Question about Kenwood Audio Players & Recorders
My Kenwood T-58L LCD display doesn't work.can a new circuit board and display Be replaced.Roy from Plymouth
2 Suggested Answers
SOURCE: KENWOOD T-58L
press the adjust button, enter digits using 1-0 butons and step to next number using the enter button. keep completing digits and nter button until clock set. Cheers Gary
Posted on Oct 29, 2008
Hi yer ive got a Kenwood T-58L LCD display doesn't work no more but staion are fine is there a way i could get the lcd display back thanks
The display is part of the circuit board under the housing. If Kenwood stocks that part, you can purchase it and reinstall yourself. You must first go to the manufactures site on line, seek parts for the T-58L and purchase the display. Replace the display exactly in the manner by which you removed the defective one. Write down what wires match each other so you do the same match when replacing the hardware. Don't leave it to chance or memory as any mistake could be deadly.
Jan 12, 2018 | The Computers & Internet
Sony vaio pcg7d2l display
2 probable causes:
1. Inverter board is bad (which is the little board the lcd connects to)
2. GPU is bad, if you need an explaination of what that is click here
Live tech support
May 04, 2013 | Sony VAIO Computers & Internet
LCD display doesn't light up
Check my Tip, to see if this is the possible cause of your faulty display.
How to repair No Display on Kenwood faceplate
Cheers,
Mar 12, 2013 | Kenwood KDC-119 CD Player
2003 Jetta Tdi instrumentation cluster both LCD segments are no longer displayed Remove cluster and disassembled carefully removed displays and cleaned contact pads on circuit board and cleaned zebra...
Your LCD display is out of order. You can try to find one new on eBay. Chinese brand is cheaper, but VDO is better. After buying the LCD display you will need to install it.
See this link as an example of a new LCD display installation in the instrument cluster.
http://www.audizine.com/forum/showthread.php/263498-Official-DIY-2000-Audi-S4-LCD-Instrument-Cluster-Pixel-Repair
Aug 02, 2011 | Volkswagen Jetta Cars & Trucks
Kenwood KDC W6534U - LCD broke (not displaying) head unit works fine otherwise. Now out of warranty. Already had same fault repaired under warranty 2 years ago. How much for replacement facia or...
This is one solution for which the part cost needs to be confirmed from Kenwood. So it is better that you can refer to the service center who had done the work some time ago to give an estimate on the cost. If the fault is a self failure you can ask for some compensation as it has repeated.
Also the LCD pane specific to this model is available only from Kenwood.
Jul 13, 2011 | Kenwood KDC-W6534U CD Player
Kenwood Tuner 40701390 (part of M58M system) receives radio stations but LCD display not visible. It gradually faded out over a long period. Suspect fault in front circuit board
if it faded over time the display itself is bad.. considering it to be an older unit might be hard to find the part... good luck.
Nov 09, 2009 | Audio Players & Recorders
A901 has stopped working
Hello.
first press the boton green inside of the machine, when up the head.
if not working .
then is problems the capacitors and resistors.
Regards
Kenwood Chef Restore
Jan 06, 2009 | Kenwood KM800 Major Classic Stand Mixer
DPX-501 LCD Repair
I got the new display part from the Kenwood supplier on LI, NY but there are dozens of pins on lining both sides of the display, each 1/16" from the other. I don't have confidence in my ability to detach the old and solder the new to the main board without further disaster.
Choices for me now are:
- continue "flying blind" - most likely solution for the moment.
- pay someone to do it - includes removal and being without a head unit for an unspecified time, plus cost.
- replace - I'd like to change brands although it means replacing the Kenwood satellite unit too, so more cost.
This hasn't been a good advertisement for Kenwood. People are impressed by the sound in my car, but not so much by the blank screen, guesswork changing stations etc.
I really like the unit, and the display was great while it worked: exactly as long as the warranty. I can't recommend Kenwood.
Aug 19, 2008 | Kenwood DPX-501 CD Player
Kenwood dpx-501
I just solved the problem with my kenwood dpx mp 2090U - (looks similar with 501). FL Display with single CD, USB, 2 Din.
I should share this......... as I received the clue from someone that share the same case to me . Thanks to Mr,Nasirbaek from Indonesia,
The problem is at the main board . Dry (bad) soldering occurred. There are more then 5 resistors in series configuration. The resistor is quiet big (1.5mm x 3.5 mm, surface mount type R) about 2,7Ohms.The position is start from near usb port cable and ended to near big transistor (1 x 1.5 cm power transistor). After resoldering check with multitester to make sure that all R are connected in series configuration.
Just open 3 screws to access the main board. 1 at the top case. 2 at cd assembly, then Carefully take out the CD and the CD ribbon cable.
good luck.
Mar 25, 2008 | Kenwood DPX-501 CD Player
KENWOOD T-58L
http://www.kenwoodusa.com/Support/Home_Electronics_Owners_Manuals/#_
didnt fine one with your model # double check it or see if t93l is similar
Feb 08, 2008 | Audio Players & Recorders
213 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
