Question about StarTech.com StarView SV211K 2-port KVM Switch
Have we seen the last of the boxes - StarTech.com StarView SV211K 2-port KVM Switch
How
check 4 places, the left or right of the dash which can only be seen with the doors open, under the dash below the steering column, or lastly under the hood. you may even have 3 fuse boxes like my chevy silverado had, one on each side of the dash and one under the hood.
May 22, 2014 | 2006 Chevrolet Tahoe
Is there a cabin air filter on this truck, if so, where?
check the heater box it will look like a slide panel under the heater box or behind the glove box or just under the right side wiper under the hood. I've seen them in all 3 places . you could also just call or go to you local dodge dealer and give them the last 8 didgets of your vin and the'll tell you .
Aug 21, 2013 | 2002 Dodge Durango
I sent message to a friend aboard at around 9pm but it was remaining one tick for few hours and suddenly his last seen time was being updated at 11:30pm but still remain one tick up to now. Pls clarify.
The time last seen and the ticks have nothing to do with each other. The time last seen correlates with the last time the person was logged into their account, while the ticks show if the person has received the message or not.
Jun 30, 2011 | WhatsApp Messenger
I don'thave the code to run my game
The code can be anywhere in the box.The disk envelope,inside the box itself,I've even seen it on the last page of the manual.Keep looking,you'll find it!
Jan 15, 2010 | Electronic Arts Medal of Honor: Pacific...
Play in steering wheel replaced upper and lower ball joints and out and inner tie rod ends. what next?
raise the truck and have some one rock the steering wheel back and forth while you look for excessive movement at the idler arm - also check is the input shaft on the steering gear box rotating more than the output(pitman arm side) i've seen more steering box failure in the last several years especially true with big tires or boggy road driving, a rebuilt box can be bought at a local parts store- o'reillys, advance, napa etc.
Nov 23, 2009 | 2001 Chevrolet Silverado 2500HD
Heater on ford 2003 ford pick up blows cold air
on the evap box there is a control mtr that switches the hot cold door. these mtrs are prone to failure. the other problem that i have seen is that the door breakes in side the evap box and that means removing the box to replace the door . if i remeber correctly you may have to slide the dash back to gain assces to the control mtr to test it good luck
Dec 21, 2008 | 2001 Ford F150 Styleside SuperCrew
Vm9512 touch screen stop working just like that
The backlight has gone bad. I have seen this exact problem in SEVERAL other Jensen units.. The backlight might last 5 years, or in extreme cases, maybe 15 minutes.. I have also seen them bad out of the box.
Dec 19, 2008 | Jensen VM9510 Car DVD Player
Periodic tv screen blackouts
The problem is your cable box. I know you said you replaced it, but I work on TV's everyday and, sorry to say this but cable box HDMI outputs have serious issues, like no or intermittent sound and video. I have seen customers exchange their cable boxes 5 and 6 times and still have the problem. Your best bet is to use the component outputs of your cable box, visually you will not see a picture difference between component and HDMI when using a cable box. Your other solution is to get satellite; I have NEVER seen an HDMI issue with a satellite box
Nov 25, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Remote code for Akai 37" lcd with Dish Network
Akai support 216-454-0864 .I have the same problem and called the support phone. The answer is this TV came without a code programmed in it.
Aug 17, 2008 | Akai LCT3285TA 32 in. LCD Television
Black square
If the picture can be seen on the sides of the black square you need to go to the menu and find the text and turn it off
Usually in the closed caption section
Mar 12, 2008 | JVC AV-27230 27" TV
StarTech.com StarView SV211K 2-port KVM Switch Logo
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
