Question about Xerox Computers & Internet
We have an error code 08,005,48:1498 Can you tell me what the problem is? Its a Xerox Phaser 8560
  • 526 Answers
SOURCE: Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Posted on Apr 15, 2009
SOURCE: xerox phaser 8560 nvreset - how?
According to http://www.laserquipt.com/support/idx/42/615/article/-Reset-the-Printer-to-the-Factory-Defaults-NVRAM-Reset-.html (and it worked for me):
NOTE: Resetting NVRAM returns stored parameters in the image processor board NVRAMto their factory default values. The print count and the Adobe firmwareserial number are not affected by this reset. You can reset the PostScript NVRAM using the Service Tools menu or the Service Diagnostics menu.
To reset the printers NVRAM using the Service Tools menu:
NOTE: Print a Configuration Page before resetting NVRAM.
Pressand hold the [Up] arrow button on the Control Panel, and then press the[OK] button. This will automatically display the Service Tools menu onthe Display Screen.
  1. Press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
To reset the printers NVRAM using the Control Panel:
  1. Pressthe [Up] or [Down] arrow button on the Control Panel to select[Troubleshooting] on the Display Screen, and then press the [OK]button.
  2. Press the [Up] or [Down] arrow button to select [Service Tools], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen.
In answer to the clarification request, I suspect they have lost the admin password. Does that help you answer the question?
Posted on Dec 15, 2009
  • 2072 Answers
SOURCE: error code 09,035.43:30419 on Xerox Phaser 8560
Ink count flag stuck after melting 2.5 Cyan Ink Sticks
Check your ink sticks, one of them is most likely stuck.
Posted on Dec 30, 2009
darkpain
  • 316 Answers
SOURCE: xerox phaser 8560 error 04,018.48:26
Hello,this fault code indicates a problem with the process control system.The printhead temperature dropped below the head cleaning needed threshold and that's why stops warming up.The first you need to do is to verify the temperature of the room that the printer is,if its too cold,near from an open window...If was too cold and not in the room temperature then move the printer and your are done.If this doesn't solve your problem run the Monitor Heaters tests with all heaters ON.Are the heaters operating correctly?If yes replace the Electronics Module.If no you have to inspect the harness to the failed heater.Is the harness damaged?If yes you must replace the harness.If no replace the problem component.
Good luck:)
Posted on Feb 04, 2010
pineworks
  • 4041 Answers
SOURCE: Xerox Phaser 8560 - error code 09 037 45 108564
Hi there
That's a ink loader error, due to the 8200 ink stick; to fix it:
- Power down the printer.
- Hold the back button and the info button at the same time, without letting go, power up the printer.
- Keep holding down the buttons until the XEROX logo comes fully to the center of the screen, keep holding for 2 more seconds, then let go. I'll take about a minute or two for the Diagnostic screen to come up, the display will turn blank and black.
- When the Diagnostic screen comes up go to down to the Function or Exercise option, there will be an option that says "clear ISC faults" it'll ask you to press OK to confirm, after you do then you will exit Diagnostics and the printer will reboot.
It should be fine until it happens again. Until all the 8200 ink is gone you will probably be doing this a few more times. Also make sure the 8200 ink is not jammed inside the ink loader, if it is then you have to un-jam it some how.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
Error message on xerox 8560 09,038.46:13269
Go to the Xerox.com website and follow the troubleshooting aid to these types of faults.
Good luck.
Feb 26, 2015 | Xerox Phaser 8560/YN Printer
Xerox Phaser 8560DN error code 07,010,43
Sadly, Xerox says that this means "Power off the printer and contact support". Phaser 8560 Support Drivers
However, there is something about "opening the pivot plate", it's Greek to me, but google it and see if you can't reset the brain in the printer and get it back to life without an expensive service call.
Aug 23, 2014 | Xerox Phaser 8560DN Laser Printer
Even after numerous on off sequences I still get the same error code of xerox phaser 8560 error code 07 010 43.22845
7,010.43:
The printhead is stuck in the tilted position or is not able to tilt forward to the print position, due to problems:
Has ink spilled ink around the printhead that prevents it from moving to its center position? You should be able to push the printhead right to left. Clean the printhead area. Is the printhead stuck to the Wiper Blade? Check the process drive gears for obstructions. Ensure the gears are correctly aligned and homed. Has ink spilled on the Head Tilt gear drive train? Clean the gears area of ink.
Has
Has
Apr 23, 2014 | Xerox Phaser 8560DN Printer
Xerox 8560 error code 07,007.40
That error signifies a problem with the printhead tilt, you need to replace the Process motor camshaft pivot kit, part number 8560-Z2.
http://www.iteminconline.com/8560-z2_8560-z2-xerox-8560-process-motor-camshaft-kit.htm
Feb 07, 2014 | Xerox Phaser 8500/DN Printer
On the 8560, what does the error code 07,010.43:14070 mean??
In the Xerox support website that error indicates that the printer needs to be turned off and call for xerox assistance. Does not specify the problem.
Although, this website refers to this problem.
http://www.fortwayneprinterrepair.com/wordpress/2011/09/25/xerox-phaser-8400-8500-8550-8560-07010-43-error-message/
If the printer has only one year old, the best solution will be to call for xerox assistance because it is under warranty.... I think...
Aug 08, 2012 | Xerox Phaser 8560MFP Laser Printer
09,035.43:46672 this is an error message i get on my xerox phaser 8560... can you tell me what it means?
If after following mariolands advice the problem continues, you will need to replace the ink loader, for the 8560 ,the part number is 133K27771. Here is a video that will show you how. The video also covers the 8400, 8500, and 8550. Though the part numbers are different the procedure is the same. ">
Jan 30, 2011 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser error code: 09,038.46:37640
The ink loader 133K27771 is probably defective
Whit
Item, Inc.
Jul 26, 2010 | Xerox Phaser 8560DN Laser Printer
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
Computers & Internet Logo
59 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
Outback Jack
Outback Jack
Steven's...
Steven's...
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
