Question about Refrigerators
I am looking for an owner's manual for an Amana model BB120TE refridgerator
4 Suggested Answers
  • 119 Answers
SOURCE: owners manual
www.kenmore.com
Click on: Customer Care. Follow the instructiuons on how to download the manual for your model.
Posted on May 27, 2008
heatman101
  • 43501 Answers
SOURCE: I'm trying to order a
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 28, 2010
  • 794 Answers
SOURCE: Amana Refridgerator Model ARB210BAW
Hi storkdoc1,
This complaint is usually the result of a defrost problem. The first thing to check in this case is the freezer area. Look at the back panel inside the freezer. If you notice frost covering the back panel, you have defrost problem.If the coils in the freezer section get clogged with frost, it will block the evaporator fan motor from blowing the cold air. Kindly check the defrost timer, thermostat and heater.You can locate the defrost timer, but it can be tricky, since they are often hidden behind the back bottom corners of the fridge. In the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw-like wheel, in the middle of the defrost timer, with a screwdriver until the fridge shuts off. Now the fridge is in defrost mode. If the defrost heater comes on now, replace the defrost timer and defrost thermostat. If the heater does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater. If you have no power to the heater, you can also bypass the defrost thermostat to see if the heater will come on; join the two wires together, to bypass the thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy or ticking, replace it.
Hope it helps.
Thank you for using Fixya.
Posted on Apr 25, 2011
I need Amana Fridge freezer manual model no BRF520T
Go to www.apdepot.com and enter your brand and model in the search area, get the model off the label inside the refrigerator, and on the lower left side you'll see selections, one of which says literature
May 08, 2012 | Refrigerators
Amana Model ACS3350AS Oven temp is 25 degrees hoter than display. What do I need to repair it? How do I find a manual for this. This came with the house.
Oven temperature can be adjusted for a maximum of 35 degrees farenheight.
Refer to the page 11 of your owner's manual.
A PDF version of the owner's manual can easily be find at
http://shop.amana.com
Jan 11, 2011 | Amana ACS3350 Gas Kitchen Range
Need owner's manual for Amana ACF4265 range
Here's the link to get a free owner's manual and installation instructions that you can print up from your computer. Just pick the exact model # from the list of choices. Douglas
http://shop.amana.com/product_literature/search_results.jsp?searchTerm=ACF4265&siteCd=AMA&userType=Consumer
May 31, 2010 | Amana ACF4265 Electric Kitchen Range
Amana Refridgerator freezes in the refridgerated cavity.
Many Amana refrigerators have something called an auto damper. It has a thermostat coil on the side of it and as the temps get colder the damper door closes. If the thermostat on the side becomes defective then the damper door will remain open or shut. If it remains open the food in the fresh food compartment will get so cold that sections will freeze. If you could send the model number of your Amana I may find a service manual with instructions that tell you how to test by removing and dipping the thermostat into warm or cold water to see if it is working properly. I will be here in and out to my other websites but would be happy to assist you and resolve this problem. Thanks Sea Breeze
Jan 21, 2010 | Refrigerators
Refridgerator door sags
Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
Good Luck!
Sep 15, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Owners manual
www.kenmore.com
May 26, 2008 | Kenmore Refrigerators
Refridgerator not cool enough.
sounds like the probable cause is defrost heater. get someone to test the element.
May 27, 2007 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
