Question about Linksys Wireless-G Game Adapter [ WGA54G ] (108451)
Its not workin to more!
It has worked in the past but one day it just shuts down.well doesn work. now it works like every month or so. the power light is solid. the wireless-g is blinking and the ethernet only lights up when it tries to log on
  • 298 Answers
Do you remember changing the wireless settings on your router? O double check if your gaming adapter still have the same wireless settings as your wireless router?
Posted on May 05, 2008
Phillips 47pfl7403d/f7 picture goes dark and then out completely
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 24, 2017 | Televison & Video
Most likely reason for battery drain,2 to 3 days 2003 Buick Century
charge the battery and then unhook the neg cable place a test light between the battery and the cable if the light is on there is a draw remove the fuses until the light goes dime then look into what the fuse feeds also unplug and remove the wires from the alternator that has diodes in it the can draw down the battery also if you have a power ant that doesn't work right that will also draw down a battery
Aug 20, 2012 | 2003 Buick Century
Kohler 12res installed 06/06, replaced controller in Dec 10, has worked fine since . This past weekend with storm, generator started and has run for 3 days , generator shut down with SCFO code - which...
SCFO is either what is displayed just before it cranks or when it is first powered up. Sounds like the controller may have forgotten what engine its running or is getting a bad run signal from the start switch. In either case a 1 year old controller should not be doing this. I would try having a local dealer doing a firmware update as there were quite a few for this controller and if this doesn't fix the problem I would start talking warranty with whoever replaced the controller.
Sep 01, 2011 | Kohler 12 kW Emergency Power System -...
I have a Dell Dimension E510 and have had this problem in the past. My dell has been shut down for a few weeks and wouldn't power on. maybe a month later, i randomly checked it after being unplugged the...
Some power supplies have an independent switch to turn on the power supply before you can power up the computer from the front. Does yours have a switch on the back?
Nov 01, 2010 | Dell Computers & Internet
Laptop shuts down on its own
Have you ever cleaned (did a maintenance) during the past six months? As we need to take bath, machines also need to be cleaned. Blow away all the dust and dirt from the motherboard, ad-on cards, connectors, ram, heatsink, cup fan, power supply,etc. and check whether it helps or not. Also run a full system scan using an updated antivirus. Good luck.
May 12, 2010 | Computers & Internet
Gateway MT6840 Laptop will not power up
have you already tried to power up your laptop without the battery, only with the powersupply docked in?
If this works, you´ll have to replace the battery or use the laptop without a battery.
If this doesn´t work, just take the full battery from the other laptop try to power up the laptop without the power supply docked in.
If this works, your latop motherboard is broken and till it is replaced, you have only the chance to work with a battery and reload it with another latop.
Jun 02, 2009 | Gateway MT6840 Notebook
Acer 22 inch monitor shuts off with indicator still green
The computer may be programmed to do a monitor shut off after lets say 20 minutes. This is a power saving feature of the operating system. Open Power Options under Control Panel.. select the drop down combo box that says "Turn off monitor" : set it to NEVER.
Nov 16, 2008 | Acer AL2216WBD LCD Monitor
The wheel controls are not workin...pls help...
ahhh..maybe you press it hardly...
that's why it will not work..
Jun 02, 2008 | Apple iPod MA446LL/A MP3 Player
My screen froze when i started a video. how do i unfreeze it?
the same shit happened 2 me yesterday night. this is the second time it happend. the screen is blank but it still has alight. this morning i noticed that that light went off so i turned it on and it worked but it said battery too low so i charged it and its working. so give about a day to see iff it works, and i hope it works for u
Apr 21, 2007 | SanDisk Sansa e250 MP3 Player
Linksys Wireless-G Game Adapter [ WGA54G ] (108451) Logo
206 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
