Question about Maytag EPICz Electric Dryer
Clothes not getting totally dry: we put them in for their cycle and after done, they still are damp. I have made sure lint screen is cleaned and we clean it every time we use it. is there anything else we could do to try to fix this problem?
    President:
  • 3,074 Answers
The vent hose is crimp clogged restricted, clear it up and it will dry the clothes
Posted on Aug 28, 2010
How to Make a Non Working Xbox Disk Work?
    1)Take disk out of Xbox
    2)Try turning off Xbox
    3)Choose one of the methods to try and fix disk Polishing disk
      -Use air first (blow across disk, or use a soft brush to remove any specks from disk before polishing)
      -Get a soft, lint-free polishing cloth (make it damp)
      -Use wet side of cloth to clean shiny side of disk
      -Dry whole disk (dry polishing cloth)
      -Put it in Xbox Using soap or water
        -Use soap or windex-slightly wet paper towel to wipe off disk from middle towards outside
        -Use furniture cleaner Using toothpaste
          -Rub toothpaste on disk, dampen a suitable soft cleaning cloth
          -Rub from centre-then move all the way around to edge
          -Wipe toothpaste off with a wet cloth-wipe any dampness with dry cloth
          -Put it in Xbox Using car polish
            -Get a dry cloth and add a small amount of polish to it
            -Rub in a circle motion, then wipe dry
            -Put it in Xbox Peanut butter
              -Put a dab of peanut butter on a lint-free cloth
              -Don't rub it in a circle motion
              -Put it in Xbox Using rubbing Alcohol
                -Pour out a small amount of rubbing alcohol onto a cotton bud
                -Rub from centre of disk, moving outward to edge
                -Wait for it to dry and try again Wax from candle
                  -Get some melted wax from a normal candle
                  -Gently pour wax on scratches-rub in with soft cloth
                  -Wipe off excess wax with a damp cloth
                  -Let disk dry for 5-10 mins and try again Vanish Oxipowder
                    -Cover entire shiny side of disk with powder
                    -Wait 5-10 mins
                    -Clean powder off completely with soft damp cloth
                    -Place disk in Xbox Other possible fixes
                      -Take disk to game/computer shop
                      -If any of your friends has game, borrow disk from them, install it to hard drive, and hope Xbox recognises it
Oct 20, 2016 | Video Game Consoles & Games
My Keurig says to prime
This video link below, from keurig, should get you back running.
remove reservoir, if you have a water filter, remove it and set aside. Use a damp non abrasive cloth and clean tank including filter screen. DO NOT DRY the inside with a cloth as lint may remain. DO NOT PUT in a dishwasher. Let it air dry. Reinsert the water filter. Put tank back into unit making sure it is aligned properly. Fill tank all the way up with clean water. Turn power on and attempt 3 WATER only brew cycles at the 6 or 8 ounce size. DO NOT USE A PORTION PACK.
If this doesn't work, you may have to clean the needles of the K-cup holder and / or the filter screen and water reservoir port.
If the problem persists you can contact you can contact Keurig at 1-866-901-BREW (2739) or Keurig.com
http://www.keurig.com/what-if-brewer-indicates-prime?cm_mmc=Google-_-Dynamic%20Search-_-Keurig-_-Keurig%20Homepage
Mar 09, 2014 | Coffee Makers & Espresso Machines
I have a whirlpool duet model gew9250pw1 dryer it gets good and hot put when the cycle is done some of the clothes are still damp.i not sure if it is the timer or a censer. i know when we start it the...
Look for an airflow blockage. Be sure lint filter is cleaned and if lint is accumulated in the air stream path, take a vacuum or brush and clean it out. Dirt and lint are a dryer's worst enemy.
Mar 17, 2013 | Whirlpool Duet GHW9150P Front Load Washer
How do I clean the monitor? my cat has put nose prints all over it, and when I attempt to wipe it off (turned off, of course) I still cannot get it clean.
The best way to clean an LCD monitor is to take a lint free cloth and spray it with Windex or vinegar and water solution, or in a severe case, summer windshield washer fluid (the kind meant to remove insect guts). Make sure the cloth is DAMP, not WET (we don't want anything dripping out of it) and wipe the screen thoroughly.
Dry with another lint free cloth while the screen is still damp.
Jul 17, 2011 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Won't dry clothes completely. They are still damp after a 60 min cycle
check you vent hose- if plugged/crimped air can't get out with moisture- also go to HOME DEPOT or LOWES- get dryer lint brush- goes in hole where lint screen is - clean out good
May 10, 2011 | Dryers
After drying for 75 minutes timed cycle, my clothes are still damp. I also cannot get clothes dry on the normal cycle at all.
Things to check:
Make sure the dryer is heating up
Make sure the lint screen is clean
Check the vent to make sure it isn't obstructed or plugged (this is the pipe that goes to the outside)
Make sure the unit isn't overloaded
Check the spin cycle of the washer - if it isn't spinning out enough water for the load, the dryer can't make up the difference - sometimes this is as simple as a plugged discharge filter on the hose that goes to the drain.
Dec 23, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
When clothes are dryed on the perm press cycle either reg dry or very dry, they are still damp. I have to run it through 2 or more times to get them dry. I'm told by Bosch that is what perm press is...then...
You may not be getting sufficient air flow--remove the lint filter and wash it with detergent and hot water. Also clean excessive lint out of the air vents (under the filter too). Don't use 'perm press' if you want things absolutely dry. Remove and hang up before they cool. 'Damp dry' really means 'don't dry' I guess!
Aug 28, 2009 | Dryers
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Machine drys fine on timed cycles but shuts off before clothes are dry on automatic cycle.
First try cleaning the moisture sensors with rubbing alcohol, these are two silver colored strips located inside the drier just below the lint cleanout
Oct 31, 2008 | Whirlpool GEW9250 Electric Dryer
Maytag EPICz Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
