Question about Philips HTS3544/37 Theater System
WHERE I CAN FIND PARTS Philips HTS3544/37 Theater System LASER LENS.
SOURCE: philips hdmi dvd player
hook up playstation 2
Posted on Jan 02, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: philips home theater system
Make sure there is a video cable of some type running from the back of the Philips to the television, and make sure the TV is on the correct source channel. Make sure the home theater system is in disc mode.
-Tha Mp3 Doctor
Posted on Dec 31, 2008
SOURCE: can you give me remote
can i get a manual for Phillips DVX 8000 multimedia home theater
Posted on Jan 07, 2009
  • 547 Answers
SOURCE: About 80 volts AC is passing to ground and is on
Check the ground wire on the electrical outlet. You can get a simple outlet tester for $10 or so. Here's one at Ace Hardware for $12.
When we bought our current house, the electrician failed to connect the ground wire to two of the outlets in the basement, and the induced current was about 80VAC on the ground.
If this helps, be sure to hit the "Thumbs up" for me!
Posted on Jan 24, 2010
dunnbiker
  • 8546 Answers
SOURCE: shortage problem
So stop feeding it fuses and get it fixed. Internet isn't a good medium for hands-on repair.
Posted on Jun 06, 2010
How to clean dvd laser lens
Take a ear bud with alcohol and clean it
Jan 17, 2012 | Philips LX3700D System
The dvd player reads the cds but when dvd is inserted it says no disc after few seconds of load
the laser is weak. need to replace. you could also try opening unit and clean lens with alcohol.
Mar 23, 2011 | Philips HTS3400/37B System
My dvd's try to spin about a few rotations then stop and it always says NO DISC regardless the type of cd/dvd i insert I was wonderin if it was something to do with the gears because it seems the laser is...
Hi, when a DVD system spins for awhile and does not play, it means that the Lens Which makes the CD inserted rotates, is to weak to play the inserted. Happens when the Lens is dirty.
You will need to clean up the lens by using a DVD lens cleaner. Comes inform of a CD and comes with instruction.
After cleaning the Lens, if still does not play,that means you will need to replace the Lens inside the system with a new Lens.
Have a nice day....
Feb 25, 2011 | Philips HTS3410D/37 700W DVD Home Theater...
THE CD PLAYER STOPS AFTER ABOUT 2O MINS any idea why
Check the laser lens inside the unit - inspect it for dirt or dust. Clean with "Q" tip and alcohol. If the problem persists, the laser might be going out. Check the lens to verify it moves up and down. Check the lens to observe a red beam. If these processes do not occur - the laser is bad.
Nov 01, 2010 | Philips HTS335W Home Cinema System 5.1...
Dvd player will not work it loads but will not
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's. .
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Good luck.
May 15, 2010 | Philips HTS3544/37 Theater System
Philips hts3400 will not play dvd
first clean the laser lens if this donçt solve the problem change the motor disc spindle because are on bad conditions
Jan 09, 2010 | Philips HTS3400/37B System
My DVD player just stopped loading movies. Could it be the sensor is bad?
You can try and clean glass laser eye with rubbing alcohol and cotton swab, otherwise you will have to replace the laser lens unit
Aug 05, 2009 | Philips HTS3400/37B System
Philips hts
Did this problem just start or been that way since you purchased it? Do you still have a warranty on it? Whens the last time the Lazer Lense has been cleaned?
Nov 11, 2007 | Philips HTS3450 System
Philips HTS3544/37 Theater System Logo
168 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
