Question about LG 42PX5D 42 in. Plasma HDTV
Flickering screen hello, my screen turns on great but after a min or so it starts to flicker seriously. I have tried all different connections as well as the rgb but all the same. I did have it stable on channel 6 with no problem bu t nothing else works. It displays perfectly for a min then flickers really fast. but I can see what is on the sceen. any help would be great
  • LG Master
  • 1,689 Answers
Unstable voltage regulation, or unstable referencing for the video signal levels.
The tech will service this by doing board swappings to fx the fault.
Jerry G.
Posted on May 15, 2008
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
HP L1720 flickering!
this is common, the display is bad.
all displays, fail. all do. no reason to get angry,
a broken display is worth nearly zero value $0
so how much money will you spend on worthless.?
you can get a new display at Walmart for $65, ,
lines are usually very serious. and is not ever the DC-DC inverter
a bad inverter (< it's power supply) is for the back ground lamps. not data side. the data side is failing and is common, if you twist the screen
it gets worse. ? bingo. data driver connections bad , screen.
IN most cases the part that is bad (screen), costs $100 new. or 50 used
why go there/
Jun 01, 2017 | HP L1720 17 in. Flat Panel LCD Monitor
N95 replacement screen flickers after 20 mins of
remove the screen and reinsert it.....may be some loose connections.. try using another screen...if problem persists then update the firmware or else change the screen....
Nov 24, 2009 | Nokia N95 Cellular Phone
RCA W40D20 HDTV intermittent flicker and it gets blurry
loose connection on ends check you hdmi cable vga cable and vgi cable so the pins are good or not bent try to borrow another and see if it changes it and dont go to far from your tuner .
Apr 21, 2009 | RCA Scenium D40W20 40" Rear Projection...
Toshiba lcd tv flickers after being on 15 mins.
This is likely a power problem. Have the power brick checked by an electronics tech to see if it is cycling off and on over time. If the power supply is not the problem, you should consider returning it if you can.
Nov 19, 2017 | Toshiba 32HL66 32 in. LCD HDTV
Acer Laptop Screen Flickering
The flickering screen indicates that it is a backlight problem with either a faulty inverter or inverter connection problem. The inverter is usually located at the bottom edge of the LCD screen, and may have one or two connectors (one for the video info. and one for the inverter power or a combined connector) attached to the motherboard under the case near the top edge of the keyboard near the hinges. Reseating these connectors may solve your problem.
Jan 29, 2009 | Computers & Internet
Flickering screen of my lifebook s series
This sounds like a loose connection. If you can press on the back of the lid and it flickers or stops flickering, then it's definitely a connection problem. You will need to take the bezel around the screen off, the screws are hidden under small sticky tabs or the small rubber bumpers. Then take the screen loose and check the connection on the back. Replace the tape on the cable, if there is any.
Aug 02, 2008 | Intel S6240 Notebook
Lcd Flickering
Sounds like the driver board for the backlight is going there a spot on the screen part of the case ( usually at the bottom) that feels much warmer than the rest?
Mar 16, 2008 | Gateway 450ROG Notebook
Sony Bravia LCD Flickers/distorts
Wanna sell the tv for parts? Kev0201@yahoo
Sep 14, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
LG 42PX5D 42 in. Plasma HDTV Logo
189 people viewed this question
Computer Repairing
Computer Repairing
