Question about Garmin Office Equipment & Supplies
Which usb cable is recommended? - Garmin Office Equipment & Supplies
  • 1,141 Answers
I would like to recommend you on Dynex™ - 6' USB-Parallel Printer Cable. it dows the job very fast. great cable!
Posted on Aug 22, 2010
Testimonial: "fast and professional answer!"
Hi I will like to use my computer on the tv what type of USB cable to use
Im pretty sure you cant use a USB cable-- best recommendation would be a HDMI, DVI, or VGA cable--- That will depend on what your TV and computer supports.
Oct 04, 2013 | Televison & Video
Unlock samsung GT E1190 phone
You can unlock this model here:
http://www.unlocksamsungonline.com/unlocksamsung/E1190
Either by cable or by unlock codes. However I would recommend by codes because you need a special FTDI usb cable to unlock by cable. Original USB cable will not work.
Jun 28, 2012 | Cell Phones
Is there a cable available to connect my HP 5470c scanner to my Toshiba laptop. What and where can it be purchased? My computer will take USB cables but the cable with the scanner is obviously not the...
This model HP5470C was supplied with a parallel and USB cables to connect to computers.
For PCs the manual recommends using the parallel cable and for Apple computers to use the USB cable.
If the Toshiba does not have a parallel printer port then try using the USB cable.
For a manual for your scanner go to this WEB site.
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&prodClassId=-1&contentType=SupportManual&prodTypeId=15179&prodSeriesId=28456
Mar 30, 2011 | HP Scanjet 5470c Flatbed Scanner
A printer error has occurred. See your documentation
What are the system requirements for using this printer? A: PC Compatible Requirements
- An IBM (r) compatible PC with at least a 486/66 MHz (for Windows 98) or Pentium (r) 133 MHz (for Windows 2000) processor (Pentium or higher processor recommended)
- Microsoft (r) Windows 98 or Windows 2000
- At least 16MB (for Windows 98) or 32MB (for Windows 2000) of RAM (32MB for Windows 98 or 64MB for Windows 2000 recommended)
- 50MB of free hard disk space (100MB or more recommended)
- VGA or better display adapter and monitor
- CD-ROM or DVD drive for installing the printer software
- USB connection: a computer running Windows 98 or Windows 2000, with a Windows-compliant USB port and a shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction. Apple Macintosh Requirements
- An Apple (r) iMac (tm) series or Power Macintosh (r) G3 or G4 with USB port
- For iMac: Mac (r) OS 8.5 or later (Mac OS 8.5.1 or later recommended)
- For Power Macintosh G3 or later: Mac OS 8.5.1 or later If your iMac is running OS 8.1, you need to upgrade your operating system before installing your printer software. To find out which operating system your iMac is running, select About This Computer from the Apple menu. If you're running OS 8.5 or 8.5.1 on your iMac, Apple recommends that you install iMac Update 1.1. Download the update for your system from Apple at http://asu.info.apple.com. Contact Apple if you have problems installing an update.
- 16MB of available RAM (more recommended)
- 50MB of free hard disk space (100MB recommended)
- VGA display or better
- A shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction.
Oct 27, 2010 | Epson Stylus RX580 InkJet Photo Printer
How to connect to computer
This printer uses a USB cable with male A/male B ends; it is not included in the box. A cable of 6' or less is recommended (USB hubs are not recommended but usually will work. Print servers often allow the printer to work but not the scanner.) Install the software before connecting the USB; if you need to download it, go to this site: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15402 and choose your OS.
If the printer or scanner doesn't work, try a new cable. Bad cables are more likely to block the scanner. Also check that a working USB device works in the port. The software installs a monitor that must be running if the buttons on the printer are going to initiate any activity. (Some set up of the software for the buttons is often needed.)
I hope this helps.
Jun 29, 2010 | Canon PIXMA MP210 InkJet Printer
Need what type of printer cable to fix to the compaq laptop from Epson Stylus C86 so i can print from laptop
You can use USB or Parallel according to the user guide. Most laptops made recently wont have a parallel port and the cables are harder to find so I recommend USB.
Jul 29, 2009 | Epson Stylus C86 InkJet Printer
I have just brought dell latitude e5500 laptop. i wanted to connected the hp officejet 5610 scanner to my laptop but am not able to do. please help
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab19
Jul 11, 2009 | HP Officejet 5610 All-In-One InkJet...
CX9400 Windows 98???
Unfortunately, Windows 95, 98, and Me are not supported with this printer.
Listed below are the system requirements for your printer.
Windows Requirements
- A Microsoft Windows compatible PC with an 800MHz processor (1GHz or faster processor recommended)
- Microsoft Windows 2000, Windows XP, Windows XP Professional x64 Edition, or Windows Vista
- 256MB RAM for Windows 2000, Windows XP, and Windows XP Professional x64 Edition (512MB recommended) - 512MB RAM for Windows Vista (1GB recommended)
- 300MB free hard disk space (550MB recommended)
- 4x or faster CD-ROM drive for installing the software
- A Windows-compliant USB port and shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable may cause the Epson Stylus CX9400Fax Series to malfunction.
- An Apple Macintosh with a PowerPC or Intel processor
- Macintosh OS X 10.2.8, 10.3.9 to 10.4.x or later
- 256MB RAM (512MB recommended)
- A USB port and a shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable may cause the Epson Stylus CX9400Fax Series to malfunction.
May 25, 2008 | Epson Stylus CX9400 Photo Printer
Usb
This is Vikram Kumar Thumu from India-Hyderabad.
Well, I seen your message on the issue. She needs to use USB cable 2.0 version to connect the Printer to the Computer. Please buy USB 2.0 version type cable. You can purchase it at any store. I recommend you to purchase in any brand store.
Bye.
Oct 07, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
55 people viewed this question
Top Garmin Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Garmin Office Equipment and Supply Expert? Answer questions, earn points and help others
