchased/subscribed songs to the unit.
1. Start Windows Media Player 11 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
2. In Device Setup - Configure Sync, write a name for your mp3 player.
3. Click Finish. The window closes and the Sync feature in the Player is displayed.
4. From the left pane of this Sync feature, you can select from Playlists or Library and you will see the content of these folders in the center pane.
5. Select the songs or entire albums from the center pane.
6. Drag these songs or albums into the Sync List, which is the right pane of the Sync feature.
7. Click the Start Sync button on the Sync List pane.
8. Repeat steps 4-7 for any other items that you want to copy to your unit.
Nov 13, 2008 | GPX MW3836 MP3 Player
Mp3
If your GoGear is an HDD model, then it is incompatible with both Vista and Windows Media Player 11. If you have Vista, forget about this player. If you have XP, roll back your Windows Media Player to version 10 and try running a Repair in Philips Device Manager - the damage might already be done, but it is worth a shot.
If you have an SA model GoGear, get the latest Philips Device Manager from www.usasupport.philips.com. Make sure you enter your correct model # in the website, or you will damage your player. Run an Update in the updated Philips Device Manager to upgrade the firmware to fix the freezing issue. Philips has a weird quirk that if you want to really upgrade the firmware, you have to also update the Philips Device Manager first or the Device Manager from the CD will give you a false positive: "Your device is already up to date."
-Tha Mp3 Doctor
Jul 17, 2008 | Philips GoGear SA178 MP3 Player
Hi
Make sure you are using Windows XP and Windows Media Player 10.
Also make sure you have installed Musicmatch Jukebox from the product CD.
The PSS110 is not compatible with Vista or Media Player 11.
If you have Media Player 11, then uninstall it, to roll back to version 10.
Also, you need to make sure the player is showing as "GoGear" and not "Removable Drive".
If Musicmatch shows the player as "Removable Drive", go into the options menu and click devices. Click the dropdown menu showing "removable drive", and select "GoGear"
You will also need to run the Philips Device manager and Restore the player, to delete the tracks which the player hasn't seen.
Mar 09, 2008 | Philips PSS110/17 MP3 Player
Syncing
It is possible that you do not have Windows Media Player 10 or 11. If you do have WMP 10, then try resetting the GoGear first (with GoGear turned on, find a small paperclip or other such device, and press it into the reset hole; it works when the player turns off). Try syncing again.
If you have WMP 11 or Windows Vista, perform a firmware upgrade:
just open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website; click on the Update tab - this will give your player the firmware upgrade.
If these methods fail, reply to message using FixYa website (not my personal e-mail).
-Tha Mp3 Doctor
Jan 13, 2008 | Philips GOGEAR SA6045 MP3 Player
Not detected by computer - cannot recharge battery
yay I found a solution! so I kept getting the error about an MTP device, so I did a big search. I am running vista on a 32 bit processor. what you need to download is the MTP installation programme from windows. so click on http://support.microsoft.com/kb/939211
and then just select what processor speed you need. should do the trick! I also downloaded http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en initially, but it didn't appear to work. hope that you all get to the bottom of this frustrating problem :)
Dec 18, 2007 | Samsung YP-U3 MP3 Player
Teac MP-111 MP3 Player Logo
185 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
