Question about Cuisinart DCC-1200 Coffee Maker
Grind & Brew Thermal™ 12-Cup CoffeemakerModel # CUI DGB-900BChas stopped grinding after it was cleaned. This has never happened before amd I am not sure how ti fix it. What should I do?
This is a cronic problem with the DGB900BC even after cleaning. the problem is the gate or trap to the grounds needs to open/remain open during grinding or all backs up and jams. my unit opens the door (correctly) during the rotation but closes just before grinding (over-rotation?). Cuisinart is not aware of this problem (800-726-0190). please call them; i just have.
Posted on Sep 08, 2010
  • bpls6 Jan 18, 2011
    Mine is doing the very same thing, has anyone dug into this issue yet with any results? What were the results from your call?
  • MBdoug Jan 19, 2011
    Sorry, hopeless. Cuisinart told me to boil vinegar water through the grinder/maker???? The best solution is to return it to CostCo and avoid the grind/brew model until it improves. The next best idea is to buy the stand-alone Cuisinart grinder with selectable # cups and coarse/fine setting. It is a little messier but no more total failures.
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
We have a Cuisinart DGB-900 BC Grind and Brew Thermal Coffeemaker. Our Problem is that the bean grinder has stopped working. We purchased the coffee maker on 2/25/10. Prior to this happening, we were...
try cleaning the grind chute again. if problem persists:
this is a cronic problem with the DGB900BC even after cleaning. the problem is the gate or trap to the grounds needs to open/remain open during grinding or all backs up and jams. my unit opens the door (correctly) during the rotation but closes just before grinding (over-rotation?). Cuisinart is not aware of this problem (800-726-0190). please call them; i just have.
Aug 30, 2010 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Just bought a cuisinart grind & brew dgb-550 and can't get the program setting to work. Tried putting in a time and leaving it and tried pushing the program button after entering the time.
Push the program button one more time - the first push allows you to set the time, the second push stores the time you have just entered, and then you have to press it one more time to make the light next to the program button light up tell it to brew at the set time.
Aug 23, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Coffee maker wont stay on after making a pot of coffee help
i downloaded the owners manual at http://www.cuisinartwebstore.com/detail/CUI+DGB-300BK
and resolved it by reading the manual. ( i had lost my original )
May 16, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a 12 cup cusinart grind & brew. The hopper is not working
You may have to clean the grinder....even more. That happened to me once. First I cleaned out the coffeemaker with the brush, and "dug" out more coffee, then I used this product which you can find on Amazon: "Urnex Grindz Coffee Grinder Cleaner - Urnex 17-GRINDZ12-40." It's expensive, but it really worked well.
Apr 02, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Grind and Brew thermal (model CUI DGB 600BC)coffee filter cup hard to open, now won't close. Cup where beans are added, bean cup difficult to open as well. Need to find repair place near zip code 95127.
That problem is endemic to this grind and brew only - find out if you are still in warranty - try and get a DGB-550BK as a replacement - the 600 is the only one with this problem. Replacing it with the same model will likely lead to the same result.
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
Dec 02, 2008 | Cuisinart DCC-1200 Coffee Maker
Cuisinart Grind and Brew DGB-700 12-Cup
Hi - You can download the manual by clicking the link underlined in blue below:
DGB-700
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 12, 2008 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
I Have a Cuisinart Automatic Grind & Brew Thermal that when you start brews a small amount of coffee and then shuts off. I shut off grind and start. After I do that it brews a full pot. We have cleaned...
I have a cuisinart model dgb-600bc coffee grind & brew, didn't have a manual with it when purchased, plugged in it & hit the on button, lights up when pushing in on it, but let it go & it stops, but doesn't brew nothing. HELP -
Aug 26, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart DCC-1200 Coffee Maker Logo
599 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
