Question about Dishwashers
My Bosch dishwasher does not start. Instead it just ticks. I am not aware of any timer that it has. We have let it tick all night. One time in the last 20 attempts to start it (by closing the door) it did start but not since. Model number SHX46B. It is about 5 years old.
  • wineasa Aug 22, 2010
    This is a follow up on the Bosch.I did all those things and it is the kind that the controls are on the inside. there is no delay I can find. The model is SHX46B. Is there some kind of delay I don't know about. It seems more likely since it did start one in the last 30 tries to be some short or something. Any ideas
  • 19,396 Answers
Hi.
It is possible that the timer board is responsible, timer board however is an expensive part and fails rarely.
Before replacing control, if there is no water coming in check:
Door lock
Inlet hose at the back
Inlet valve
water level sensor (float or pressure)
If there is water getting in but cycle does not advance check:
Hot inlet in valve (if valve is dual)
Heating sysem (if valve is not dual0
Thermostat
water level.
If all the above is Ok go for the timer board, that is likely the problem
Posted on Aug 23, 2010
    Brigadier General:
  • 3,513 Answers
Hi
Please check your control board checked.If the dishwasher does not start, first make sure that the door is properly latched by shutting it completely. Check whether the dishwasher is turned on. The "On/Off" button is located on the left side of the control panel. Press the button one time to turn the dishwasher on. For models featuring a concealed control panel, meaning that the control panel is located on the inside edge of the door rather than on the door's face, the unit will not start unless a wash cycle has first been chosen. Finally, the "delay start" option may need to be canceled. This option allows the user to delay when the dishwasher's cycle begins by up to 24 hours. To cancel this option, press the "+" or "-" buttons on the control panel until "00" is indicated on the digital display panel.
Let us know if you have something more to ask else please accept the suggestion.
Thanks for contacting fixya.com
Posted on Aug 22, 2010
1250rec1 ticking from door, no lights on panel
I traced it down to the timer switch or function selector being faulty. Are these other posters really that dumb or are they trying to mislead someone for their amusement ?
Apr 14, 2014 | Frigidaire Dishwashers
Flashig lights, ticking sound, unfinished cycle
It sounds like it may be a heater problem or motor start problem. If you will post the complete model number from the decal, I may be able to look up something on it.
You should be able to get warranty service even without the proof of purchase as long as the manufacturing date proves it is within the warranty period. The date code is in the serial number.
If you will post it also I can look it up and tell you when it was built.
Thanks/Mike
Nov 09, 2007 | Frigidaire 24 in. FDB1250RE Built-in...
Bosch Dishwasher tells me a cycle will take 75mins when it used to take 35mins. I have replaced a relay on the CPU which has fixed the problem of it not heating, but not sure why timer is all wrong. The...
BOSCH IS HAVING A PROBLEM RIGHT NOW WITH SEVERAL OF THERE CONTROL BOARDS...as a matter of fact just out today on a bosch shu33 model dishwasher and control was bad and was told by a local supplier there is a recall on these control boards.... based on you explaination it sounds like the control is bad and will need replaced... good luck to you..
Jan 06, 2011 | Bosch Dishwashers
Timer doesnt tick but works if moved manually
The timer has come to the end of it's serviceable life. Being mechanical, they wear out and are not designed to be econonomically fixed.
It needs replacing.
Regards
Jan 14, 2010 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
Bosch SHU4312 won't finish cycle, won't drain.
The control board on these units is prone to a cold solder joint cracking. I have read that Bosch recommends replacement and will supply the board, not covering labor. I repaired mine prior and have done one for a friend as well. Has lasted several years and counting
The symptom is constant cycling without ticking down the last few minutes
Jun 04, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dial doesn't advance
You don't want to replace the timer switch just for that. If it is under warranty, get it done ASAP.
If not, wait till you have a real problem with the timer, like it not running, or doesn't cycle completely.
Then the switch will have to be replaced and you'll miss that tick tick ticking.
Mar 17, 2008 | Jenn-Air JDB6510 Built-in Dishwasher
Dishwasher
If you coud describe where you hear the noise that would be helpfull. the noise could be somethig hilling one of the spray arms or something stuck in the pump impeller. if you only wear it when it is only in a wash cycle I would say it may be someting in the wash pump. But also make sure the spray arms are moving freely
Jul 19, 2007 | Bosch 24 in. SHV66A03 Built-in Dishwasher
My dishwasher does not fill
suspect it has not drained fully hence will not fill. humming noise may be a foreign object stuck in the pump impellor. take pump out and check impellor turns freely
Mar 31, 2007 | Bosch 24 in. SHU66C05 Stainless Steel...
Dishwashers Logo
98 people viewed this question
Top Dishwashers Experts
