I used reg soap in my GE profile WPDH8800washer and Now when you press start the door locks then in about 20 sec.it goes back to reg display and then will shut off. Do you think my intake screens are clogged If so what do I do? thanks
  • Washing Mach... Master
  • 15,557 Answers
The problem is that you have used non HE soap and that created suds that have contaminated the water sensors in the unit, You can try putting water in the unit using a bucket and see if you can close the door and get it to enter a spin and drain cycle or you can leave the door open for a period of time (days) to see if it dries out enough to allow it run.
Posted on Aug 22, 2010
This is my second attempt. I have a GE Profile
After you set it, the display goes back to showing the current temp. Just wait awhile and current temp displayed should change to the temp you set once it has had a chance to adjust. Give it a few hours.
Feb 19, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I have a GE Profile,model PFS22SISBSS,3 years
Possible main pcb failure failure which would cause everything to cut out and restart . Is the compressor or back of the appliance hot ?? Do all the control lights go out when the compressor cuts out ??
Feb 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile front load washing machine demo mode
I called General Electric and this is the solution:
unplug the machine for 2 to 3 minutes.
Plug it back in the wall
Do not put the power back on.
Open the door
Press the start/pause button 5-6 times
The display will say demo exiting...
This works. Also don't forget to remove the shipping bolts before starting your washing machine!!
Good washing!!
Jan 04, 2009 | Zanussi IZ141W Front Load Washer
GE dishwasher won't start
You have a washer control board problem or a burnt connector or both.
Mar 17, 2017 | GE 24 in. Profile PDW9200J Built-in...
Door Keeps Locking and Unlocking after Power Outage
Located the switch - resetting fixed my stove as well.
Dec 17, 2007 | GE Profile JTP18 Electric Single Oven
1h (?) signal, and soap dispenser doesn't open
The part called a Wax Motor (about 2 inches) inside the door is responsible for opening your dispenser.Check it / replace it.
Oct 09, 2007 | GE 24 in. Profile PDW7800 Built-in...
Our GE Profile JTP18 keeps flashing "door lock" since we ran a self clean
most of the time a simple fix.... http://www.geappliances.com/search/fast/infobase/10004586.htm
you have to trick the door lock mech into cycling through the cleaning process (takes about 20 seconds)
Print Range - “LOCKED DOOR” flashes in the display
If “LOCKED DOOR” is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
If the above does not correct the situation, a service technician will need to check your cooking product. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Sep 14, 2007 | GE Profile JTP18 Electric Single Oven
GE Profile XL44 Spectra gas oven
My Spectra XL44 suddenly refuses to ignite the baking portion of the oven - broiler and top work just fine. The day before it was working fine. Wondered if it was an electrical egnition problem - gas feed or what??? Help!! Mregressor@aol.com
Nov 13, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
