Question about HP Digital Projector xb31 Multimedia Projector
HP XB31 Projector heat senor
Hi, i believe that the heat sensor is defected on my XB31 HP Projector.
How can i replace it / where is it located / what does it looks like ?
Thanks. Marc
  • deadxb May 09, 2008
    My xb31 has either a fuse or sensor or other issue as well: It does not respond to power in any way, no lights, no nothing. Are there any user-replaceable items that would cause this? It's not the bulb, since the bulb is new. It does not power u0... Help! Thanks, Alan L
Hi, i solved the problem by opening the projector cover and placing/making sure that the left fan was in the the right place ...
on the bottom tracks but make sure to align the fan with the top cover track as well .... in other words, if the left fan is not *exactly* in it slots (top & bottom) ... a slight degree misplaced (fan) and the projector over heats...
- this happened during a change of lamps : + the lamp that was on was not even broke.. !!
- it can occur too during shipping or just manutention...
Posted on Aug 28, 2008
Hi, well the projector will work for +/- 1h30 then overheats and shuts down. The light indicates overheat, not temperature problem.. in the specs.. anyways, i put a new lamp in and it still does the same thing. It worked for 4-5 hours without shutting down when i tried it with the top cover open at 1 inch.
Thanks for your interest. Marc.
Posted on May 21, 2008
I am having somewhat the same problem...bulb is also new here.....But when I turn mine on the bulb light turns on(the one with the bulb and lightning bolt) and the picture turned off...I tried it this morning and unplugged it and video worked...but now no those are the symptoms...can anyone help?
  • 563 Answers
Hi Marc
How do you know that the sensor needs replacement ?
Could you please give me some of the sympoms first ?
This could be something other than a sensor.
Posted on May 06, 2008
I need to replace bank 1 senor 1 on a 2005 Avalon and bank 1 senor 2.
bank 1 is the front bank closest to the grill
sensor 1 is the heated oxygen sensor and is located in the manifold or before the cat converter
sensor 2 is the oxygen sensor and is located after the cat converter
get a specialist oxygen sensor tool so that the small wires are not damaged during repalcement
Sep 26, 2016 | 2005 Toyota Avalon
I have an HP XB31 Projector with a broken color wheel. Is there someplace to get a new / replacement wheel without having to buy a used or broken projector on e-bay?
You should be able to get the part directly from HP. See Here.
enter your serial number or parts code and viola.
If it's not listed on the site. Call them. They have many parts not available online over the phone.
Jan 25, 2011 | HP Digital Projector xb31 Multimedia...
The oven wont heat up above 50
HI, this is not a serious issue here. you will need to test the resistance of the oven temp senors. it seems to be defective. also, check the wiring harness from the oven temp sensor to the control. make sure the wiring harness is in good condition. replace the oven temp sensor if found to be defective.
May 30, 2009 | Hotpoint SY36 Style Line Stainless Steel...
Xb31 digital projector
There are many so called shops. But I highly recommend an authorized or certified shop. Although HP is no longer making projectors, there are still authorized and certified shops in Atlanta. We can not direct you to one at this time. Good luck.
Nov 27, 2008 | HP Digital Projector xb31 Multimedia...
XB31 projector overheat
Hi sun_md
This sounds like a typical temp. sensor that is faulty.
If you take off the top cover of the Projector and follow the cables from your fans to the Mainboard - you'll find a smallish board that regulates the heat of the Projector. You will also find another sensor on top of the lamp housing.
Try replacing the sensor that goes with the fans first , this is normally the one giving problems.
Good luck and thanks for using Fixya !
May 22, 2008 | HP Digital Projector xb31 Multimedia...
Connecting Projector to High Def Source (e.g. PS3 HDMI)
That projector supports M1-D also which is the digital side of the M1-DA... Anyway, they sell cables that are M1-D to HDMI to which you can hook directly to the PS3. They are decently priced too, less than $20. I know this thread is old, but I came across it due to an issue I am having with my xb31, broken color wheel. Trying to find parts...
Feb 06, 2008 | HP Digital Projector xb31 Multimedia...
HP Digital Projector xb31 Multimedia Projector Logo
784 people viewed this question
Ben Johnson
