Question about Kenmore Refrigerators
Model 70282990 Top Freezer Kenmore Refrigerator, Manufacture date 10/99. Freezer compartment freezes, but still not up to par as now hard ice cream gets real soft. refrigerator section cooling very minimally.
Kazong
  • 152 Answers
SOURCE: Soft ice cream
there are vent openings in the back of the freezer you should not block that ..it will cause the temp to go up
Posted on Jan 21, 2008
docjohn174
  • 943 Answers
SOURCE: Amana Side-by-Side refrigerator hot spot
hi tanks for the question there are heaters at the spots you said were hot and those heaters are there to prevent moist air from hitting cold surface and create warer droplets from forming on those surfaces i would remove the back of the fridge and vacuum it out that should solve your problem thanks the appliance doc
Posted on Sep 18, 2008
turbo5280
SOURCE: Kenmore refrigerator freezer not freezing
The problem is in the defrost system.. You have a defrost heater in your freezer that comes on 3 times a day & melts the frost to keep your freezer frost free. That frost turns to water & runs down a drain & eventually goes to a drain pan located under the unit. On these models the hole for the drain is located directly under the evaparator fan. The drain hole is to far from the heater so the water settles & then freezes around the fan blades causing it to stop spinning. Its that fans job to circulate cold air from the freezer to the fridge, so now all the cold air is staying in your freezer. Last I knew they were workin on a solution to this but you need to contact the manufacturer. A temporary fix would be to unplug & then defrost the freezer by taking out the freezer panel & melting all the ice. Boiling water is effective. When you get the ice gone from around the fan you should be able to see the drain hole & be sure water runs freely down the hole. Put it back together then adjust the front legs of the fridge so the whole unit slopes back slightly causing the water to run back to that drain hole without settling.
Posted on Apr 27, 2009
SOURCE: FREEZER ICED OVER, LOWER COMPARTMENT NOT COOLING
Well, if the service person said the defroster is not the problem, there must be a good reason. But, I would go with a faulty defrosting system. Most likely suspects are the defrost timer and the defrost heating element.
Posted on May 05, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
What temp should the fridge and freezer each be?
According to FDA safetey specs bacteria can grow at 40 to 140 F degrees .Refrigeration must be below this number but above 32F to keep from freezing. I maintain commercial refrigeration and they run at 34 to 38 F degrees. I have deep freeze set at -10F which keeps ice cream very solid but can go up to +2 F which renders softer ice cream...
Jun 25, 2009 | Kenmore 64802 Top Freezer Refrigerator
May 05, 2009 | Refrigerators
Ice maker stopped working???
water valve or icemaker or make sure freezer is freezing check see if you have frost build up
Apr 06, 2009 | Kenmore 57029 Side by Side Refrigerator
Freezer quit freezing
HI,
you can try this suggestion first.
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks,
Mar 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer not keeping ice cream cold
One thing you can do is clean out the area under the ice box where the condenser coils are located. Make sure the fan motor is blowing under there. Clean the kickplate. Get the air restrictions out of the fins and that may bring the freezer temp back up to par.
Nov 23, 2008 | Frigidaire FRS23KF7AB Side by Side...
Top freezer Freezes/ Bottom not cold
defrost problem. advance defrost timer to defrost (till it shuts off) . remove freezer panel, check voltage and amps to heater,if heater is hot, replace timer, if heater is cold and no voltage, replace defrost limit switch. defrost all ice, carefully! with hair dryer, no poking with screwdriver.
Oct 26, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Soft ice cream
Jan 21, 2008 | Kenmore 72073 Top Freezer Refrigerator
Refrigerators Logo
470 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
