Question about Ovens
Leisure Rangemaster Auto 55 serial number 5419-082216, 11 years old - main oven flame failure. The oven flames lights but doesn't get any higher when I try to turn it up. what is the problem and can it be repaired, thanks.
SOURCE: leisure rangemaster 55 gas cooker
It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
Posted on Apr 07, 2008
  • 12 Answers
SOURCE: How do I fit a Flame Failure Device into a Mistral EL
you should not attempt to repair this unless you are gas registered. It is against the law!
Posted on Oct 24, 2009
SOURCE: i have a rangemaster 55
mine has done the same thing boxing day. Did you get a solution
Posted on Dec 27, 2010
heatman101
  • 43501 Answers
SOURCE: rangemaster 55 auto, oven ignites but flame
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on Apr 02, 2011
SOURCE: Xenon 2 leisure gas cooker After
Where can I purchase an Xenon II Instructions book?
Posted on Nov 23, 2011
My main gas oven will light but not go up to full flame, the top oven works fine
Flame failure device not working heater pilot could be blocked
Oct 24, 2016 | Ovens
The oven won't light
I suspect this is a gas oven. If so it is possible that the oven igniter is bad. If it is a standing pilot type the pilot should get higher in flame when you turn on the oven. This higher flame should cover the sensor probe in flame if not the pilot orifice could be partially blocked. A service person should be contacted if this is the case. Without any more information than what you have noted that is the best i can do.
Feb 24, 2014 | Ovens
Oct 21, 2009 | Ovens
Pilot light still going out
If this oven has a "stack" (where the hot gases & heat vent to your hood) air could be blowing down the stack affecting the pilot. Simple test, Bic lighter lit at the top of the stack in the middle of the opening. If the flame is being sucked down the stack, then you have air blowing the pilot out. How old is the thermocouple on this unit ? Pilot flame heats this up to send a signal to your main gas valve to open up so the burners light. A weak t-couple could be your problem. Hope this helps
Jul 23, 2009 | Bakers Pride FC-616 Gas Single Oven
Leisure rangemaster 55 gas cooker
Nov 13, 2007 | Ovens
Ovens Logo
51 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
