Question about Victor Welding Tools
I need a rebuild kit for a CSR 350D oxy regulator or just new seat assy the seal is bad
2 Suggested Answers
  • 2468 Answers
SOURCE: need parts for victor 272654 oxy reg
I will sell exterior parts only,I do sell internal regulator parts but only to certified technicians that have the test equip and can re-certify the gauges after a re-build
Posted on Jul 27, 2010
85 jeep cherokee 2.5l runs fine on level ground but the carb floods when I'm going up hills? Any solutions? Its been tuned up new plugs and wires and everything but why is it flooding?
Your carb is needing to be rebuilt the seals and float and valve seat may be damage. The float opens when the fuel level in the carb is low. If the valve seat is damaged or the float is not working. Gas can keep pouring into the carb resulting in extra fuel. Till the engine stops and fuel pump pressure stops pushing fuel it will keep pouring fuel and will not stop till rebuilt correcting the problems. Buy rebuild kit and rebuild it or try junkyard and replace it.
Feb 12, 2018 | Jeep Cars & Trucks
1993 waverunner bogging down on take off. New rebuilt carb, will low oil level cause this? Is there a low level switch /?
Only of you have ran the engine out of oil...Sounds like the carbs may not be set correctly.. .Did a professional do the rebuild?..What exactly was "rebuilt".. were any parts replaced?
Sounds like the low speed (pilot jets/air screw passages may not be clean as they need to be??)
Please check the compression on each cylinder..remove the spark plugs... hold the throttle (carbs) wide open when you check this.. spin the motor for 5-8 seconds... you should get 120psi. minimum..(and less than 10psi difference).. if less, it might be time to actually rebuild the top end..(new pistons/rings/hone cyl.).. only bore it if absolutely necessary.. get it measured..
There are only 3 parts in a two-cycle carb that ever need to be replaced,,(unless they are actually broken) The needle and seat assy., the jet needle and the needle jet. ..see pic... parts # 41 = needle and seat assy. #6 = jet needle, #37 = needle jet.
The needle and seat regulate the flow of gas into the carb as the floats rise and fall..,, if they are damaged or leaking the carb will overflow with gas., the needle jet is a orifice with a specific size..The jet needle has a specific size, taper, and length..== The jet needle and needle jet work in unison to regulate the flow of gas from right off idle all the way to WFO..the needle jet/jet needle WILL wear over time causing the fuel/air mixture to become richer and richer and start fouling spark plugs..(this is more pronounced on 4-cycle ATV's)...
I hope this has shed some light on your carb situation...
Good luck...
exploded view of mikuni carb Google Search
Jul 10, 2017 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
Air is leaking from regulator knob on my d55146 compressor. will a regulator rebuild kit fix it or do i need a hole new regulator?
Yes. A rebuild kit will include all seals and o-rings needed.
This project is best handled at a service center...Reason being that the rebuild requires making sure that all seal surfaces are a clean machine surface to properly reseat and seal..
Apr 20, 2013 | Dewalt D55146 1.8 HP Continuous, 200 PSI,...
Todd engine for Lawn Tractor not getting fuel. bought a carb kit now what
kit should have included new needle and seat along with gaskets and possible welch plugs. Depends on kit purchased. Just need to remove and rebuild carb. They are very simple to rebuild, but need to clean all existing jets and everything else accessible first. Hopefully instructions were included, if not, will need to know model # to get info on how to rebuild carb.
Apr 10, 2013 | Garden
Rebuild window motor
sorry, there are no kits for that. just have to drill out the rivets and replace the regulator assy.
Oct 25, 2012 | 1997 Ford F350 Crew Cab
Bostitch n80s nail gun leaks air at the trigger.. I need instructions as how to remove the trigger assembly and replace with a new one. I have the new trigger assy.. Any help will be greatly...
under my name click on it and in the tip section on the left hand side of the page you will find detailed instructions on how to remove this valve. If you have trouble finding it let me know and if I have helped you with your problem would you please vote accordingly, Thank you
Mar 24, 2011 | Stanley Bostitch N80s Nailer -rebuild...
List of all components for a top end rebuild. Is there a kit out there?
  1. Piston
  2. piston rings
  3. head gasket
  4. Cylinder base gasket
  5. Fresh bore on cylinder (if it can be bored), see note
  6. Possibly valves, valve guides and valve seals, see note
  7. Miscellaneous seals and gaskets
NOTE; some cylinders are nickle plated and can not be bored unless re-plated. If cylinder is beyond repair then replace it. The valves should be re-seated. If any dishing or valve stretch is present, the bad valves must be replaced. Valve guides seldom need replaced but valve guide seals could be bad. If the bike gives a puff of white smoke when started after sitting for 5 or 10 minutes then replace the seals.
A “very helpful” rating on this answer? Thanks!
Jul 02, 2009 | 2003 Yamaha WR 250 F
Installing rear brake caliper rebuild kit.
To remove piston safely use the brake pedal to press out piston. You will need to remove the pads so it can do this. You will need a container to catch the fluid when the piston comes out. Clean the the piston with a fine polishing cloth 600 grit or higher so as not to leave scratches, replace piston if it pitted or burred. Clean inside of caliper, remove inside seal with dental type tool. Roll in the new seal, position same as old one. install new outter dust boot if equipped with one. Lubricate seal and leading edge of piston with brake fluid. Slide piston into calipier. You will need to make sure it is started straight and then use a C-clamp to compress the piston all the way in. Never ever use any oils or grease any any internal brake parts because it will cause seal failure. Clean parts are critical, but again , no petroleum products. Good luck
Jun 10, 2009 | 1982 Honda GL 1100 Gold Wing
Welding Tools Logo
229 people viewed this question
Top Victor Welding Tools Experts
Bill Boyd
Are you a Victor Welding Tool Expert? Answer questions, earn points and help others
