Question about Koch Media Dunes Of War for Windows
Couldn't write file data/save/restart.xs (Error 997) Windows 7
Thank you admin. <a rel='nofollow' href="http://videofullizle.com">hd film izle</a>
Posted on Aug 21, 2012
2 Suggested Answers
SOURCE: Does Emperor RotMK work with Windows 7?
I have Windows 7 32bit and was able to successfully install Emperor ROTMK. I used to get that error with an old disk I had. it was because my disk was damaged.
Posted on Mar 13, 2010
How do i reset user password on aspire one d255e atom n455
1. restart windows system from login page.
2. before booting to "Acer" press immediately Alt+10 and continue pressing until
"windows prompt: loading". (this is before the Windows Logo)
3. you will arrived into two (2) options.
-Reset or restore factory settings.
and
-second is restore system only.
note: the second option will restore the system without and boot to normal without password
plus back-up the data and will be save by default directory c:\backup (this is where file save on documents, music, video and others)
-the first option will erased all data and format the system and install fresh windows 7 starter
and install the drivers of the netbook acer -aspire one.
4. wait for the system to finish its task under option 2 then it will restart or reboot.
5. process of resetting the password will be done. you can now type a new password for you
windows system.
Jul 10, 2014 | Computers & Internet
Tip
How to fix No Bootable Media Error Message
FAT (File Allocation Table) is one of the most widely used file systems used now-a-days with various versions of Windows operating systems and memory cards. Every logical partition contains a FAT that consists of file allocation information and the information of free allocation units that need to be assigned to files. Although the FAT file system is reliable, corruption still occurs due to various reasons. In such situations of FAT corruption, your system becomes unbootable, resulting into inaccessibility of data saved in FAT based hard drive. To access the data after FAT file system damage, an easy way is to restore the data from an updated backup. But, with inaccessibility of data backup or backup falling short to restore the required data, an ideal option left is to use an advanced FAT Data Recoveryapplication that can recover the lost data.
To illustrate the above scenario, consider a practical case the below error message pops up when you attempt to boot your system:
“No Bootable Media”
As the above error message appears at the time of booting the system, you wont be able to access the data saved in the hard drive.
Cause:
The above error message because the FAT file system has been corrupted. Few main causes for file system damage are improper system shutdown, human errors, and virus attack.
Resolution:
To isolate the above error message and to access the data after the above error message appears, you will need to follow the below steps:
Run CHKDSK utility to repair the FAT file system. If the problem persists, format the hard drive.
While the latter resolution resolves the above error message completely, it also deletes the data saved on your hard drive. In such cases, if the backup is not available, then you can only recover your formatted data by using an advanced third-party FAT Data Recovery software.
A FAT Partition Recovery utility thoroughly scans a FAT based hard drive and recovers almost all data, even after formatting. The data recovery utility can be downloaded from the Internet.
Stellar Phoenix Windows Data Recovery is an efficient FAT Partition Recovery tool that recover lost, deleted, and formatted data from both FAT (FAT12, FAT16, FAT32, VFAT) and NTFS (NTFS, and NTFS5 ) based hard drives. The detailed help manual attached with the tool allows even a new user to perform recovery easily without any technical knowledge. It supports Windows 7, Vista, XP, 2003, and 2000.
on Jun 30, 2010 | Computers & Internet
Tip
"Could not start the Remote Procedure Call (RPC) Service. Error 1058"
Issue: "Could not start the Remote Procedure Call (RPC) Service. Error 1058" error message when you manually start the Remote Procedure Call service Resolution :
1 . Restart your computer by using the Safe Mode startup option. To do this, follow these steps:
a. Restart your computer, and when the Boot menu appears, press F8 .
b. Under Windows Advanced Options Menu, select Safe Mode, and then press ENTER .
c. When the Boot menu appears again with the words "Safe Mode" displayed at the bottom of the menu, select the operating system that you want to start, and then
press ENTER.
2 . Click Start, click Run, type regedit, and then click OK.
3 . In the left pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Hardware Profiles\Current\System\CurrentControlSet\Enum\ROOT\LEGACY_RPCSS
4. On the File menu, click Export.
5. In the File name box, type a name for the registry file.
6. In the Save in list, click the location where you want to save the registry file, and then click Save.
7. Right-click LEGACY_RPCSS, click Delete, and in the Confirm Key Delete dialog box, click Yes.
Note Do not delete any one of the following subkeys that may be found under the ROOT subkey:• MS_L2TPMINIPORT
• MS_NDISWANIP
• MS_PPPOEMINIPORT
• MS_PPTPMINIPORT
• MS_PSCHEDMP
• MS_PTIMINIPORT
8. Exit Registry Editor.
9. Restart your computer by using the Restart Windows Normally startup option.
on May 30, 2008 | Microsoft Windows Vista Home Premium with...
Imy friends daughter forgot her password how do we get back into it craig 7 in netbook
and
windows system.
Jun 29, 2014 | Craig Electronics Recertified - Craig...
Missing binkw32.dll
Download binkw32.dll from link and save it to your Hard Drive.
2. Copy binkw32.dll file to C:/windows/system32
3. Overwrite if asking.
4. If you still getting error - copy the dll file also to your software/game folder.
http://www.dll-files.com/dllindex/dll-files.shtml?binkw32
scroll down and click DOWNLOAD ZIP-FILE
Nov 06, 2013 | Microsoft Windows 7 Home Premium for PC
Gateway laptop error
Which operating system ?
Restoring your Windows 7 Gateway computer to its original factory settings is a great way to get rid of pesky viruses you can't seem to remove from your computer, or simply to remove old programs and files from your computer and start with a clean slate.
Your Windows 7 Gateway computer will likely run faster as a result of deleting old and unnecessary files.
It's also a good idea to restore your Windows 7 Gateway computer to its original factory settings if you plan on selling it, or passing it along to a family member or friend.
Recover From Windows 7 Home Screen
Click the "Start" icon in the lower-left corner of your Windows 7 home screen.
Click "All Programs" in the Start menu, then click "Gateway".
Click "Gateway Recovery Management" to open the Gateway Recovery Management program.
Click the "Restore" header, then click "Restore System To Factory Default".
Click "Yes" in the "Confirm Restoration" dialog box, then click "Yes".
Click "OK" in the dialog box warning you that all of the personal data on your computer will be deleted. Your computer will automatically restart.
When your computer restarts the restoration process will begin. The process could take anywhere between 30 and 90 minutes.
Click "OK" when a dialog appears telling you that the computer has been restored to its original factory settings and that you need to reboot your Gateway Windows 7 computer.
Your computer will reboot.
After the computer restarts you will need to configure Windows 7 with your personal preferences.
Recover at Startup
Turn on or restart your computer and hold down "Alt" while clicking "F10" during startup until you are redirected to the Gateway Recovery Management program.
Click "Restore System From Factory Default".
Click "Next" to begin the restoration process.
or if still no joy
http://www.almuseo.com/download-repair?Windows 7 0xc0000185for Windows 7 0xc0000185 and associated problems.
Windows 7 0xc0000185 error message codes are almost always caused because of missing system files inside your Microsoft Windows operating-system.
When you've got Windows 7 0xc0000185 error message then we suggest that you perform an error scan.
This article provides related information that explains the best way to repair your Windows Windows 7 0xc0000185 error codes either by hand and automatically. Additionally, this guide can help you to fix most regularly occurring error code messages connected with Windows 7 0xc0000185 error code which you might possibly get.
Jun 03, 2013 | Computers & Internet
Hi, I have a laptop Compaq A945 US with Windows 7 installed in it. I am facing a serious problem these days as my laptop shut down automatically while doing my work. It happens after 10-15 min on first...
dear..
i think you should re-install your laptop, maybe the system has an error because some files are missing, it can be happens because of viruses, to re- format your os you can click one time restore..just turn on or reboot your laptop and quickly press f11 button on your keyboard, but no data will save when you do this, so you need to back up your data first, so you don't lose your work..
if one click restore couldn't be done, you need to prepare a bootable windows cd. to install windows from cd you need to change your boot set up, press f1 when you turn on your laptop, go to boot menu change your first boot to cd room and the second boot to hard drive, enter the windows cd, press save and exit, when appear a message "boot from cd or dvd" quickly press any key, then you can follow the instruction that appears on your screen..
May 19, 2011 | HP Compaq Presario A945US 17" Notebook PC
I have a windows 7 ultimate, but i want to change it to windows xp service pack 2. can i change windows 7 to win xp without damaging all the data i have stored?
YES BUT FIRST YOU HAVE TO WIPE THE HARD DRIVE. YOU CANNOT "DOWNGRADE" FROM 7 TO XP...ONLY UPGRADE.
BACK UP ALL DATA FIRST
Oct 15, 2010 | Microsoft Computers & Internet
Quickbooks pro 2009 error code: 00000 00000 shuts down quickbooks, can't get past this error for installation
  1. Open the company file in QuickBooks Pro for Mac 2009.
  2. Resort QuickBooks lists.
  3. Run the Verify Data Utility.
  4. Run the Rebuild Data Utility.
  5. Create a Back Up of the file:
  1. Go to the File menu.
  2. Select Back Up to QuickBooks for Windows.
  3. Save the file to the Desktop of the Mac.
6 Copy the file to a portable media.
7 On the PC, copy the file from the portable media to the Windows 8 Desktop.
8 Restore the backup into QuickBooks for Windows.
for more help visit QuickBooks Technical Support
Jan 08, 2009 | Computers & Internet
Problem with windows xp service pack 2
Windows was unable to save all the data for the file drive_letter:\file_path\file_name. The data has been lost. This error may be caused by a failure of your computer hardware or network connection. Please try to save this file elsewhere.To restore normal behavior:
1. Open a CMD.exe window.
2. Type the following command and press Enter: REG ADD “HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\3ware Storage Controller” /V CacheControl /T REG_DWORD /D 0 /F
3. When you receive the The operation completed successfully message, shutdown and restart Windows XP.
Apr 18, 2008 | Computers & Internet
Koch Media Dunes Of War for Windows Logo
2,308 people viewed this question
Top Koch Media Video Game Consoles & Games Experts
James Wishart
Are you a Koch Media Video Game Console and Game Expert? Answer questions, earn points and help others
