Question about Frigidaire FMV156DC Microwave Oven
Our microwave safety quite working and it will not turn on unless you push up on the door
  • Frigidaire Master
  • 9,047 Answers
It's probably as simple as a door switch or maybe its mount is loose.
On these models, it's most often the bottom door switch.
See this helpful file on door switches.
We also have the full service manual and have uploaded it to our site here to help you.
If you only need a switch, you can order a universal type here for $5 postpaid.
You can order other parts here.
Posted on Aug 23, 2010
How do I fix a microwave that counts down and does not turn on?
Appears to need a replacement door switch, might just be cheaper to get a new microwave if it is old.
They are made to close tightly and sealed so you are not exposed to microwaves. Not sure how safe you are overriding the microwave safety feature standing nest to it holding door.
Nov 30, 2015 | Microwave Ovens
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
When I open microwave oven door . close the door again light comes on an plate spins an wont stop unless I unplug it
Inside the door latch, is a safety feature, that prevents the microwave from operating unless the door is closed. This feature can easily become faulty, or even come with the fault already causing the microwave to constantly operate whenever the door is closed.
Microwaves can be very dangerous in regard to holding HEAPS of voltage within the unit. I recommend getting yourself a new microwave, as attempting repairs on any of the modern units can, more often than not, be far more costly then the price of a new one.
Hope this helps.
Apr 14, 2014 | Hamilton Beach Beach 87108 Microwave Oven
When I turn the micro on it does not turn nor heat unless I lift up on the door. Seems like door needs to be adjusted slightly
The problem you're seeing is nearly always a result of a safety switch that is not being activated by the door. The result is that the oven thinks the door is not shut fully. Pressing the door closed at the latch or downward from the top opposite of the hinges will usually provide enough movement to activate the switch. One of these methods is what I suspect you are doing to get it to work.
Inspect the prongs on the door. Make sure both are not damaged or broken in anyway. The size and shape are critical for effectively engaging the safety switch. Repair or replace parts as needed.
The switch itself is usually connected to the latch striker assembly or to a switch deeper inside the oven - to the latch itself - to detect its position. The striker assembly is partially visible behind the two openings of the door frame - the two prongs on the door push them down and when fully closed, keeps them down. Since accessing these parts requires disassembly of the oven by qualified persons to maintain safe operation - the oven should be service professionally to ensure that the door is closed completely before allowing the microwave to function.
Sep 03, 2013 | Dacor DCM24 Convection/Microwave Oven
Just like others, the microwave component does not work. Convection works just fine. Before microwave quit, it appeared to have something to do with the door(?) I would put a napkin b/w door and by...
If the inside light, fan and turntable come on when you try to cook, but it does not heat, this is probably a bad primary interlock (top door switch) or possibly that switch's mount is bad.
See this file on safety, and this file on door switches.
We have the full service / installation manual for this unit, and have uploaded it here to help you.
If the inside light, fan and turntable do not come on when you try to cook, the 20A fuse is probably bad or loose in its holder.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 18, 2010 | GE Advantium SCA2000B Microwave Oven
Microwave wont kick on unless I push the door up
Hi, this is a faulty door latch assembly. the switch is malfunctioning. the entire door latch assembly will need to be replaced.
Jun 21, 2009 | Amana ACO1520A Microwave Oven
MY PANASONIC MICROWAVE OVEN HAS POWDER BUT IT DOES NOT HEAT.
I'm assuming the clock is on and controls appear to work, but won't start cooking. Quite often the latch on the door can slip out of place, so the safety interlocks do not clear even with the door closed. The latch can be accessed by removing the cover of the microwave, and should be easily visible. The latch assembly can be adjusted by loosening the screws and pushing the unit upwards. Re-tighten screws on new position. A very small adjustment is usually enough. Do not undertake repair work if you are not up to it.:::Spiceweasel.au
Apr 04, 2008 | Microwave Ovens
Oven will not work unless I push on the door
It's probably a broken tab on the dooir switch mount or a screw holding the door switch mounts is loose.
Even though a door switch clicks, it may still be bad inside.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find an exploded view and order parts by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
You can also order Sharp parts from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 06, 2007 | Sharp R-1480 Microwave Oven
Spacemaker II Microwave problem
Quite often this is due to a bad door switch. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Sep 27, 2007 | GE JEM31 Microwave Oven
Frigidaire FMV156DC Microwave Oven Logo
47 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
