Question about Yard Machines Garden
MTD YM 11A-B16N229 after I get the motor running the engine turns off?...only after a few mins.I have not had the mower long.
libaredneck
  • 119 Answers
SOURCE: MTD RIDING MOWER with 618-0229 transmission.
sounds like you need a new drive belt
Posted on May 04, 2009
  • 22 Answers
SOURCE: have to choke MTD to keep it running
check fuel pump diaphram is not streched or hard, check fuel filter for blockage, or fuel tank cap might be not venting, if none work drain and clean out carby bowl.
Posted on Jul 20, 2009
SOURCE: mtd ym 21" starts but wont stay running
Just checked my dad's for same problem. First thought is its not getting gas from tank; line is clean and no holes. On his 22" MTD push, i took off the air cleaner housing to expose the carb. Sprayed carb cleaner in carb throat, checked for smooth butterfly valve action, and also cleaned small jet/opening on left side of carb housing. Put it together and it ran perfectly. Don't buy a kit until you at least try this, its cheaper!
Posted on Oct 19, 2009
  • 33 Answers
SOURCE: MTD riding mower does not move forward or reverse.
this is a belt driven transmission. from the engine driven pulley going aft towards the xmission differential there is another smaller variable speed pulley, there is a long belt between these two, from the variable speed pulley there is a larger xmission pulley that sits kitty-corner to it with a belt between these two. This larger "xmission pulley" is what drives the differential and depending upon which gear you have selected, makes it go forward or reverse. Check that both belts between pulleys are on, check that pulley's hardware is completely secured (nuts tightened down) The heads of these pulley's are splined to align to the shaft(s) and if they aren't tight, they will just spin and not engage the transmission. If your battery is under the seat, remove it and you should be able to see and access the aft pulleys. If both belts are on and engaging the pulley's and the shaft is turning on the transmission pulley than you have transmission differential failure. Bet it's the belt off or pulley head loose. Good luck, hope this helps
Posted on Apr 14, 2010
riceski
  • 1851 Answers
SOURCE: Briggs and Stratton 11 hp motor on Mtd ride-on
Sounds like you need to remove the starter and see what you can do to check it out.
Posted on May 05, 2010
Are all MTD push mowers that begin with 11A basic(ally) the same?
No, when I searched your 11A-020L-765 It brought up a lot of 11A- and some had overhead engines and some did not, had mulching and big wheels and enough that the answer is no.
Mar 25, 2016 | Mtd Garden
Cannot find any information on my mtd mower
I searched it and came up with this info, at the bottom of the of the info page was a pdf owners manual, also under specs it shows the engine as a Powermore, new one on me, Huskee 21 in 2 IN 1 140cc Push Mower CARB Compliant For Life Out Here
Runs rough, Uses LOTS of fuel, not leaking fuel, Starts hard.
turn your set screw at 1 1/4 turns from closed,it is wide open
Jul 19, 2015 | Garden
Mtd 11a-54m7031 idles high
Most new units only run at one speed. (So they can meet the EPA limits).
May 15, 2014 | Mtd 22" Yard Machine Push Mower
My yard machines by mtd mower model number 11a-b13l029 won't start?
Fuel must be less that 30 days old! Air filter OK? oil level OK? Is the shut off cable streteched, If it is then is makes contact and will not allow the engine to start.
Bought 2 brand new MTD 3.5 HP 20 inch cut lawn mowers Model #11A - 020B352 Both mowers run until hot then cut out and will not restart only turn over with a squirt of fuel bulb then stall again. Both...
heres a few things to check, make sure that the oil is not over filled, you might have bad fuel,, and check the spark plugs on both to make sure they aren't fouled by fuel, if so,, clean the plug and regap them,
Jun 02, 2011 | Mtd Garden
Where is the oil drain plug for the mtd 11A-O84EO29
Hi dherrin...
Look under the mower housing on the motor and locate a square plug, or maybe a socket screw to remove.
This will be the oil drain.
Free answer...Please take time to rate me
May 21, 2011 | Mtd 22" Yard Machine Push Mower
Have to choke MTD to keep it running
Jul 19, 2009 | Mtd LAWN MOWER PART # 787-01341...
Garden Logo
82 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
