Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
Memory card locked
The memory card is locked and i have tried sliding the tab in different possitions but it still wont work.
can anyone help me please?
    Scholar:
  • 46 Answers
Have you tried using the camera's setup menu to perfom the initial required format of the card ??
Otherwise The memory card itself has to be faulty . Have you tried using a different card ??
A while back when I bought my Motorola V3x Razr ,new in box, the micro SD card I received not only fail to work , but was bent like a banana & crashed the pc everytime I attempted to connect it LoL
Posted on May 26, 2008
When i insert memory card in my camcoder aiptek dzo-v50s,i have got problem.card protect
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 24, 2011 | Cameras
Memory card error it says card is locked I slid the switch back an forth but still says memory card
I'll include a diagram of the little lock switch so you know the correct position to be able to load pictures to it. Another reason for getting the card locked error is if the memory card hasn't been formatted in the camera it's being used in. Formatting is necessary after downloading pictures to the computer as well.
Diagram
Mar 02, 2011 | Canon Cameras
My daughter has a vivicam 5022 and when i put the memory card into it, it says card locked and wont take any pictures how do i unlock the card?
SD cards have a slide switch along one edge. The position nearest the contacts enables writing, the opposite position protects or locks it. Try sliding it fully to the locked position and then fully to the unlocked position. If that doesn't work, try a different card.
Jan 24, 2010 | Vivitar ViviCam 5022 Digital Camera
Computer keep saying the disc has write protection. I've tried the little lock in both positions with the same result.
If the little tab on the side of the memory card was already adjusted to no avail, then try to reformat it from your computer.
Jan 15, 2010 | SanDisk 2GB microSD Memory Card
I borrowed my sister in laws samsung i70 now it is saying the card is locked & wont function how can i unlock it?
Shut the camera power off, and remove the memory card.
Observe the label side of the card and find a small plastic tab on the left edge of the card. Slide the tab forward (towards the connector end) into the "Unlocked" position.
*Carefully* reinsert the card into the camera - taking extra care to slide it straight in - so that the tab is not bumped back to the "Locked" position.
Power up and and take pictures.
If it doesn't work - it is possible that the tab got moved during the reinsertion process. Remove the card again, and place a *small* amount of scotch tape over the tab to keep it from moving, and try again.
Oct 15, 2009 | Samsung S760 Digital Camera
My SanDisk memory card for my HP Photosmart R740 wont let me format the card or delete photos from the camra or take new photos, please help!
The card may have failed on you or the write protect slide over enough to lock the card. Take the card out and looking at the label to the left is a notch on the side. In the notch will be a tiny button or slide. Move it to the top (away from the gold connectors) to unlock. If you still cannot delete you may have a dud card. You can try to reformat on a different computer or with a different operating system. For example windows won't work but Mac or Linux might work.
Jul 09, 2009 | SanDisk 2GB Secure Digital Memory Card
Memory card locked
Sounds like the 'lock' tab on the memory card has been moved to the 'safety' to prevent you from re-writing your card accidentally
Fix it by:
1 remove memory card from camera
2 look for the very little tab/switch on the front of the card
3 slide it to the unlocked position (opposite of now)
4 put it back into camera...should now allow you to take pictures
if the tab/switch is missing do not dispair...
-use a small piece of clear tape to cover this 'tab/switch' opening
-this is the same concept as cassette/vhs/ 5 1/4" floppies...removing the 'tab' to lock it
Sep 10, 2008 | Samsung Digimax L830 Digital Camera
The memory card is locked and I cant figure out how to unlock it...the camera wont take pictures and cant even erase the pictures
remove the memory card and look on the side of it their should be a little tab move it to the other possion and try the camera again. if that does not work with the card out gently tap the camera on the card side. and reinsert it their is a sensor that tells the camera their is a card inserted in it. it might be stuck. hope this helps.
Apr 24, 2008 | Cameras
Card locked
Greetings Burtie,
There should be a small slide tab on your memory card which locks it. Please slide that tab to the unlocked position and this should fix your issue with a locked memory card.
Sincerely,
Agent Dort
Apr 07, 2008 | Samsung Digimax U-CA 5 Digital Camera
Locked Card
Take the memory card out of the camera. Look at it carefully and you will seea small tab. Move the tab from the locked position to the unlocked position. Re-install the memory card into the camera and then you're done.
EEee
Nov 03, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
57 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
