Question about Kenmore Elite Oasis 27052 Top Load Washer
I have a kenmore elite Oasis He. It will not level the cloths out for spin cycle. I have to manually adjust cloth for it to balance out. This happens every time on large loads and very small loads. Can the counter balance be out of whack? please help..Thanks I have always owned a Kenmore washer but I have to say this is a poorly designed washer. I may have to change brands if I cant get this problem solved...Thank you for your help....
  • 15,935 Answers
It appears your Load Balance Sensor has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 27, 2010
Why does my kemore elite always get out of balance when spinning worst with a light load
When Loading, Always Distribute Clothes Evenly (weight wise) With A Light Load Usually Clothes Will Become On One Side Before End Of Wash Cycle--If You Look Before Spin Cycle And This Had Happened, Redistribute and restart from present position (cycle wise)
Feb 28, 2015 | Kenmore 24032\24036 Top Load Washer
Kenmore elite model 11027052602 clothes wet after spinning cycle why
You might have a restriction in the outlet hose. Worse, you might have a bad pump.
It is easy to check for the constriction. Pour water into the tub, set the timer for the spin cycle and watch how strong/fast the water leaves the hose. Check for water beneath the tub.
Oct 07, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
How do you solve the balance problem in the kenmore elite oasis even with no clothes it in
Try running with no clothes? If still shows UL when empty running, your machine needs service. P.S. use HE detergent or else.
Aug 27, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
When my washer is on the spin cycle it goes out of balence shuts down no matter wht size load or how i arange the load never completes the spin cycle this is a kenmore elite oasis 5 years old. #2 problem...
as for the washer there maybe a broken spring or where the spring attaches that balances the drum. look for this firest. for the dryer is it spinning around at the right speed if it is then the belt is ok. is it hot inside the dryer after running it when you open the door. if ti is check the dryer vent hose and exterior door at end of hose to see it they are plugged up . if the hose is plugged up the heat and moisture can't excape and the clothes will take a long time to dry.
Sep 12, 2011 | Kenmore Oasis HE 27082 Top Load Washer
After having frozen pipes, and thawing out we have noticed that the spin mode is a lot loader than it used to be
If it's not an out of balance problem (the tub), then there could be something wrong with the clutch or the transmission pulley. Make sure you don't overload your washer. Open the lid while it is in spin cycle and see if the clothes are balanced out.
http://www.appliancepartspros.com/
Feb 09, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore Elite Oasis He. During the final spin cycle the load becomes unbalance and the drum beging jumping up and down until the UL code is displayed, this happens on every load except when empty...
UL = uneven load.
Re-distribute clothes and re-try.
If still no-go... the load balance sensor is likely to blame.
Sep 24, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Excessive noise during the spin cycle. we have owned the washer for 16 months. problem started 1 wk. the machine is level.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 03, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Constantly off balance
I have a kenmore elite oasis top loading washer about 3 years old. I took it apart and checked the springs and the rods and the plastic ends that hold the rods in place and all of them look fine. I run an empty load in the washer and it still goes unbalanced on the spin cycle. My water bill has tripled due to the fact that every load takes 3 to 4 washings. I need help please!
Jan 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
182 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
