Question about Garden
LlI have a Black & Decker drill (KR600CRE) which starts as soon as I plug it into the mains and cannot be switched off by pressing the trigger. Please can you advise. Thanks Anthony Nield
rowdy45176
  • 2176 Answers
SOURCE: I have the black and decker hammer drill model
look at the back of the brush holder for a tab that the forward/reverse lever locks into, it might be broken not allowing it to shift.
Posted on Mar 03, 2009
woobie dog
  • 1273 Answers
SOURCE: Black and Decker Cordless Drill Chuck stuck in full open position
I'd put penetrating oil in it and tap the chuck with a plastic hammer. That should free it up.
Best rgrds, W/D
Posted on Aug 18, 2009
  • 243 Answers
SOURCE: I need to replace the keyless chuck on my black
most of them have a screw in the chuck. turn it complete open and remove screw very often lefthandthread. after that turn off the chuck and place new one. replace screw.
Posted on Feb 12, 2010
Testimonial: "hrelpful, thanks"
wireguy212
  • 1627 Answers
SOURCE: How to remove the chuck of Black & Decker Drill BD154R?
You need to open the chuck and remove the bolt from the bottom of it[usually a #2 phillips].The next step is to insert a 5/16 allen wrench into the chuck and tighten the chuck.Hold the drill with the chuck facing away from you then strike the allen wrench with a hammer on the right side[so it goes down] and now you will be able to remove it by hand,good luck.
Posted on Mar 21, 2010
  • 87 Answers
SOURCE: How do I know if my battery is bad or if my
With a multimeter set it to 12 volt dc and place the leads on the two parts that would be touching the battery. If you see voltage then it is a bad battery.
-David
Posted on Nov 08, 2010
How can I reverse the direction on the drill?
Above the trigger there is a black slide switch that will reverse the direction if its in the colckwise direction the richt side is pushed in if counter clockwise the left side is pushed in.
Apr 06, 2016 | Black & Decker Black and Decker FIRESTORM...
I have an 18 volt B&D drill driver. Trigger will not activate the drill motor.
Hi- I'm sorry to hear that your switch has failed in your drill. Switches are covered under warranty as long as you are within the warranty period. You can locate your nearest Factory Service Center at the link below so we can assist you with ordering the part or handling warranty repair. Please be sure to the Factory Service Center.
http://www.blackanddecker.com/Service-Centers.aspx
If you have any questions, please let me know and I'll be happy to assist.
Thanks
Black + Decker Customer Service
Feb 13, 2015 | Black & Decker 18V Cordless Drill/Driver
How do I exchange bits in the keyless * BLACK & DECKER 12-Volt 3/8" Cordless Drill
In Black and Decker drills when the drill stops turning the chuck spindle locks automatically. All you have to do is grip the outer sleeve of the chuck and turn it anti clockwise to open it. Turn it clockwise to close it. When you press the trigger to start drilling the spindle unlocks automatically again.
Jan 10, 2011 | Black & Decker Garden
Black & Decker 1/2" drill
I had to replace the variable trigger on my 3/8 Black and Decker as the trigger failed and would not start the drill.Maybe you have the sme problem as many B&D drills have the same variable trigger.
Jan 10, 2011 | Drills
Model DR230 corded drill...worked one time...now will not do anything. Checked power and plug...will not make any noise.
I suspect that the drill trigger has malfunctioned. I had a variable speed drill that the trigger went, and the replacement from Black and Decker cost more than the drill was worth.
Dec 30, 2010 | Black & Decker Drills
When replacing cord on black & decker 7190 type 1 electric drill i dropped the drill one of the wires pulled free and im unable to visibly tell how it is to be rewired correctly need diagram displaying...
If you look at the trigger/switch mechanism, you'll note little lettered ovals on either side at the bottom/base where the wires go. The black (hot) wire from the plug goes to the side stamped "LINE", and the white (neutral) wire goes to the side stamped "LOAD"
Jul 02, 2010 | Drills
Drill turned on and off intermittently when
Sounds like the switch---might try spraying electrical contact cleaner into it using the small tube attachment.
Feb 18, 2010 | Black & Decker DC825KA 18V Impact Driver
Describe how to remove drill bit and install a
Most cordless drills use keyless chucks these days. Shift the drill into reverse and hold the main body of the chuck. Pull the trigger and the bit should come out. Put it into forward and run it to tighten onto a new bit.
Dec 02, 2009 | Drills
How do I change my black & decker electric drill to go in reverse or forward? As you can see I'm tool challenged. Kathleen
The switch near the trigger that toggles left or right controls that.
Good luck with your project, Kathleen.
Oct 02, 2009 | Black & Decker 3/8" Variable Speed...
Garden Logo
77 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
